- 型号:SABO MPB.533.00 PLM500
- 数量:2
- 制造商: 厦门兴锐达自动化设备有限公司
SABO MPB.533.00 PLM500现货
高可用性:对可用性要求较高的过程,DCS系统可以提供冗余配置(见图2)。
图2:对可用性要求较高的工艺过程,冗余对长期运行至关重要。效率和便于实现冗余,对将费用维持在预算内十分关键
功能需求:某些行业和设施需要历史数据库、流线型的报警管理、以及配置通用用户接口的中央控制室。有些则需要制造执行系统(MES)的集成、先进的控制和资产管理。DCS系统内置这些应用(见图3),使其很容易被添加到自动化工程应用中,而无需增加独立的服务器,也不会增加集成成本。从这方面讲,DCS系统经济性更高,而且可以提高生产力,降低风险。
图3:每种系统平台都具有独特的数据库需求
生命周期投资回报率:设施的需求,因行业而异。对于规模较小的工艺工程,没有扩展需求,也不需要与其它工艺过程区域集成,因此PLC系统具有较好的投资回报率。DCS系统可能具有较高的安装成本,但从全生命周期来看,DCS系统所带来的产量增加和安全效益,会抵消一部分成本。
平衡短期需求与长期愿景,对操作确定性和改善工厂运行、维护非常关键。
Gigatronics 8652A
Gigatronics 900-12-18
Giga-tronics 80410A Low VSWR Modulation Power Sensor, 10 MHz to 18 GHz, K(m)
Giga-tronics 80420A High Power 1 Watt Modulation Sensor, 10 MHz to 18 GHz, K(m)
Giga-tronics 80421A High Power 5 Watt Modulation Sensor, 10 MHz to 18 GHz
Giga-tronics 80701A High Performance Modulation Sensor, 50 MHz to 18 GHz
Gigatronics 6061A signal generator, NIST-calibrated
Gigatronics 1018
Gigatronics 605-2-8
Giga-tronics 80322A High Power 25 Watt Sensor, 10 MHz to 18GHz, N(m)
Giga-tronics 80323A High Power 1 Watt Sensor, 10 MHz to 26.5 GHz, K(m)
Giga-tronics 6082A opt 130 Synth Sig Gen (Reduced 8/12)
Gigatronics 80350A
Giga-tronics 80314A Low VSWR Power Sensor, 10 MHz to 40 GHz, K(m)
Giga-tronics 80304A Universal CW Power Sensor, 10 MHz to 40 GHz, K(m)
Gigatronics 8651A
Gigatronics 8652A Dual Channel Peak/Average RF Power Meter
Giga-tronics 80320A High Power 1 Watt Sensor, 10 MHz to 18GHz, K(m)
Giga-tronics 80601A Universal Modulation Power Sensor, 10 MHz to 18 GHz
Giga-tronics 80402A Universal Modulation Power Sensor, 10 MHz to 18 GHz, APC-7
Gigatronics 80354A 200W Peak Power Sensor
Gigatronics 605-10-18
Gigatronics 8652A Power Meter 40 GHZ / Dual Channel
Giga-tronics GT-8888A USB Power Sensor, 10 MHz to 8 GHz, CW
Gigatronics 17071
Gigatronics 8542C
Giga-tronics 80313A Low VSWR Power Sensor, 10 MHz to 26.5 GHz, K(m)
Giga-tronics 80302A Universal CW Power Sensor, 10 MHz to 18GHz, APC-7
Giga-tronics 80310A Low VSWR Power Sensor, 10 MHz to 18GHz, K(m)
GIGATRONICS 8652A POWER METER WITH 80601A SENSOR- nice Giga-tronics
Gigatronics 8652A Power Meter w/Opt.12 (Reduced 8/12)
Gigatronics 80334A
Gigatronics 6061A
Gigatronics 16936 / 16936A
Gigatronics 58542
Gigatronics 6062A
Giga-tronics 80303A Universal CW Power Sensor, 10 MHz to 26.5 GHz, K(m)
Wavetek Giga-Tronics 80324 .01-40GHZ sensor RENT/SALE with mfg cal cert.
Giga-tronics 80401A Universal Modulation Power Sensor, 10 MHz to 18 GHz
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
工控宝APP下载安装
