- 型号:403D/404D/1006D
- 数量:100
- 制造商:宁波日昕动力科技有限公司
- 有效期:2020/11/26 0:00:00
Critical and high frequency spares and consumables 关键的高频备件和消耗品 | ||||
No. | Description | 中文描述 (仅供参考) | Part Number | Unit |
1 | Air Filter | 空气滤芯 | Perkins | Ea |
2 | Air Filter | 空气滤芯 | Dry element type | Ea |
3 | Air Filter | 空气滤芯 | (26510337)-20000-51238 | Ea |
4 | Air Filter | 空气滤芯 | (AF25904) | Ea |
5 | Air Filter | 空气滤芯 | (AS25708) | Ea |
6 | Air Filter | 空气滤芯 | (CH11038)-10000-51240 | Ea |
7 | Air Filter | 空气滤芯 | (PA2527/AF1872 | Ea |
8 | Air Filter | 空气滤芯 | 150-5030 | Ea |
9 | Air Filter | 空气滤芯 | 3261641 | Ea |
10 | Cooling Antifreeze Coolant | 冷却防冻液 | NA | Ltr |
11 | Fuel Filter - 518-9074 | 燃油滤芯 | 518-9074 | Ea |
12 | Fuel Filter (4461492) | 燃油滤芯 | #VALUE! | Ea |
13 | Fuel Filter (CH10930)-10000-59652 | 燃油滤芯 | (CH10930)-10000-59652 | Ea |
14 | Fuel Filter (FS 1280) | 燃油滤芯 | (FS 1280) | Ea |
15 | Fuel Filter (FS1040) | 燃油滤芯 | (FS1040) | Ea |
16 | Fuel Filter (FS1251) | 燃油滤芯 | (FS1251) | Ea |
17 | Fuel Filter (FS1275) / FS1280 | 燃油滤芯 | (FS1275) / FS1280 | Ea |
18 | Fuel Filter 1R0749 | 燃油滤芯 | 1R0749 | Ea |
19 | Fuel Filter 26560017 Perkins | 燃油滤芯 | 26560017 Perkins=26561117 | Ea |
20 | Fuel Filter PKCH10931 | 燃油滤芯 | PKCH10931 | Ea |
21 | Fuel water separator | 燃料水分离器 | TBC | Ea |
22 | Engine oil | 机器润滑油 | Oil 15w-40 | Ltr |
23 | Generator Grease | 发电机油脂 | Ltr | |
24 | Oil Filter - 264 - 1492 | 机油滤芯 | 264 - 1492 | Ea |
25 | Oil Filter (2654403) | 机油滤芯 | 2654403 | Ea |
26 | Oil Filter (CH10929)-10000-59645 | 机油滤芯 | (CH10929)-10000-59645 | Ea |
27 | Oil Filter (LF 3349) | 机油滤芯 | (LF 3349) | Ea |
28 | Oil Filter (LF 9000) | 机油滤芯 | (LF 9000) | Ea |
29 | Oil Filter (LF16087) | 机油滤芯 | (LF16087) | Ea |
30 | Oil Filter 107 Perkins | 机油滤芯 | 107 Perkins | Ea |
31 | Oil Filter 1R1808 | 机油滤芯 | 1R1808 | Ea |
32 | Water Filter (WF 2126) | 滤水器 | WF 2126 | Ea |
33 | Battery 120A | 电池120A | NA | Ea |
34 | Battery 90A | 电池90A | NA | Ea |
35 | Battery 150A | 电池150A | NA | Ea |
36 | Battery 70A | 电池70A | NA | Ea |
37 | Filter AS FU | 机油滤清器 | CA1R0749 | Ea |
38 | Filter AS | 空气过滤器 | CA3261641 | Ea |
39 | Filter AS-LU | 机油滤清器 | CA1517737 | Ea |
40 | Element AS | 空气滤清器 | OL3E98481 | Ea |
41 | Engine oil | 机器润滑油 | Oil DEO-C14-PAIL | Ltr |
42 | Hydraulic oil ISO VG 46 | 液压油 | ISO VG 46 | Ltr |
43 | 1100KVA Control Panel | 控制面板 | Ea | |
44 | 60 KVA Control Panel | 控制面板 | Ea | |
45 | 80 KVA Control Panel | 控制面板 | Ea | |
46 | 8" ball Valve Redress kit | 球阀调整装置 | Ea | |
47 | 6" ball Valve Redress kit | 球阀调整装置 | Ea | |
48 | 4" ball Valve Redress kit | 球阀调整装置 | Ea | |
49 | 3" ball Valve Redress kit | 球阀调整装置 | Ea | |
50 | 2" ball Valve Redress kit | 球阀调整装置 | Ea | |
51 | Metallic Flange Gasket (Various sizes) | 金属法兰垫片 | Ea | |
52 | Metal Flange (Male and Female Thread) | 金属法兰垫片 | Ea | |
53 | 2 core cable | 2芯电缆 | MTR | |
54 | 3 core cable | 3芯电缆 | MTR | |
55 | Armoured Cable | 铠装电缆 | MTR | |
56 | NPT Fittings (assortment) | PCS | ||
57 | Electrical panel and breakers (assortment) | 配电板和断路器(分类) | PCS | |
58 | Lighting junction boxes | 照明连接盒 | EA | |
59 | 16 amp single pole, 230 AC MCB | 16安培单极,230交流MCB | EA | |
60 | 25mm2 DIN rail mounted WDU terminal blocks | 25mm2轨装WDU端子块 | EA | |
61 | Sodium bulbs, baluster, igniter | 钠灯泡,栏杆,点火器 | EA | |
62 | Mercury bulbs, baluster, igniter | 水银灯泡,栏杆,点火器 | EA | |
63 | Oil paint; green, yellow, other | 油漆;绿色、黄色.其他 | LTR | |
64 | All assorted general fasteners and fixings | 所有配套的通用紧固件 | PCS | |
65 | All oil and lubricants, general rags, cleaning products | 所有油和润滑剂,一般抹布,清洁产品 | PCS |
公司主营Perkins发动机配件,volvo发动机配件,帕金斯发动机配件,cat卡特发动机配件18874821491微信同号原装——完美匹配,性能佳
根据该设备的型号量身设计的原装零件能确保与新机零件保持完全一致的技术状态及品质,每个零件都与厂家流水线上新车装配的零件规格及质量标准一致;从而实现与该柴油机的完美匹配,保护整机优质性能。
非原装——力不从心,匹配差
非原装零件设计和制造的工艺标准都无法与原装零件相比,造成的结果是零部件与整车的匹配性差,从而降低柴油机的运行性能;更有甚者会腐蚀、磨损柴油机本身,大大降低柴油机安全性能。/
原装零配件——规范生产,品质认证
我们所销售的每一个零件都原厂装机件,品质认证,性能出色,运行可靠。
非原装——良莠不齐,难以监控
英珀威机械告诉您付厂假冒配件的危害是不言而喻的,它绝不像普通生活用品那样,只是在工艺、品质上存在问题,严重时它会危及他人的生命安全。然而由于利益的驱使,仿冒配件至今仍难以杜绝,使用假冒配件会大大降低柴油机安全性能。/
英珀威机械教您辨别常规假冒原厂配件的方法:感官 所谓假冒配件,必然是仿造原厂正品的配件,它们在标识、包装等细节上也尽可能的仿冒,因此很容易混淆视听。由于仿冒品低价低质的本质,它在感官上不可能做得与正品一样,因此我们辨认的第一步就是通过这些方面来进行辨认。正品厂家配件进行批量生产,包装规范,因此包装盒同样会注重质量和工艺。如果你看到配件的包装自己模糊、色彩黯淡,那十有八九就是假货。另外原厂配件会在包装盒(或者袋)上规范标明产品信息以及厂家信息,包装内应该有合格证、检验手续等。仿冒品往往也会在这方面图省事。英珀威机械教您辨别常规假冒原厂配件的方法:从工艺质量,特别是细节处来分辨。假冒配件受制于加工工艺,往往在细节上很粗糙。采用劣质材料制造,这类仿冒品比较好辨认,由于看上去已经很假,有时候卖家自己也会直说这是假货。怕就怕那些在表面文章下很下功夫,但内在用伪劣材料的假配件,这就需要一些专业知识了。
- 电话:15706865167*18874821491
- 传真:0574-26892499
- email:18874821491@163.com
上一篇:AIP504-10
