当前页面: 首页 >供求信息 >福建省沃尔沃维保TAD1242VE柴油机零配件中心
供稿:宁波日昕动力科技有限公司 2019/11/29 20:43:35
人气:26
  • 型号:TAD1242VE
  • 制造商:宁波日昕动力科技有限公司
  • 有效期:2025/6/21 0:00:00
本公司专业提供VOLVO PENTA原厂柴油机配件,以TAD1240GE, TAD1241GE, TAD1242GE柴油机配件为例。 如需购买沃尔沃遍达柴油机配件,可以来电咨询,请提供柴油机型号、序列号及所需配件名称,如果搞不清楚,可以提供相关的照片、零件号,这样就可以准确的报价。
服务热线:配件部18874821481微信同号,整机部15706865167微信同号,售后部15888109092微信同号,技术部18374999949欢迎致电我司。
公司淘宝店铺链接https://shop144476208.taobao.com/?spm=2013.1.1000126.2.3414420fDdAANgg
AD1241GE柴油发动机燃油系统配件清单
#Part noQtyDescription
138266601Fuel hose, inlet
With return valve.
238329301Fuel hose, return
338286531Fuel hose
Radiator-overflow valve.
438286551Fuel hose
Overflow valve-fuel pump.
538286561Fuel hose
Fuel pump-fuel filter.
638286571Fuel hose
Water separator-ECU.
738286581Fuel hose
Fuel filter-inlet cylinder head.
838286591Fuel hose
Outlet cylinderhead.
99477601Flange screw
10204780641Hollow screw
-20397814
11205480121Faucet
-1330191
12251672Hollow screw
139690114Gasket
1481482441Valve
15119963Gasket
168459991Bracket
179526294Clamp
189526263Clamp
199639482Nipple
209465445Flange screw
21119962Gasket
2281483282Nipple
239454075Flange nut
249464402Flange screw
2538286101Spacer
269655372Bracket
269655403Bracket
When pre heater is mounted
279464402Flange screw
28740332Hollow screw
299655551Bracket
3038266591Bracket
31119962Gasket
32205479761Protecting cover
-656456
339570191Hexagon nut
349570181Hexagon nut
35211231932Sealing ring
369482113Cable tie
3730924601Fuel pump
SN-240248, Repl by 20440371
37
1
37204403711Fuel pump
SN240249-, Repl by 20752310
37
1
37207523101Fuel pump
SN542919-
37
1
3881702821Radiator
399469348Flange screw
4081486041Fuel filter housing
40
1
419464722Flange screw
4238302051Fuel filter housing
42
1
439467522Flange screw
4438273821Bracket
459463293Flange screw
468657372Fuel hose
479569694Ferrule
489569834Fitting nut
4938257701Fuel pipe
D=10mm
509569691Ferrule
519569831Fitting nut
5238311331Fuel pipe
D=12mm
539807821Ferrule
549569841Fitting nut
55213159971Non-return valve
56208527652Sealing ring
579910461Hollow screw
5835873221Banjo nipple
59208527642Sealing ring
609910481Hollow screw
619935841Banjo nipple
62211231932Sealing ring
638610571Fuel hose
3/8”
6438303421Hose
1/4”
659939791Hose clamp
66
1Hose clamp
679936141Banjo nipple
68213159971Non-return valve
699570821Nipple
100柴油发电机组故障报警维修 卡特彼勒4-16缸柴油机维修 柴油机消防泵技术服务有限公司 大宇柴油机吊缸修理 cat柴油机湖南省维修单位 强鹿柴油机消防泵技术服务有限公司 4008atg2帕金斯发动机修理 奥林匹亚柴油发电机组故障报警维修 奔驰MTU发电机的柴油机维修 三菱4-16缸柴油机维修 发电机维修保养 消防泵柴油机发动机维修 沃尔沃柴油机消防泵技术服务有限公司 cat柴油机吊缸修理 道依茨发电机的柴油机维修 威尔逊柴油发电机组维修 珀金斯柴油机浙江省维修单位 cat柴油机浙江省维修单位 强鹿柴油机湖南省维修单位 维修奔驰MTU柴油机的公司 perkins 发动机大修要多久时间 道依茨4-16缸柴油机维修 三菱柴油机吊缸修理 柴油机消防泵的特点与维护保养 进口发电机的柴油机维修 大宇柴油机浙江省维修单位 消防泵三菱发动机维修 三菱发电机的柴油机维修 维修约翰迪尔柴油机的公司 奔驰MTU柴油机吊缸修理 维修沃尔沃柴油机的公司 维修卡特彼勒柴油机的公司 大宇4-12缸柴油机维修 进口发动机大修要多久时间? 三菱柴油机湖南省维修单位 强鹿发动机大修要多久时间?
  • 电话:15706865167*18874821491
  • 传真:0574-26892499
  • email:18874821491@163.com
