- 型号:IC693PWR321T
- 数量:18
- 制造商:深圳长欣自动化设备有限公司
- 有效期:2020/12/12 0:00:00
信心不是天生的,是靠我们后来慢慢培养的
别人有的我们有,价格更实在,别人没有的我们也有,品质绝对保证,诚信经营,值得长期合作的好伙伴
几千万的库存,给您您想要
多家国外优良供应商,折扣大独家
拿起您的电话来购吧!!!
1734-IE2V /C 1734IE2V MFG:2013
Control Tec EVP Board
MINT Schneider Electric TM2AMI2HT Analog Input Module
SIEMENS 6SC 9321-3MA1 6SC93213MA1 BOARD
Oilgear Pump #D23030
Oilgear Pump #D15030
Oilgear Pump #D15035
Oilgear Pump #D10017
Oilgear Pump #D10025
Oilgear Pump #D6017
Oilgear Pump #D6025
Oilgear Pump #D3511
Oilgear Pump #D3511
Oilgear Pump #D3517
Oilgear Pump #D3525
Oilgear Pump #D2025
Moog Servo Valve #730-510
Moog Servo Valve #760-897A
Moog Servo Valve #760-814A
Moog Servo Valve #30-389A
Moog Servo Valve #32S020
Parker BD15 Replacement Star Valve
Atchley 415 Replacement - Star Valve
Ultra 4551 Replacement Star Valve
Lot of 40 Universal Batteries #1250
Rexroth Pressure Relief Valve #DB20-2-52/350/12
IA series Temperature Transmitter
GE PV-VL-13.8-500-2 Power Vac Circuit Breaker 1200A 5 Cycles
Reliance Electric DC Motor 37KW 4 Pole 220V with Centrifugal Fan FF-ST
IBM 7545 AML Manufacturing System Robot Assembly
Allis Chalmers MA-250A Power Circuit Breaker 4160V 1200A 60 Cycles
Mitsubishi MDS-A-CSP-450 AC Spindle Drive 3Ph 152A 200-230V 45kW 50/60Hz
Siemens SHPD69160 Circuit Breaker 1600 Amps
ITE CND63B120H Circuit Breaker 1200 Amps
Roche Cobas 372026 Integra 400 System
Indramat RAC2.3-250-460-AP0-W1 Servo Drive
Siemens SND69100ANGTH Circuit Breaker 3p 1000A 600V
GE AM-4.16-250-8C Magne Blast Circuit Breaker 4.76KV 1200A 60 Cycles
GE AM-4.16-250-9C Magne Blast Circuit Breaker 4.76KV 1200A 5 Cycles
GE AM-4.16-250-9H Magne Blast Circuit Breaker 4.76KV 1200A 5 Cycles
GE AM-13.8-500H-4 Magne Blast Circuit Breaker 13800V 1200A 60 Cycles
GE AM 2.4/4.16 150/250-3 Magne Blast Circuit Breaker 4160V 1200A
GE AM 13.8-500-3 Magne Blast Circuit Breaker 13800V 1200A 60 Cycle
GE AM-2.4/4.16 150/250-2 Magne Blast Circuit Breaker 4160V 1200A
GE AM-13.8-500-7S Magne Blast Circuit Breaker 15KV 1200V 5 Cycle
Siemens 6SN1130-1DB13 Simodrive Module
GE AM-2 4/4.16-150/250-3 Magne Blast Circuit Breaker 4160V 2000A 60 Cycle
GE AM 4.16-250-4 Magne Blast Circuit Breaker 4160V 2000A 60 Cycles
Hypertherm (Motoman) CMD-0001436 Plasma Cutting System
ABB ACS800-U1-0070-7+N650 Drive 525-690V
Allen Bradley 1326AB-B740C-S2L Servo Motor 460V 2200RPM
Siemens 6SE7027-2ED10-Z Simovert FC AC Drive
Indramat RAC2.3-250-460-APO-W1 AC Main Spindle Drive 400A 460V 60Hz
Siemens HRD63F200 Circuit Breaker 2000 Amps
Siemens 3RW4446-6BC35 Soft Start 356 Amp 600V
Nordson P7,2H,FULFILL Hot Melt System ProBlue 750/60HZ 200-240V 27A
GE TKL8S Circuit Breaker 800 Amps
GE TKL12S Circuit Breaker 1200 Amps
Ajax Tocco Magnethermic PACER-S10 Solid State Power Supply 1kHz - 10kHz
Vickers Servo Controller AC BRM45-70
Phoenix Contact IBS-IP-500-PS-2-BS Power Supply Unit 480V
Siemens 6SE7026-0ED10 Simovert FC AC Drive
Siemens 6SE7023-4EC10-Z Simovert FC AC Drive
Atlas Copco ETD S9-600-20-CTADST Electric Nutrunner Torque Wrench
PARKER C3S150V2F12 Servo Motor Drive 208-240VAC ! BNIB
Schneider MM-PMD2400C Display Panel
Allen Bradley 1326AB-C3E-11-2287B Servo Motor 3000RPM 7.5kW 310Nm
GE AM 2.1/1.16 150/250-3 Magne Blast6 Circuit Breaker 4160V 1200A
GE AM2.4/4.16 150/250-3 Magne Blast Circuit Breaker 4160V 1200A 60 Cycle
YASKAWA CACR-UIR101010FD AC Servo Drive
Mitsubishi SJ-45-BP AC Spindle Servo Motor 1150-3450RPM 37kW 200V 228A
Leybold SV65-95007 Vaccuum Pump 3.0HP 3Phase 1440-1760RPM 50/60Hz
Indramat MAC115B-0-GS-3-C/130-A-0/S001 Servo Motor
Indramat MAC115B-0-GS-3-C/130-B-0/S001 Servo Motor 66A 2000RPM
Omron FZ-305 Operator Panel 2 CAM LCD-HMI
Cutler-Hammer 55PTHX PanelMate Series 500
Marposs 3415 Thruvar 5 9246ARG Gauging Head
Kuka Type KC1 00104262 Robot Interface Controller 19-30V
Enerpac SQD-100I Square Drive Torque Wrench 7361ft-Lbs 800 Bar 11,600 PSI
Allweiler SNF940ER42-U3-W1 Screw Pump 30/247V 10 Bar
Atlas Copco ETV S9-450-20-CTADS Electric Nutrunner Torque Wrench
Atlas Copco ETD S9-450-20-CTADST Electric Nutrunner Torque Wrench
Emerson SK6405-14-2 Motor 1/10HP 1630RPM 115V 1.8A w/ MPB6905-12 Actuator !
Namco ER800-00600 Fiber Optic Cable 2 Meters
KUKA PM6-600 Servo Control 800VDC ! REFURB !
Reliance DSA-MTR-40DA-2 AC Drive DDS-TLII 40 Amp
Allen Bradley 1336F-8020-AN-EN Enclosed 1336 Plus II AC Drive 20HP 460V
Xenon COOLCUREXL-DVD Bonding System 1000W/cm2
Albany Door Systems 001197-28323/001198-28363 Safety Curtain Pairs
Control Techniques M25-14ICD Mentor II Drive 10HP
McQuay 055104401 MicroTech Open Protocol Control Board 0.40A 120V 60HZ
Siemens 3RW3472-0DC35 SIKOSTART 300HP 460VAC 361 Amp
Siemens Furnas 91TD35AFA Soft Start Controller 300/350HP 460/575V
Camco Ferguson 512RA4H40-90 Right Angle Indexing Drive
Camco Ferguson 6SFM Gear Reducer 60:1 1800rpm 1507lb-in
Camco Ferguson WBD101-1X4 Walking Beam AC Drive
Sandex 7AD-08158R-L3VW5 Indexing Drive (Alpha Series) 0-200rpm
Sandex 7AD-08277R-S3VW5 Indexing Drive (Alpha Series) 0-200rpm
Cutler Hammer 37E2908 Freedom Series 2100 Motor Control Center 500HP 3PH
Ingersoll Rand Fastener Tightening System CFM14
Fasco Coders Ink Jet Coder Bud Jet IV Ultra Mark
Joslyn Clark 5DP8-5051-11 Contactor 535Amp 500VDC
Ward Leonard 5DP8-5051-11 Contactor 535Amp 500VDC
Allen Bradley 1394C-SJT05-D Servo Controller 530/680V
Indramat MAC112D-1-FD-2-C/130-A-2/S013 Servo Motor w/ Cooling Fan Unit
Indramat MAC112D-1-FD-2-C/130-A-1 Servo Motor w/ LEM-AB112x121 Cooling Fan! RFB!
Reliance CNV-TDR-60A Converter Drive DDS-TLII 60 Amp
Reliance DSA-MTR-30A AC Drive DDS-TLII 30 Amp
Rexroth MKD071B-035-GP0-KN Servo Motor 6000RPM 6.3A
Okuma MIV06-3-VAC-H AC Drive
Kuka PM6-600 6-Axis Servo Controller
Mettler JTPA1160000 Jaguar Operator Interface Panel
ABB ACS800-U1-0020-7 AC Drive 15/20HP
Siemens 3TF6844-0CF71 Contactor 540 Amp 600V
Allen Bradley 1326AD-B1E-11-065 High Performance Rare Earth Servo Motor
Weber 5200 Printer Applicator Model-5200
Indramat RAC3.5-150-460-A-00-W1-220 Servo Drive
Fanuc A06B-0858-B100#3000 Servo Motor 3 Phase 159-215V 50/60HZ
Powis PC-6000 Industrial Oven Control
Vickers KAFDG5V833C270 Directional Pneumatic Valve
Mitsubishi FR-SF-18.5KP-C Servo Drive ! REFURB !
Allen Bradley 1394C-SJT05-L-RL Servo Controller 3Ph 380/460V
Allen Bradley 8520-CPUX1 Adapter Module 8520 Series
Proview Multisystems NF-848F Operator Panel
Atlas Copco ETV S9-370-20-CTADST Electric Nutrunner Torque Wrench
Allen Bradley 8510A-A11-A2 Drive Spindle 230V
Mitsubishi MDS-B-SP-150 AC Spindle Drive 15.0kW 58A 270-311VDC 220-230VAC
GE Fanuc IC600-LX616L Memory Module
Allen Bradley 2711-T14C9 Panelview 1400 BRAND
Bosch PE100 Analog Press Control System
Crown 30WRTL-126 30WRTL Fork Lift 24VAC 600A Max 3000Lbs Capacity
Allen Bradley 1391B-ESAA45-AQB AC Servo Control
Allen Bradley 150-F201NCD Motor Control SMCFlex 75-150HP 460V
Allen Bradley 1336F-CWF150-AN-EN AC Drive 15HP 575V
Vickers Brushless Servo Control BRM45-20
Allen Bradley 1391B-AA15-A12 Servo Controller AC 3PH 15A 220VAC 50/60Hz
SIEMENS 6FC5110-0CB01-0AA0 CPU Interface Module
Itaya Engineering SCD-5 Statistical Process Control
Honeywell TVMI-80-00-E00-A00-L10-0U0005 Recorder
Kollmorgen Servo Star SR55200-2G805C Servo Drive 230VAC, 55A, 20Kw
Eurotherm 955-8R0075 Regenerative DC Drive 3ph 230-460VAC
Allen Bradley 2711-K10C9 Operator Interface Panelview RS232
Ferraz Shawmut B093910 Fuse 50A 690VAC
Control Techniques 6M56 Mentor DC Drive 460V
AC Tech M3500B AC Drive 60HP 460v/575v
STI MS46SR-20-610-Q1-10X-10R-NC-FP Light Curtain Kit
GE Fanuc A06B-0127-B176-R 3Ph AC Servo Motor 149V 133Hz 4.6A 2000RPM 1kW
Cutler Hammer HND-65K (HND312T36W) Circuit Breaker w/ Auxiliary Switch
Wells Brookfield HADVII Viscometer 22W 115V
Electro Craft DM-100 Servo Drive BRU-500 100 Amp
Allen Bradley 1394-SJT05-T IMC-S Turbo 5Kw System Module
SAF SS6-80-C Solid State Starter OPAL Series 600V
Pilz PIPANEL-BEDIENFELD Operator Interface Panel 24VDC 50W
TR Electronics LE-200 Laser Measuring Device 18-24V 0.2-125m 2200-00402
Allen Bradley 2711P-B15C4D1 Panelview Plus 1500 Key/Touch
Oerlikon GMB01D-RML-213Z Gear Pump Turbo
ITE ND63F120 Circuit Breaker 1200 Amps
Allen Bradley 1395-A68-D1-P12-P50 DC Controller 150/240V 10/20A 3.7KW/5HP
Allen Bradley 1395-A65-D1-P12-P50-X1 DC Controller 240V 20A 5HP
NWL WB0177 Capacitor 3000kVAR 1250VAC 2400A RMS @ 3000 Hz
Almex Kwikweld A6-18 (1079-367) 50 PSI 110V 3Amp
Ingersoll Rand QM9SS650H62S16 EC Fixtured Spring Loaded Torque Spindle
Ingersoll Rand QE8AE115RA6S08 Angle Electric Nutrunner Torque Wrench
Yaskawa CACR-SR 30SB1BFY118 Servo Controller
SKF 71934 CDGA/P4A Percision Bearing
Amatek Gemco 1995-A6MPX Micro Set PLS
Allen Bradley 440L-R4D1200-N Light Curtain
ABB SACE-E2B/E-1600 EMAX Power Breaker 1600A 400VAC
Siemens 6SE3121-1FG40 AC Drive MIDI Master 10HP 575V
Allen Bradley 2711-K9A5 Panel View 110V 50/60HZ .85A
Hardy Instruments HI-1756-2WS Weigh Scale Module 1756-2WS
ALLEN-BRADLEY 6181P-15TPXPH VersaView 1500P
LUST DriveTronics Servo Motor FIP 21/0085-30 AC2
Control Techniques 6M15 Relcon DC Drive 440V
Control Techniques M45-14ICD Mentor II Drive 20HP
Honeywell 2000-200-150-126-015-00 Herculine Actuator
- 电话:13306006594
- 传真:0755-27801689
- email:3007542108@qq.com
