- 型号:20440371
- 数量:10000
- 制造商:宁波日昕动力科技有限公司
- 有效期:2021/3/1 0:00:00
VOLVO沃尔沃发电机服务中心 为客户提供专业的沃尔沃发电机、柴油发动机、船用发动机检查、维修保养服务。 提供原厂沃尔沃发电机配件、三滤 服务电话:18874821491微信同号,QQ:3100095627
10000# Part no Qty Description 1 3826660 1 Fuel hose, inlet With return valve. 2 3832930 1 Fuel hose, return 3 3828653 1 Fuel hose Radiator-overflow valve. 4 3828655 1 Fuel hose Overflow valve-fuel pump. 5 3828656 1 Fuel hose Fuel pump-fuel filter. 6 3828657 1 Fuel hose Water separator-ECU. 7 3828658 1 Fuel hose Fuel filter-inlet cylinder head. 8 3828659 1 Fuel hose Outlet cylinderhead. 9 947760 1 Flange screw 10 20478064 1 Hollow screw -20397814 11 20548012 1 Faucet -1330191 12 25167 2 Hollow screw 13 969011 4 Gasket 14 8148244 1 Valve 15 11996 3 Gasket 16 845999 1 Bracket 17 952629 4 Clamp 18 952626 3 Clamp 19 963948 2 Nipple 20 946544 5 Flange screw 21 11996 2 Gasket 22 8148328 2 Nipple 23 945407 5 Flange nut 24 946440 2 Flange screw 25 3828610 1 Spacer 26 965537 2 Bracket 26 965540 3 Bracket When pre heater is mounted 27 946440 2 Flange screw 28 74033 2 Hollow screw 29 965555 1 Bracket 30 3826659 1 Bracket 31 11996 2 Gasket 32 20547976 1 Protecting cover -656456 33 957019 1 Hexagon nut 34 957018 1 Hexagon nut 35 21123193 2 Sealing ring 36 948211 3 Cable tie 37 3092460 1 Fuel pump SN-240248, Repl by 20440371 37 1 37 20440371 1 Fuel pump SN240249-, Repl by 20752310 37 1 37 20752310 1 Fuel pump SN542919- 37 1 38 8170282 1 Radiator 39 946934 8 Flange screw 40 8148604 1 Fuel filter housing 40 1 41 946472 2 Flange screw 42 3830205 1 Fuel filter housing 42 1 43 946752 2 Flange screw 44 3827382 1 Bracket 45 946329 3 Flange screw 46 865737 2 Fuel hose 47 956969 4 Ferrule 48 956983 4 Fitting nut 49 3825770 1 Fuel pipe D=10mm 50 956969 1 Ferrule 51 956983 1 Fitting nut 52 3831133 1 Fuel pipe D=12mm 53 980782 1 Ferrule 54 956984 1 Fitting nut 55 21315997 1 Non-return valve 56 20852765 2 Sealing ring 57 991046 1 Hollow screw 58 3587322 1 Banjo nipple 59 20852764 2 Sealing ring 60 991048 1 Hollow screw 61 993584 1 Banjo nipple 62 21123193 2 Sealing ring 63 861057 1 Fuel hose 3/8” 64 3830342 1 Hose 1/4” 65 993979 1 Hose clamp 66 1 Hose clamp 67 993614 1 Banjo nipple 68 21315997 1 Non-return valve 69 957082 1 Nipple
- 电话:15706865167*18874821491
- 传真:0574-26892499
- email:18874821491@163.com
