- 型号:CV19386/Z
- 数量:10000
- 制造商:宁波日昕动力科技有限公司
- 有效期:2025/6/21 0:00:00
宁波日昕提供免费的发动机技术支持,perkins全系列机型原厂配件,机器故障在线解答,欢迎来电,
产品型号:
SEV644C/1 | GASKET |
SE478F | SEAL - ROCKER BOX COVER |
494/130 | GASKET |
680/150 | ACTUATOR |
554/118 | SEAL - O RING |
509/118 | SOLENOID |
680/59 | POTENTIOMETER |
680/124 | PICKUP |
879/39 | PRIMING PUMP |
SE429B/4 | FUEL FILTER |
331/275 | GASKET |
331/266 | GASKET |
282/315 | GASKET - OIL FILTER |
282/301 | GASKET - OIL FILTER |
282/299 | GASKET |
283/107 | GASKET - WATER CONNECTION |
341/180 | GASKET - WATER CONNECTION |
422/8 | HOSE |
422/8 | HOSE |
576/181 | SEAL - O RING |
278/376 | GASKET |
278/386 | GASKET |
576/176 | SEAL - O RING |
860/296 | RELIEF VALVE |
278/392 | GASKET |
576/175 | SEAL - O RING |
782/52 | PRESSURE SWITCH |
576/173 | SEAL - O RING |
576/217 | SEAL - O RING |
551/777 | CLAMP |
417/57 | SLEEVE |
590S/320 | ELBOW |
SEV111A/36 | GASKET - OIL FILTER |
SEV111A/23 | OIL FILTER HEAD |
278/394 | GASKET |
SE11B | LUBE OIL FILTER |
SEV145H | WATER PUMP KIT |
SEV145A/42 | GASKET WATER PUMP |
576/199 | SEAL - WATER OUTLET |
422/6 | HOSE |
525/19M | HOSE CLIP |
576/205 | O RING |
278/399 | GASKET |
T401877 | SEAL |
T401878 | SEAL |
SE573C/3 | GASKET - THERMOSTAT HSG |
782/176 | SWITCH |
T402103 | THERMOSTAT |
T422038 | SEAL - O RING |
283/112 | GASKET - TURBOCHARGER |
Check History | SEAL - O RING |
SE597C/7 | GASKET - LIFT PUMP |
278/389 | GASKET |
576/158 | SEAL - O RING |
278/393 | GASKET |
278/394 | GASKET |
576/184 | SEAL - O RING |
283/108 | GASKET - OIL COOLER |
576/128 | SEAL - O RING |
SEV145A/42 | GASKET - WATER PUMP |
554/117 | SEAL - O RING |
278/390 | GASKET |
554/101 | SEAL - OIL |
SE116C/5 | GASKET |
283/119 | GASKET - INTAKE MANIFOLD |
419/600 | HOSE |
525/62 | HOSE CLIP |
419/485 | HOSE |
525/40 | HOSE CLIP |
282/296 | GASKET - EXHAUST MANIFOLD |
341/189 | GASKET - EXHAUST |
419/603 | HOSE |
525/27M | HOSE CLIP |
819/483 | CLAMP |
331/284 | GASKET - AIR PIPE |
763/333 | BELLOWS |
551/675 | CLAMP |
541/422-197 | FAN BELT |
702/184 | CHARGING ALTERNATOR |
701/137 | SELF MOTOR |
589/83 | RELAY |
589/86 | SOLENOID |
589/91 | SOLENOID |
838/14 | PICKUP |
- 电话:15706865167*18874821491
- 传真:0574-26892499
- email:18874821491@163.com
