- 型号:2418F47
- 数量:10000
- 制造商:宁波日昕动力科技有限公司
- 有效期:2021/4/17 0:00:00
三菱Mitsub珀金斯Perkins柴油发电机/发动机浙江代理商,销售维修保养及零部件服务。
T408129 BRACKET
T408143 GASKET
T408147 BRACKET ASSY.
T408148 WIRING HARNESS
T408157 CLIP
T408160 CLIP
T408162 WIRING HARNESS
T408169 AIR HOSE
T408185 BRACKET ASSY.
T408187 HOSE
T408188 PIPE
T408200 OIL FILTER HEAD
T408214 BRACKET ASSY.
T408218 FLYWHEEL ASSY.
T408220 EXHAUST PIPE
T408222 FUEL HOSE
T408223 BRACKET
T408224 CLIP
T408225 CLIP
T408229 PIPE,AIR
T408231 ADAPTOR
T408237 BRACKET
T408238 HOSE
T408239 MOUNT
T408243 HOSE
T408249 CLIP
T408250 CLIP
T408251 MOUNT
T408256 WASHER
T408257 EXHAUST MANIFOL
T408258 EXHAUST MANIFOL
T408260 EXHAUST MANIFOL
T408264 EXHAUST ASSY
T408310 GASKET
T408342 CYL.HEAD COVER
T408349 FLYWHEEL HOUSIN
T408352 PIPE
T408354 PIPE,TURBO
T408360 RELIEF VALVE
T408363 PIPE CLIP
T408386 SUMP
T408387 SUMP
T408395 PIPE,TURBO
T408397 PIPE,TURBO
T408398 SUMP
T408402 SUMP
T408405 PIPE,TURBO
T408407 PIPE,AIR
T408410 PIPE,TURBO
T408411 ADAPTOR ASSY
T408416 SEAL
T408420 PIPE,BREATHER
T408424 GASKET
T408425 BRACKET ASSY.
T408427 BRACKET
T408431 BRACKET ASSY.
T408434 TURBOCHARGER
T408435 EXHAUST ASSY
T408436 EXHAUST ASSY
T408437 CONNECTION
T408439 HOSE
T408457 WIRING HARNESS
T408459 EXHAUST ASSY
T408465 BOLT
T408467 PIPE,BREATHER
T408469 EXHAUST PIPE
T408470 EXHAUST PIPE
T408473 PIPE
T408475 BRACKET ASSY.
T408476 PIPE
FUEL FILTER 柴油格 26560141 1
OIL FILTER 機油格 2654403 1
FAN BELT 風扇皮帶 2614B665 1
NTAKE HEATER 發熱器 2666A018 1
THERMOSTAT 水膽 4133L054 1
ROCKER COVER JOINT 上蓋墊片 3681A054 1
B.主要大修件
FRONT OIL SEAL 前油封 2418F437 1
REAR OIL SEAL 后油封 2418F475 1
REAR OIL SEAL 后油封 2418F701 1
KIT,TOP OHAUL 上部修理包 U5LT0349 1
KIT,BTM OHAUL 下部修理包 U5LB0370 1
INLET VALVE 進氣門 3142L081 6
VALVE EXHAUST 排氣門 3142D031 6
GUIDE INLET 進氣門導管 3313A012 6
GUIDE EXHAUST 排氣門導管 3318A705 6
INSERT INLET 進氣門座環 3314A141 6
INSERT EXHAUST 排氣門座環 3314A131 6
OUTER SPRING 彈弓 3174P409 12
VALVE SPRING CAP 彈弓塞 3342N011 12
VALVE SPRING COTTER 鎖片 33173108 12
OIL COOLER JET 冷卻噴咀 3861A027 6
VALVE SPRING COTTER 鎖片 3142W004 24
PISTON,KIT 活塞 4115P001 6
RING KIT 活塞環 UPRK0001 6
LINERS 缸套 3135X062 6
BEARINGS,BIG END STD 連杆瓦 U5ME0013 1
BEARINGS, BIG ENG STD 連杆瓦 U5ME0014 1
BEARINGS, BIG ENG STD 連杆瓦 U5ME0014A 1
BUSH SMALL END 杯士 3112A005 6
BEARINGS, MAIN STD 主軸瓦(U5MB0010) U5MB0022 1
BEARINGS, MAIN STD 主軸瓦 U5MB0010A 1
THRUST WASHER 止推片 31137551 2
THRUST WASHER 止推片 31137561 2
PUSH ROD 推杆 31434307 12
B.主要大修件
TAPPET 活門襯筒(3142U031) 3142U991 12
KIT REPAIR, TURBO 增壓器修理包 26741060 1
LIFT PUMP 手搖泵 ULPK0036 1
OIL COOLER 冷卻器總承 2486A993 1
INJECTOR 噴油咀總承 2645F027 6
WATER PUMP 水泵總承 U5MW0196 1
ROCKER ARM 搖臂 4115R311 6
ROCKER ARM 搖臂 4115R309 6
ROCKER ARM 搖臂 4115R306 6
LUB OIL PUMP 機油泵 4132F067 1
ALTERNATOR 充電機 2871A141 1
ALTERNATOR 充電機(2871A003) 2871A502 1
ALTERNATOR 充電機 2871A702 1
STARTER MOTOR 起動馬達(2873B071) 2873A030 1
STARTER MOTOR 起動馬達 2873D304 1
STARTER MOTOR 起動馬達 2873K406 1
TURBOCHARGER 增壓器總承 2674A080 1
TURBOCHARGER 增壓器總承 2674A346 1
FUEL INJECTION PUMP 高壓油泵 2643U607 1
FUEL INJECTION PUMP 高壓油泵 2644P501 1
KIT,CONROD 連杆 4115C331 6
KIT,CONROD 連杆 4115C312 6
KIT,CONROD 連杆 4115C315 6
(1)英国Perkins发动机零部件销售 我公司常备有PERKINS各系列常用配件:
(100,200/300,400,500,700/800,900/3.152,1000/4.236,6.354,540/640,1100,1300,2000/3000,2300,2500,2800,4000等系列)机油格(机油滤清器)、柴油格(柴油滤清器)、风格(空气滤清器)、水格、冷却液(防锈水)、风扇皮带、充电机皮带、上修包、下修包、连杆瓦、主轴瓦、止推片、充电机、起动马达、活塞(含活塞销)、活塞环、缸套、缸套胶圈(四配套)、中缸总成、气门 、气门导管、气门座圈、连杆、曲轴、风扇叶、前油封、后油封、气门油封、机油冷却喷咀、机油冷却器、摇臂轴、增压器总成、增压器修理包、机油泵总成、高压油泵、水泵总成、水泵轴、手摇泵、喷油咀、喷油咀铜套、喷油咀胶圈、冷却器总承、柴油冷却器、机油压力感应器、水温感应器………
(2)英国Perkins机组专业的维修保养
工程部是我司主要经营项目之一,也是公司多年来的支柱产业,主要对Perkins品牌各种型号的发电机组、船舶、车辆、工业用发动机进行专业的大、中、小维修保养、技术支持,及相配备的机房消音、自动并机柜、转换柜等工程。在专业发电机组、工程机械维修行业迄今已有多年的历程。配备有完善的PERKINS发动机(及相配的机组)维修工具及检测设备。为用户提供高质量、高效率的维修服务。
(3)电机组及船用机组整机销售
1、销售纯进口发电机组(功率从10KW到2000KW);
2、根据客户特殊要求安装、改造高性能自动化发电机组;
3、提供不同要求的发电机组(包括:流动型电站、防音型电站、无人值守电站等),各项产品广泛运用于工厂厂房、邮政、电信运营、铁路、油田、煤矿及商场大厦等场所。
- 电话:15706865167*18874821491
- 传真:0574-26892499
- email:18874821491@163.com
下一篇:HA-2940U2W直销
