未来属于IP协议
2008/3/3 10:23:00
The future belongs to the IP protocol 未来属于IP协议 From automotive manufacturers to motorway operators – fibre optic networks everywhere 光纤网络应用于各个领域----从汽车制造商到高速公路营运者 With the typical data applications, the IP protocol has long left the office environment and is in the process of conquering all other areas of application. Industrial Ethernet has now become a firmly established term that describes the use of Ethernet-based components with high reliability in tough environments. 与普通的数据应用一起,IP协议早已应用于办公室的环境,并正在迅速进入其他所有领域的应用。工业以太网已经是一个既定的术语,它描述了在恶劣环境中使用基于以太网的组成元件,具有高度可靠性。 In addition to typical production environments, this technology is also successfully used in the traffic control area, in monitoring and signalisation systems as well as in the energy sector. A current application focus is control and monitoring in the traffic and transport sectors, where (in addition to high availability) large bandwidths are also required. 除典型的生产环境外,该技术也应用于交通控制的监控和信号系统,以及能源部门。其中当前的重点区域是交通和运输部门的控制和监控应用,在这些应用里(除了高可用性),需要高带宽。 Motorway operator ASF needs high-quality products 高速公路经营者ASF需要高质量的产品 Autoroutes du Sud de la France As the largest French motorway operator, the ASF Group (Autoroutes du Sud de la France) has put its faith for years in the proven hardware components of MICROSENS. ASF, which belongs to the Vinci Group, finances, builds and operates the largest French motorway network, which leads to the most important economic region and one of the most important tourism destinations in Europe. These include, among others, the motorways in the South of France, the Estérel/Côte dAzur/Provence/Alps (ESCOTA) motorways and the operating company Cofiroute. 作为法国最大的高速公路经营者ASF Group (Autoroutes du Sud de la France),多年来一直信任MICROSENS的硬件组件。 ASF属于Vinci Group,它提供经费来建造和运营法国最大的高速公路交通网络,从而使其成为欧洲最重要的经济区域,以及旅行的最重要目的地。该网络包括法国南部的高速公路,还包括Estérel/Côte dAzur/Provence/Alps (ESCOTA)高速公路,以及营业公司Cofiroute。 This motorway network is more than 3,100 km long and connects France to Spain, Italy and Northern Europe. With an average traffic volume of more than 30,000 vehicles per day, the optimum safety of the traffic participants represents a major challenge for the operators. This can only be ensured with the help of reliable, future-proof, environmentally compatible and neighbourhood-friendly infrastructures. 该高速公路网络长达3100km,将法国与西班牙、意大利和北欧连接起来。每天要维护大概30000多辆车,对于操作者来说,交通参与者的安全是一个最大的挑战。要达到这一目标,必须要有可靠的、有将来保证的、适应环境的,并且友好的基础设施。 To master all these challenges, the ASF Group is relying on high-quality products and technology partnerships. Together with the competent integration partners, the companies Aneto and Telindus, various large-scale projects have been successfully realised with the ASF Group. 为了应付所有的挑战,ASF Group依靠高质量的产品和技术合作伙伴。加上Aneto和Telindus作为主管集成的合作伙伴。ASF Group顺利完成了各种大型项。 Large-scale project for toll stations 大收费站工程 During the large-scale project for toll stations, solutions from MICROSENS were used across a wide area. Originally, many toll stations were only equipped with PCs. In the course of the modernisation of the stations and of many new investments, the services of these have been substantially expanded over the last few years. In addition to typical control data for the access barriers that are connected directly via fibre optic converters, the till machines and the video cameras were also connected to the IP network. In one of the next stages of development, the additional connection of the voice services via VoIP telephony is planned. MICROSENS解决方案在大收费站工程里被广泛使用。原来许多的收费站只配备的有PCs。在将车站现代化的过程中,作出了许多新的投资,它们的服务在过去几年里已有明显扩大。除了通过光纤转换器直接连接的访问壁垒的典型数据控制,现金机及摄像机也被连接到IP网络。下一个扩张阶段的其中之一是用VoIP集成语音服务。 Special Fast Ethernet industry switches 特殊的快速以太网工业交换机 Special Fast Ethernet industry switches with fibre optic connection are used and these are superbly suited to the tough environment, thanks to their robust design. 特殊的快速以太网工业交换机是用光纤连接的。由于他们精湛的设计,使它们特别适合高速公路恶劣的环境。 The systems are desired for top-hat rail assembly and are installed directly in the electric distributors. 该装置可以安装在DIN rails上,并直接安装在电力分配器。 As part of the connection of numerous toll stations, a quick-reacting and dedicated network structure was established. Through specific traffic management and control, a high level of safety is ensured 7 days a week at any time of day or night. The entire ASF network is divided into 36 areas, whereby each sub-area covers between 50 and 120 km of motorways and is connected via a ring structure to the seven regional administration centres (D.R.E. Valence, Orange, Narbonne, Biarritz, Agen, Brive and Niort). In turn, these regional centres ensure global network coordination and are networked with the main control and service centres of the ASF in Valencia. 作为无数收费站连接的一部份,一个快速反应的、专用的网络结构被建立起来。针对特殊的交通管理和控制,并确保每周7天任何时候的安全的高度控制,ASF的整个网络被分为36段。每段覆盖50至120公里的高速公路,并通过环形结构连接到七个区域行政中心(D.R.E. Valence, Orange, Narbonne, Biarritz, Agen, Brive and Niort)。这些区域中心确保全球网络的协调,并用网络连接保证了Vedène的ASF中心的主要控制和服务。 Modular MICROSENS system 有标准组件的MICROSENS系统 To guarantee smooth data transmission over such great distances, only fibre optic can be considered as a suitable data transmission medium. Due to the constant expansion of the network structures, the operators were looking for an open transmission platform. The modular system of MICROSENS with its broad variety of electro-optical converters was able to fulfill all these parameters. The data of the regional administration centres was thus networked with the main centre optically via Gigabit Ethernet fibre optic converters. 为确保无故障数据传输可以在远距离上访问,光纤是唯一合适的数据传输媒介。由于网络结构的不断扩大,其经营者需要有一个开放的传输平台。MICROSENS提供的有标准组件的系统,因其不同种类的电光转换器,满足了所有的参数要求。整个管理区域的数据是用千兆以太网光纤转换器与主控中心联网的。 Thanks to the comprehensive product line from MICROSENS, the ASF Group could also draw on the competence of the German manufacturer for a completely different project, as part of the long-range connections. In the linking up of the two cities of Agen and Avignon, the task was to enable transmission of high data rates in the Gigabit range over a distance of approx. 470 km. It was possible to realise this successfully with the help of special transponders with signal regeneration, combined with optimised active optical technologies. The solutions used by ASF for the optical data transfer are used as standard by many European telecommunication suppliers. 多亏MICROSENS全面的产品系列,ASF Group才能依靠德国制造商的能力,在一个完全不同的项目范围里,建立长期的远程连接。连接Agen和Avignon两地,并在约470公里的距离内建立千兆范围内的高数据率的数据传输。在有信号再生功能的特别收发器帮助下,可以 成功实现与优化动态光学技术的结合。ASF实施的、用于数据传输的解决方案通常被许多的欧洲通讯供应商使用。 PSA Peugeot Citroën In addition to
