赫优讯紧凑型IOT边缘网关使用指导手册
Content
Industrial Raspberry Pi ............................................................................................. 6
Industrial Raspberry Pi Variants .......................................................................... 6
Docker ......................................................................................................... 7
Thing‐Editor Node‐RED ......................................................................................... 8
Device Management netFIELD.io ............................................................................. 9
Industrial IoT Communication MQTT .............................................................. 10
Industrial IoT Communication OPC UA ............................................................. 10
1. Real‐Time Ethernet to OPC UA ............................................................. 11
2. Modbus TCP to OPC UA .......................................................................... 12
3. Modbus RTU to OPC UA .......................................................................... 13
4. Serial protocol to OPC UA ................................................................... 14
5. CAN to OPC UA .................................................................................. 15
6. Real‐Time Ethernet to MQTT ................................................................... 16
7. Modbus TCP to MQTT ....................................................................... 17
8. Modbus RTU to MQTT ..................................................................... 18
9. Serial protocol to MQTT ........................................................................ 19
10. CAN to MQTT ............................................................................ 20
11. Real‐Time Ethernet to serial protocol .............................................. 21
12. Real‐Time Ethernet C software example ................................... 22
13. CANopen C software example ............................................ 23
14. Raspian ............................................................... 24
15. Soft SPS (CODESYS) ................................................ 25
16. Mini Box PC ............................................................ 26
17. Visualizing with Grafana ........................................................ 27
18. Visualizing with Node‐RED ........................................................... 28
19. Data logger ............................................................................ 29
20. Data base ............................................................................... 30
21. IBM Cloud ‐ IoT Platform ............................................................... 31
22. Microsoft Azure ‐ IoT Hub ................................................................... 32
23. Bluetooth ........................................................................................ 33
24. TeamViewer ........................................................................................ 34
25. S7‐Communication ................................................................................... 35
26. ADS‐Communication ................................................................................... 36
27. Notification through email / text / WhatsApp / signal lamp ............................. 37
28. Web server ................................................................................. 38
29. Website ............................................................................................. 39
30. JavaScript .............................................................. 40
31. Python ...................................................................................................... 41
32. Machine Learning ...................................................................... 42
IIoT training environment «Mylivezone» ...................................................................... 43
Available IIoT‐Exercises at the «Mylivezone» training platform ........................ 44
Order reference codes .................................................................. 45
Contacts ...................................................................................................... 47
案例详细介绍,请点击下方链接获取:
http://customer.gongkong.com/2020/赫优讯紧凑型IOT边缘网关使用指导手册.pdf
用于关键应用的互联驱动技术
工业网络环境中的OPC UA
德国赫优讯推出M.2格式的工业计算机主从通讯卡
通过被动式EtherCAT网络数据挖掘增加物联网价值
赫优讯工业网络接口获得国际协议组织新认证
