新品速递
HORNER公司的新I/O上市
HORNER公司的新I/O上市
——— SmartRail万能I/O
 HORNER公司的新I/O——SmartRail万能I/O上市。
The SmartRail I/O System is Horner’s newest I/O offering.  SmartRail is compact – but highly expandable and scalable.  Start with an Ethernet Base with a built-in two port switch.  Continue by adding I/O modules of your choice that easily snap together.  Each base can hold up to 8 I/O modules, for a total of up to 256 digital and 32 analog points.  Now just daisy-chain as many additional bases that are needed to complete the application – up to a total of 2048 digital and 512 analog I/O.  Software configuration is a snap as well – just plug-and-play using Cscape 9.1. (Cscape 9.1 to be released at the end of March.)
Digital I/O is available in 8, 16, and 32 point modules – with DC (in and out) and Relay options. For the 32 point modules – SmartLink Wiring Accessories make the multitude of terminations neat and compact. Analog I/O selection is extensive – with modules for 0-10V, 4-20mA, Thermocouples, and RTDs.  These are offered as 4 channel Input only, Input/Output, and Output only models.
When it comes to network connectivity – SmartRail is flexible.  The SmartRail Ethernet I/O Base is one of three offerings, along with CsCAN (summer 2010) and Profibus DP.  This allows it to work great with OCS, or even with third party controllers.
I/O Expansion Using Multiple Bases
SmartLink Terminal Strip and Expansion Cable (for 32 point I/O)
SmartLink Relay Strip and Expansion Cable (for 32 point I/O)
HORNER OCS在RTG混合动力改造中的应用
浩纳尔X系列HE-X2 OCS
HORNER一体化控制器 SmartMod中文数据手册
HORNER一体化控制器 XL系列控制器
HORNER一体化控制器 CX中文数据手册
