horner推出RX371 Ruggedized Controller
2010/5/5 17:40:00
horner推出RX371 Ruggedized Controller。
Specifications
Display Type (LCD with Backlight) | 5.7" QVGA TFT w/32,000 colors. 700 NIT |
Display Screen Dimensions | 320 x 240 pixels |
Display Memory | 2.75 MB |
User Keys | 5 user-defined Function Keys and 1 System Key designed for 30 Million + operations |
Number of Screens Supported | 1023 |
Serial Ports | 2 Serial Ports, RS-232/RS-485 |
SmartStack Support | Up to (4) metal SmartStacks directly on back |
SmartStix Support | Yes |
Ethernet | 10/100 MBPS Ethernet |
Removable Media | MicroSD® Storage up to 2 GB |
USB A Connector | Support for USB Flash Drives |
USB Mini B Connector | Programming Port |
Temperature Range | -30° to 60° C |
Approvals | CE, UL and C-UL pending |
Environmental | NEMA 4X and IP66 |
Impact Rating | Exceeds requirements for IK7 |
Height | 5.964" (151.49mm) |
Width | 7.682" (195.12mm) |
Depth | 2.425" (61.60mm) |
Weight | 54 oz (1.53kg) |
Horner Part Number | HE-RX371 |
HORNER OCS在RTG混合动力改造中的应用
浩纳尔X系列HE-X2 OCS
HORNER一体化控制器 SmartMod中文数据手册
HORNER一体化控制器 XL系列控制器
HORNER一体化控制器 CX中文数据手册
