SmartRail系列
——— 种类丰富的I/O扩展模块
SmartRail系列I/O扩展模块,以太网连接,速度快,种类丰富。
Part Number Description
  SmartRail Bases
HE599ETX200 Ethernet Base.  Compatible with XL6e, NX221/251, QX, RX, RCX.  Features built-in unmanaged switch.  Supports up to 8 I/O modules drawing up to 1.5A @ 5Vdc.  Supports up to 256 digital and 32 analog I/O per base.  Requires Cscape 9.1, and Firmware 12.70.
HE599CNX100 CsCAN Base.  Compatible with XLe, XLt, XL6, XL6m, XL6e, NX, QX, RX, RCX.  Projected Availability Summer 2010.
HE599PBX100 Profibus Base.  Requires a Profibus Master, such as the SmartStack PBM650 module. Supports up to 8 I/O modules drawing up to 1.5A @ 5Vdc.  Supports up to 256 digital and 16 analog I/O per base.
  SmartRail Ethernet cables
HE599CBEnnn
(nnn=length)
 Available in 1, 2, 3, 6, 10, 15, 30 & 50 foot lengths (ie HE599CBE001 = 1 foot cable)
  Digital Input Modules
HE599DIM510 8 DC Inputs (24vdc pos/neg logic).
HE599DIM610 16 DC Inputs (24vdc pos/neg logic).
HE599DIM710 32 DC Inputs (24vdc pos/neg logic).  SmartLink Expansion Cable and Terminal Strip recommended.
I/O Expansion Using Multiple Bases
SmartLink Terminal Strip and Expansion Cable (for 32 point I/O)
SmartLink Relay Strip and Expansion Cable (for 32 point I/O)
HORNER OCS在RTG混合动力改造中的应用
浩纳尔X系列HE-X2 OCS
HORNER一体化控制器 SmartMod中文数据手册
HORNER一体化控制器 XL系列控制器
HORNER一体化控制器 CX中文数据手册
