infoteam OpenPCS v6.6.4 震撼发行
infoteam OpenPCS v6.6.4震撼发行。现在我们有德语和中文简体两种语言版本。
此版本的新特性:
Fixed CRQs
2012/0061 | Error not displayed at the end of build log |
Some errors are not considered the sum of error | |
2012/0059 | Ordering logic for FB categories |
FB categories are ordered in alphabetial order | |
2012/0050 | Build faild after a direct global file is moved to sub folder |
Build now recognizes the moved fiel | |
2012/0047 | Library files not included after upload from PLC |
Library files are inculuded in upload if option is selected | |
2012/0045 | Error in online change |
Changing only initial values has lead to default values for the whole segment | |
2012/0039 | Some function block help files are missing |
Links to the help pages in openpcs.xml are now included | |
2012/0035 | Chinese comments in LD instructions |
Chinese comments are displayed correct | |
2012/0029 | SoftPLC task crash because of too many segments |
The number of segments is chechked and an error is thrown | |
2012/0027 | Program global FBs do not work |
Function block decalred in program global section now work | |
2012/0023 | Error reading hardware file in 663 |
In some cases error messages have been entries were in english | |
2012/0012 | Wrong language in context menu |
In German OpenPCS some context menu entries were in english | |
2012/0007 | Address as variable name is watchlist |
Using direct address as watch variable is working again | |
2012/0003 | Pass wrong parameter type before function block call |
The error message was improved |
新发版本链接如下:
· Release notes: http://www.infoteam.de/downloads/login/openpcs66/ps/OpenPCS_664_ReleaseNotes.pdf
· German version: http://www.infoteam.de/downloads/shared/PS664d.exe
· Chinese version: http://www.infoteam.de/downloads/shared/PS664cs.exe
一方梯队软件(北京)有限公司迁址通知
医疗器械软件技术标准研讨会圆满落幕
一方梯队 OpenPCS 冗余系统
一方梯队软件“2015中国安全技术日”圆满落幕
一方梯队“2015中国安全技术日”如期与您见面
