业界动态
ABB斩获FMG集团铁桥磁铁矿项目2600万美元订单
Order includes ABB water-cooled variable speed drives and high voltage induction motors that will deliver industry-leading energy efficiency.
订单包含高效的ABB水冷变频器和高压感应电机
The Iron Bridge Magnetite Project, an unincorporated joint venture between Fortescue’s subsidiary FMG Magnetite Pty Ltd and Formosa Steel IB (Iron Bridge Joint Venture), covers the development of a new magnetite mine, including processing and transport facilities. Located in the Pilbara region of Western Australia, the mine is expected to produce 22 million wet tonnes per annum of high grade, magnetite concentrate used for steel production.
铁桥磁铁矿项目由FMG集团子公司FMG磁铁矿公司 (FMG Magnetite Pty Ltd) 与合资伙伴Formosa Steel IB共同运营,业务涉及包括加工和运输等基础设施在内的新磁铁矿开发。该矿位于西澳皮尔巴拉地区,预计年产2200万吨高质量磁铁精矿,这些精矿可以用于钢铁生产。
As part of the project, the Iron Bridge Joint Venture require a cost-effective energy efficient variable speed drive solution. These drives, to be installed in eight switch rooms, operate with a separate transformer that is located outside the room. This reduces the heat generated inside, resulting in less energy required to maintain the 25°C room temperature.
该项目需要一种经济高效的节能控制方案。这些变频器被分别安装到八个电气室,与室外的独立变压器配合运行。该方案可以减少室内产生的热量,从而降低为维持25°C室温所需的能耗。
ABB’s water-cooled drives also directly support a higher voltage 33kV network.  This eliminates the need for a lower voltage intermediate switchboard and additional components, which ultimately reduces the total cost of the project.
ABB水冷变频器可直接接入电压高达33kV的电网,无需安装低压开关柜,大大降低了项目总投资。
Iron Bridge also selected ABB high voltage induction motors to power high pressure grinding rolls, grinding mills and baghouse fans used to separate the ore from the dust. Engineered to withstand harsh conditions, the motors offer high power efficiency, but in a frame size smaller than competitive alternatives. With a compact footprint, these motors are energy efficient, save space and require less structural foundation.
该项目还选用了ABB高压感应电机为高压辊磨机、破碎机和去除矿石上粉尘的袋式除尘器提供动力。这些电机不仅能够适应恶劣工况,而且拥有比同等竞品更小的外形尺寸和更高的输出功率。这种紧凑的结构设计能帮助客户节省现场空间,提高能效,降低对安装基础的要求。
“We have worked closely with the Iron Bridge team to ensure that we delivered an energy efficient, reliable and innovative solution,” said Mike Briggs, Business Manager for ABB Motion, Australia. “We are especially pleased to have won both the drive and the motor business and look forward to continuing our strong relationship with Fortescue beyond the delivery of this project and supporting them throughout the mine’s lifecycle.”
“我们与铁桥项目团队紧密协作,确保我们为客户提供节能、可靠和创新的解决方案,”澳大利亚ABB 运动控制业务经理Mike Briggs表示:“我们很荣幸能斩获该项目的变频器和电机业务,也期待在项目交付后继续与Fortescue建立牢固的合作关系,并在矿山开发的整个生命周期中为他们提供支持。”
Fortescue is one of the world’s largest iron ore producers. The $2.6 billion project is expected to be completed in the first half of 2022.
Fortescue是全球最大的铁矿石生产商之一。铁桥磁铁矿项目耗资26亿美元,预计在2022年上半年投产。
ABB (ABBN: SIX Swiss Ex) is a leading global technology company that energizes the transformation of society and industry to achieve a more productive, sustainable future. By connecting software to its electrification, robotics, automation and motion portfolio, ABB pushes the boundaries of technology to drive performance to new levels. With a history of excellence stretching back more than 130 years, ABB’s success is driven by about 110,000 talented employees in over 100 countries. www.abb.com
ABB(ABBN:SIX Swiss Ex)是全球技术领导企业,致力于推动社会和行业转型,实现更高效、可持续的未来。ABB 通过软件将智能技术集成到电气、机器人、自动化、运动控制产品及解决方案,不断拓展技术疆界,提升绩效至新高度。ABB拥有130多年的卓越历史,业务遍布全球100多个国家和地区,员工人数达11万。www.abb.com
ABB ACS180变频器为污泥脱水机提供高性价比解决方案
ACS880LC液冷变频器在新能源拖船的应用
从农场到餐桌,ABB解决方案助力全面推动绿色大棚养殖业发展
ABB ACS800服务解决方案,为您的设备稳定运行保驾护航
ABB PLC 和传动产品助力减少食品浪费
