凯迪恩 编程软件EasyProg英文版
2006/5/24 8:55:00
EasyProg - The Programming Software for KDN-K3 series PLC
产品分类:PLC 中型PLC
品牌:凯迪恩
EasyProg is the programming software for KDN-K3 series micro PLC, and it is a user-friendly and high-efficient development system with powerful functions. EasyProg is developed independently and accords with the IEC61131-3 standard.
EasyProg is provided with the following features:
·Accords with the IEC61131-3 standard
·Supports two standard programming languages, i.e. IL (Instruction List) and LD (Ladder Diagram)
·Powerful instruction set, build-in standard functions, function blocks and other special instructions
·Supports interrupt service routines
·Supports subroutines
·Supports direct represented variables and symbolic variables, easy to develop and manage the user project.
·User-friendly and high-efficient environment
·Flexible hardware configuration, you can define all types of the hardware parameters
The following lists the elementary Data Types that the KDN-K3 supports:
KDN-K3系列PLC在中央空调中的应用
KDN-K3系列小型一体化可编程控制器
凯迪恩 Kinco-R331-04TC 总线式I/O模块
凯迪恩 Kinco-R331-04RD 总线式I/O模块
凯迪恩 Kinco-R323-08DR 总线式I/O模块
