阿科美FLP200现场型便携机
2012/12/18 13:07:06
阿科美FLP200现场型便携机:冗余锂电池设计,可在无电源供应下,连续工作4.5-3.7小时,并可实现电池的热插拔更换.
产品分类:品牌:
FLP200 is the first industry notebook form factor computer with multi-slot expansion built-in. The highly mobile unit boasts battery capacity that is 3 times the normal notebook to accommodate data acquisition and
test & measurement peripheral cards. With high memory capacity, dual-core processing power and multi-drive capability, the system outperform, out-expand and out-maneuver any portable computer in the market today
FLP200 was designed with high mobility in mind with the option to install standard PCI peripheral cards. A first in the portable design, our unique design offer latest dual-core processor and PCI expansion while maintaining a function of a notebook computer. With the built-in battery power, the system can offers a high 100W output in a small form factor that cannot be duplicated else where in the market. The system offers an exceptional value for customer a field work environment that are without power source and small form factor is a must. The integrated 15?TFT LCD and keyboard/touchpad add to the computing experience.
Engineered to be the leader in portable market, the FLP200 integrates 2 high capacity Li-ion battery pack into the system. The smart battery system is light in weight and the battery are hot swappable to allow continuous replenishing of power. The system can operate in a both battery power and AC power simultaneously or independently. The FLP200 can operate for 4+ hour when fully charged and recharging the battery will take half the time. Customer can charge and operate the unit at the same time during operation seamlessly. The battery system provides constant monitoring of battery states and specialized software is provided to offer system management that can be tailored to shutdown, hibernate or run specific user assigned application when the battery is low.
Expansion is what set the FLP200 apart from the standard notebook. The system offers 2 full length PCI expansion slot that will operate with majority of the data and testing peripheral cards in the market. With the low power consumption designed throughout the system, we are able to reserve maximum amount for the add-in cards without hindering the battery mobility time. Accommodating the expansion option are built-in dual LAN port and DVD-RW drive. A standard 100GB (7200RPM) drive is offer in the system with optional dual hot-swappable tray for RAID configuration. The unique size, expansion, battery portability and processing power included in the system offers a unparallel of multi-slot mobile computing. No longer is a power outlet required, and no longer is a sacrifice between mobility and processing power be needed. The light weight and rugged FLP200 is here to provide what has been missing in the market.
ECP382-P便携式电脑
ACME 新推便携式平台以满足更高的移动数据存储需求和高清视频流应用
ACME II 系列便携式工业PC
AFS370工业电脑
阿科美SPS-152双扩展槽低功耗便携机(无电池型)
