AFS370工业电脑
Thanks to its rugged aluminum case, this multi-purpose system provides maximal safety for its four hard discs. Like many of our other systems, the SynClone Writeblocker can also be installed. With two installed SynClones it will be possible to copy up to 6 hard discs simultaneously. The 17-inch LCD screen exhibits form and function so that the system can be conveniently used to analyze copied data after the field work. The System also includes a fixed 120GB drive, a slim DVD-RW drive and a MediaBlock gard reader for smart cards
产品分类:工控机
品牌:阿科美
A 2.13 GHz Intel Core 2 Duo E6400 processor backed by 2GB of RAM (expandable to 8GB) gives the new AFS-370 the power of a workstation in portable form. Gigabyte Ethernet, USB 2.0, and Fire-wire (IEEE 1394B PCI) are incorporated to speed up communications. And its 17-inch LCD screen exhibits form and function. Triple independently operating write-blocked bridges allow for the inspection of three subject drives at once. Users are given the option of choosing SCSI, IDE or SATA interfaces. Data and image capture is output to triple 500GB hot-swappable SATA drives. The system also includes a fixed 120GB drive, a slim DVD-RW drive, and a MediaBlock card reader for smart cards (including CompactFlash I and II, IBM Microdrive, Memory Stick, MultiMedia, Secure Digital, and Smart Media cards).
ECP382-P便携式电脑
阿科美FLP200现场型便携机
ACME 新推便携式平台以满足更高的移动数据存储需求和高清视频流应用
ACME II 系列便携式工业PC
阿科美SPS-152双扩展槽低功耗便携机(无电池型)
