Processor | Intel Atom N270(1.6GHz) @ TPD 2.5W | |
Chipset | Intel 945GSE ICH7M | |
Memory | Support DDR2 800/667MHz Memory, Max up to 2GB | |
Storage | Support 2.5″SATA2 Hard Disk | |
Graphics | Intel Graphic Media Accelerator 950 | |
Front Panel | 1*Power Switch with Power LED | |
I/O Ports | 1*DC12V IN | |
Extension | 1*Mini PCI-E | |
Size | W:203.6mm D:190mm H:44mm | |
Material | Aluminum SECC1.2 (Black) | |
Power Supply | DC Adapter (60W) Input : AC100~240V 1.5A 50~60MHz Output : DC 12V 5A(MAX) | |
Weight | 2.06KG | |
Environment | Temperature | 0~60 °C |
Humidity | 10~95% @40°C,non-condensing |
