采用Intel 945GSE+ICH7芯片组;板载Intel Diamondville(Atom)1.60G 的45nm 低功耗CPU;支持DDR2 800/667/533内存,最大容量为2GB;集成Intel高性能GMA950图形显示核心,支持 DX 9.0c图形标准;板载AC` 97声卡,提供一个MLC和LINOUT接口;板载双1000/100/10 Mbps 自适应RTL 8111C PCI-E 硬千兆网卡;板载6个串口。
SV1-B3326 Motherboard Specifications
CPU
Intel Atom 330 Dual-Core 1.6GHz
FSB 533MHz, TDP 8W, 45nm, HT
Chipset Intel G31 / ICH7
Memory
1× DDRII DIMM
800/667/533MHz
up to 2GB memory
BIOS
4MB SPI AWARD BIOS
Upgradeable in OS, Support “Plug & Play”,
ACPI 2.0B, APM 1.2, DMI 2.0, SMBIOS 2.5,
General
Expansion Interface 1× PCI Slot
Chip
Intel GMA 3100 Core
support DirectX 9.0c
Graphics Memory up to 224MB shared memory
Interfaces
1× DB15 VGA port
1× 16 pin VGA connector
Chip 2× Realtek? 8111C PCI-E chip
Ethernet Speed 1000/100/10Mbps auto-adaptive
Interfaces 2× RJ-45 ports
I/O Chip ITE 8782F
Audio Chip Realtek? ALC653 AC`97 sound chip
I/O
Interfaces
1× LINE-OUT & MIC-IN phone jack
1× 40 pin IDE connector
2× SATA ports(transfer rate 3Gb/s),
2× PS/2 Ports
1× LPT port
6× COM
COM1 / COM1-1: RS-232 DB9 port / connector
COM2-6: RS-232 connectors
Form Factor Mini-ITX
PCB Structure 4 Layers
Size 170mm×170mm (6.7inch×6.7inch)
OS Windows Vista / XP / 2000
Special
Functions
Support Others Linux / Unix
Power On after Power-Fail Recover system after power fail
“Watchdog” Recover system when crashes occur
Low-voltage Adaptation Starting-up and running stably with 130V low voltage
ESD Protection Resist 2000V+ lightning or electrostatic discharge
