OPC Server for Aspentech IP21
产品分类:工控软件 OPC软件
品牌:MatrikonOPC
【Introduction】
The OPC Server for AspenTech InfoPlus.21 from MatrikonOPC is used to extract both real-time and historical data. Any OPC compliant application can connect to this server using either the OPC DA (Data Access) or OPC HDA (Historical Data Access) communication standards.
Support for all available InfoPlus.21 point types
Enables you to query for massive amounts of data to do your reports
Direct access using the SetCIM API (CIMIO not required)
Access to both real-time and historical data
Support for both reading and writing
Connects to multiple databases simultaneously
Aggregates List: Interpolated, Maximum, MaximumActualTime, Minimum, MinimumActualTime, TimeAverage
Now auto-configures itself when installed locally on the IP21 Database. (Finds all fields and tags in the system)
【特别提示】
可联系我公司获得免费试用软件
中国化学品安全协会关于举办第六期安全仪表系统功能安全培训班的通知
海天炜业顺利完成山东某石化2017年控制系统检修工作
典型案例 | 海天炜业为某煤化工企业排除运行故障
海天炜业Guard工业防火墙保障江苏某石化工控网络安全
中国特检院“石油化工装置维护保运工程师(控制系统)培训班”在海天炜业开班
