OPC Server for Generic Data Access (GDA)
产品分类:工控软件 DCS 软件
品牌:产品介绍
【Introduction】
The OPC Server for Databases supports both real-time and historical data access to ODBC, MS SQL, MySQL, and Oracle compliant databases. Users may map the OPC point name, value, quality and timestamp by ODBC source table column, custom queries or through pre-configured stored procedures. Applications that require connectivity to databases can use this MatrikonOPC Server to access real-time and historical process data that is archived by an online analyzer, laboratory personnel, etc.
The OPC Server for Databases has the following new and enhanced Features:
NEW: Supports OPC Alarms and Events: Simple and Conditional. Acknowledgement and Storing*
NEW: Updated Graphical User Interface for simplified workflow and ease of use.
Supports using column names as tag names
BatchIDs and In sert TimeStamps (BatchID makes a group of Tags unique and In sert TimeStamp stores the Time at which the write was done on the tag value regardless of what the actual timestamp was)
Connection indicator (shows whether you are currently connected to the database or not)
Executes database functions and procedures with OPC point values filing in the parameters. -
Aggregates List: Average, Count, DurationBad, DurationGood, Interpolated, Maximum, MaximumActualTime, Minimum, MinimumActualTime, PercentBad, PercentGood, StandardDeviation, TimeAverage, Total, Variance, and more...
User friendly help tab (dynamically changes based on the options that are selected for GDA Object Devlink)
The OPC Server for Databases supports the following:
Support for ODBC compliant databases such as MySQL, Microsoft SQL, Oracle, Microsoft Access, Rockwell RSSQL, Sybase, etc.
Access to both real-time and historical data
Read and write access.
Connection to multiple databases simultaneously
【特别提示】
可联系我公司获得免费试用软件
中国化学品安全协会关于举办第六期安全仪表系统功能安全培训班的通知
海天炜业顺利完成山东某石化2017年控制系统检修工作
典型案例 | 海天炜业为某煤化工企业排除运行故障
海天炜业Guard工业防火墙保障江苏某石化工控网络安全
中国特检院“石油化工装置维护保运工程师(控制系统)培训班”在海天炜业开班
