屏通人机 X系列- PX150高階型人机界面
屏通人机 X系列-高階型人機介面 PX150
产品分类:人机界面 触摸屏
品牌:屏通
屏通X系列-高階型人機介面 PX150
产品说明
Model Name | PX150-XSD | |
Sub-models | 4 / 6 | |
Display | Size | 12.1" diagonal |
Resolution (HxV) | 1024*768 | |
Type | TFT LCD | |
Colors | 16-bit/24-bit (Software selectable) | |
Backlight Type | LED | |
Backlight Life (hr) | 50000 | |
Display Contrast | 700 | |
Luminance (cd/m2) | 350 | |
Touch Screen | 5-wire Analog Resistive Type | |
CPU | RISC ARM11 800MHz | |
Battery Backed RAM | 1MB | |
Working Memory | 256MB | |
NAND Flash ROM | 1GB (SLC Type) | |
Real Time Clock (RTC) | Yes | |
Communication Interface | Micro-SD Slot | YES (SDHC) |
USB Client | YES (2.0) | |
USB Host | YES (1.1) | |
Serial (Com1) | RS232/422/485 | |
Serial (Com2) | A-RS422/485 B-RS232/485 C-RS232 with RTS&CTS | |
Serial (Com3) | RS232 or RS485 | |
Ethernet | YES (10/100Mbps) | |
Function Keys | N/A | |
Audio | YES (Type 6) | |
Microphone In | N/A | |
Video In (BNC Connector) | 6: YES, Module Depth: 20mm | |
Front USB Host Port | N/A | |
Power | Supply Voltage | 24VDC�10% Isolated |
Consumption | 20W | |
Environment | Operating Temperature | -20�C ~ 60�C |
Relative Humidity | 10%~90% | |
Shock (operation) | 10 ~ 55Hz(X,Y,Z direction, 1G, 30 minutes shock test) | |
EMI | FCC Part 15 Class A | |
CE | EN61000-6-2, EN61000-6-4 | |
Ingress Protection | IP66 | |
Cooling | Natural Cooling | |
Dimension WxHxD (mm) | 399.1x297.6x55 | |
Cutout Dimension WxH (mm) | 384.5x283.0 | |
Net Weight (Kg) | 2.68Kg |
屏通 T043系列带按键人机界面
屏通人机 8寸PT080系列触摸屏
屏通 PT150-XSD T系列-加強型人機介面
屏通 PV104 TFT 65535色 人机界面
屏通人机 15寸PT150 系列触摸屏
