屏通 PT150-XSD T系列-加強型人機介面
屏通 T系列-加強型人機介面 >> PT150-XSD
产品分类:人机界面 触摸屏
品牌:屏通
產品代號 PT150-XSD
產品名稱 PT150-XSD
產品簡介
1.Touch panel採用五線式電阻
2.內建USB host 與USB client
3.提供 IP65F等級防水觸控式前面板設計
4.採用32位元高效能、高可靠度、低耗電之免風扇中央處理器
5.使用彩色64M TFT/LED 背燈
6.可選128KB~1MB電池備份記憶體供警報、配方、資料記錄使用
7.配合PanelMaster觸控大師規劃軟體可支援橫式及直立式顯示
8.支援多國語言、Windows文字格式、BMP、JPG、GIF等圖檔顯示
9.搭配功能完善之軟體”PanelMaster”,提供設計畫面使用並支援線上程式智能下載功能
9.提供客制化商標;面板設計及初始化開機作業系統 (BIOS)
10.,嚴謹之產品管制及百分之百產品測試
产品说明
Model Name | PT150-XSD | ||||
Sub-models | 4 | ||||
Display | Size | 15" diagonal | |||
Max. Resolution | 1024*768 | ||||
Type | TFT LCD with LED Backlight | ||||
Max. Colors | 16-bit | ||||
Backlight Life (hr) | 50,000 | ||||
Display Contrast | 700 | ||||
Luminance (cd/m2) | 350 | ||||
Touch Panel | 5-wire Analog Resistive Type | ||||
CPU | RISC ARM9 32Bit | ||||
Backup SRAM | 128KB (Optional: 1MB) | ||||
Working Memory | 64MB | ||||
Built-in Storage Memory | 1: 8MB, 2 / 4: 8MB 128MB (NAND Flash) | ||||
Real-Time Clock (RTC) | YES | ||||
Communication Interface | Micro SD Slot | YES | |||
USB Client | YES (USB 2.0) | ||||
USB Host | YES (USB 1.1) | ||||
Serial (Com1) | RS232/422/485 | ||||
Serial (Com2) | A-RS422/485 B-RS232/485 C-RS232 with RTS&CTS | ||||
Serial (Com3) | RS232 only (optional:RS485 only) | ||||
Serial (Com4) | N/A | ||||
Ethernet | 4: YES | ||||
Front Function Keys | N/A | ||||
Audio out (optional) | N/A | ||||
Video in (optional) | N/A | ||||
Front USB Host Port | N/A | ||||
Power | Supply Voltage | 24VDC±10% Isolated | |||
Consumption | 20W | ||||
Environment | Operating Temperature | -10°C~ 60°C | |||
Relative Humidity | 10%~90% | ||||
Shock (operation) | 10 ~ 55Hz (X,Y,Z direction, 1G, 30 Mins shock testing) | ||||
EMI | FCC Part 15 Class A | ||||
CE | EN61000-6-2, EN61000-6-4 | ||||
UL Certification | YES | ||||
Ingress Protection | IP66 | ||||
Cooling | Natural Cooling | ||||
Dimension WxHxD (mm) | 399.1 x 297.6 x 55 | ||||
Cutout Dimension WxH (mm) | 384.5 x 283.0 | ||||
Net Weight (kg) | 2.68 |
屏通 T043系列带按键人机界面
屏通人机 8寸PT080系列触摸屏
屏通人机 X系列- PX150高階型人机界面
屏通 PV104 TFT 65535色 人机界面
屏通人机 15寸PT150 系列触摸屏
