关键字: | 加固笔记本,军工笔记本电脑, |
产品分类: | 工控机 人机界面 工控机整机 专用机 图控一体化产品 便携式工业PC |
品牌: | 亚华兴 |
- 产品简介:
- Intel 915GM + ICH6M chipset 400/533 MHz FSB DDR2 400/533 SATA & EIDE support 8 USB 2.0 port PCI and LPC ACPI 2.0 Extensive Power Management
Product Specification
Item | Description | ||||
Processor | Intel Dothan LV Processor with FSB 400MHz, 1.6GHz with 2M L2 Intel Dothan ULV Processor with FSB 400MHz,1.1GHz with 2M L2 | ||||
Core logic | Intel 915GM + ICH6M chipset 400/533 MHz FSB DDR2 400/533 SATA & EIDE support 8 USB 2.0 port PCI and LPC ACPI 2.0 Extensive Power Management | ||||
Memory | Support DDR2 400/533/667 MHz Two So-DIMM DDR2 memory slots support up to 1GB with high density memory technology module | ||||
GRAPHIC | VGA | Intel 915GM IGP | |||
LCD screen | 13.3’ TFT LCD 1280*800 Pixels | ||||
Mass Storage | HDD | Easy upgradeable with 1.8’ 8mm IDE HDD Optional 2.5’ 9.5mm SATA HDD | |||
ODD | Support 5.25’ 12.7mm height ATAPI interface DVD/COMBO/ DVD-DUAL/Super-Multi DVD | ||||
Audio | HD Audio,ALC883 Built-In 2 speaker | ||||
User Interface | keyboard | 86 key with 19mm key pitch and 2.5mm key stroke | |||
Pointing Device | Integrated Touchpad Left key Right Key | ||||
LED Indicator | 8 LED 1. Power LED (GREEN) 2. Charger and Battery Status (GREEN and Orange) 3. HD Or DVD ROM Activity(GREEN) 4. Wireless LAN Activity (GREEN) 5. Number Lock (GREEN) 6. Caps Lock (GREEN) 7. Reserved 1 8. Reserved 2 | ||||
One type II PCMCIA/Cardbus Slot | |||||
TPM | 1.2 | ||||
Smart card | EMV2000 /EMV V4.1 | ||||
Finger Mark Identify | None | ||||
1394 | None | ||||
Wireless LAN | One Mini PCI interface ,2 Antennas, Support 802.11 B/G/A | ||||
Blue TOOTH | None | ||||
GPS | Support(Optional) | ||||
GPRS/WCDMA | None | ||||
Ethernet LAN | 10/100M LAN Ethernet Controller | ||||
Modem | Azalia modem V9.2 | ||||
Digital camera | 1.3M | ||||
I/O ports | video port | One 15-pin VGA Port | |||
audio port | 2 Jack MIC in & Headphone out | ||||
S-pdif | None | ||||
fax/modem port | One RJ11 Port | ||||
ir port | None | ||||
LAN Port | One RJ45 Port | ||||
ps/2 port | None | ||||
parallel port | None | ||||
Com port | 6 (Two use Odu, one for GPS, one for DB9,two for Reserved) | ||||
usb port | Four USB2.0 Ports (One use Odu) | ||||
1394 Port | None | ||||
TV-Out | None | ||||
Card Reader | SD/MMC 2in1 | ||||
PCMCIA | One TypeⅡPCMCIA card slot | ||||
Express Card | None | ||||
Smart card | One Smart Card Port | ||||
Power Port | One DC-In Port (Odu) | ||||
Port Replicator | None | ||||
Docking | PCIE(Optional) | ||||
Security | Support Smart Card(IC Card)at BIOS Boot Support TPM Support U-Key Support One Key Destroy | ||||
Optional board(Choose one) | 1、 DVD Board 2、 Docking Board 3、 PCIE encrypt Board | ||||
System Software | System BIOS | Phoenix BIOS and EC | |||
Device Driver | Driver list: CPU/Chipset/USB2.0/CODEC/Wireless/Touchpad/LAN Driver/TPM | ||||
Utility | Controller center | ||||
OS | Support Linux Support Windows XP | ||||
Power System | battery | 6 cells li-on 18650 battery pack, 10.8V/60W(For 13.3 Panel) | |||
adapter | |||||
Power management | ACPI V2.0 S0,S3,S4/S5 support | ||||
Dimension | 320 x 242 x 41-50mm | ||||
Weight | Under 4 Kg (including 6 cell Li-Ion battery pack) | ||||
Button Control | 1. Power On/Off Button 2. destroy Switch | ||||
Hot Key | Fn + ESC | Enter Suspend state (sleep button) | |||
Fn + F1 | Touchpad on/off | ||||
Fn + F2 | None | ||||
Fn + F3 | Wireless On/Off | ||||
Fn + F4 | Mute | ||||
Fn + F5 | LCD Brightness down | ||||
Fn + F6 | LCD Brightness up | ||||
Fn + F7 | LCD/CRT display switch | ||||
Fn + F8 | LCD display On/Off | ||||
Fn +F9 | None | ||||
Fn +F10 | None | ||||
Fn +F11 | None | ||||
Fn +F12 | None | ||||
Fn+↑ | Volume Up | ||||
Fn+↓ | Volume Down | ||||
Optional Items | Ø Module Bay: DVD-ROM/Combo/DVD-Dual Ø WLAN: Support 802.11A/B/G with Mini PCI Card interface Ø 2nd battery pack | ||||
Accessories | Ø AC Adapter with Power Cord Ø Battery Pack , 60W(For 13.3 Panel) Ø User’s Manual Ø Driver DVD | ||||
Environmental | Altitude | Operating : 10,000 ft, Ref: MIL-STD-810E | |||
non-operating: 40,000 ft, Ref: MIL-STD-810E | |||||
Temperature | Operating: -20 to 49 deg C, Ref: MIL-STD-810E | ||||
non-operating: -50 to 70 deg C, Ref: MIL-STD-810E | |||||
Humidity | 5 to 95% RH | ||||
Moisture and Fungus Resistance | Resistance to moisture and fungus, operating and non-operating; | ||||
Steamjet | 105+/- 5 psig at a distance of less than or equal to one foot; | ||||
Waterjet | 50+/- 5 applied to produce at least one inch spray diameter; | ||||
Salt Atmosphere | Operates after exposure to a condensing 5% aqueous sodium chloride solution at 35º C for a period of 48 hours; Ref: MIL-STD-810E | ||||
Solar Loading | Operates with the effects of solar radiation (solar loading to 1120 W/m2 max); Ref: MIL-STD-810E | ||||
Mechanical | Shock | Operating: 20 g, 11 m/sec saw tooth, Ref: MIL-STD-810F | |||
Airdrop: Maintain functionality after exposure to a 10g, 100ms, half sine pulse applied in the vertical direction while mounted in the vehicle, | |||||
Random Vibration | MIL-STD-810E, Method 514.4, Category 8 (Ground Mobile Equipment) (operating) | ||||
EMC | Conducted Emissions | MIL-STD-461E CE102 | |||
Radiated Emissions | MIL-STD-461E RE102 | ||||
Conducted Susceptibility | MIL-STD-461E CS101, CS114, CS115, CS116 | ||||
Radiated Susceptibility | MIL-STD-461E RS103 | ||||
Electrical | Input Voltage | 12-19 VDC | |||
Power Consumption (typical) | 15 watts(Use ULV 1.1G CPU) | ||||
Maximum Power | 30 watts | ||||
Miscellaneous | MTBF | 150,000 hours | |||
| MTRF | <= 1.5hours |
