丹佛斯VLT® Advanced Active Filter AAF 006高级有源滤波器
The VLT® Advanced Active Filter AAF 006 improves system efficiency and increases grid robustness to avoid downtime.
产品分类:低压变频器 低压变频器配件
品牌:丹佛斯
The VLT® Advanced Active Filter AAF 006 improves system efficiency and increases grid robustness to avoid downtime. It can compensate forindividual drives or it can be installed as a compact standalone solution at a point of common coupling to compensate for several loads simultaneously.
The active filter ensures optimal harmonic suppression independent of the number of loads and their individual load profile. In addition, it corrects the power factor and balances the phase load to provideoptimal energy utilization.
Supply voltages and load range
380-480 V...190-400 A
Features and benefits
● The lifetime of electronics are prolonged thanks to innovative concepts such as back-channel cooling
● Durability and reliable operation is improved thanks to coated PCBs
● A high degree of customization is possible due to the wide range of options
● Running costs are low as a result of features such as sleep mode, progressive switching frequency and power factor correction
● Servicing is easy due to the modular design
Applications
A range of applications for the water and wastewater, marine, oil and gas and mining industries.
PC tools
● VLT® Motion Control Tool MCT 10
● VLT® Motion Control Tool MCT 31
● Danfoss HCS (Harmonic Calculation Software)
● Danfoss Servo Sizer
● VLT® Energy Box
智驱“新”未来 | 丹佛斯为锂电行业输出高效解决方案
勇为行业先 | 丹佛斯助力全球首个直流电推化学品船提升效能
丹家速度 | 14周制造时间,看丹佛斯如何轻松应对
可再生能源远无法满足实现绿色转型的能源需求
直播回顾 | FC111线上研讨会直播答疑汇总来啦!
