产品选型
西克 ZR-350N-B光电开关
西克 ZR-350N-B光电开关
ZR-350N-B光电传感器施克SICK
产品分类:
离散传感器 物联网 光电开关 感知层 位置检测
品牌:
西克
  • FEATURES
    Sensor/detection principlePhotoelectric proximity sensor, Background suppression
    Dimensions (W x H x D)11 mm x 31 mm x 20 mm
    Housing design (light emission)Rectangular
    Sensing range max.2 mm ... 500 mm 1)
    Sensing range15 mm ... 500 mm 1)
    Type of lightVisible red light
    Light sourceLED
    Wave length680 nm
    • 1) Object with 90 % reflectance (referred to standard white, DIN 5033)
  • MECHANICS/ELECTRONICS
    Supply voltage10 V DC ... 30 V DC
    Ripple± 10 %
    Power consumption≤ 30 mA 1)
    Output typePNP
    Switching modeLight/dark switching
    Switching mode selectorSelectable via light/dark rotary switch
    Response time≤ 0.5 ms 2)
    Connection typeConnector M8, 3-pin
    Housing materialPBT
    plastic
    Optics materialPC
    Enclosure ratingIP 67
    Ambient operating temperature–25 °C ... +55 °C
    Ambient storage temperature–40 °C ... +70 °C
    UL File No.NRNT2.E128350 & NRNT8.E128350
邦纳BANNER OTBVN6 W/Y光电触摸按钮
LANBAO兰宝 电感式接近开关 LE08SN25DNO
M8圆柱型接近开关凯库恩KEKUHN
邦纳 LS2TP30-1050Q88安全光幕
邦纳 OTBVN6 W,Y光电按钮
