西克 WTB140-P330光电开关
2020/5/17 10:31:05
WTB140-P330光电传感器施克SICK
产品分类:离散传感器 物联网 光电开关 感知层 位置检测
品牌:西克
FEATURES
Sensor/detection principle Photoelectric proximity sensor, Background suppression Dimensions (W x H x D) 11 mm x 31 mm x 20 mm Housing design (light emission) Rectangular Sensing range max. 2 mm ... 500 mm 1) Sensing range 15 mm ... 500 mm 1) Type of light Visible red light Light source LED Wave length 680 nm 1) Object with 90 % reflectance (referred to standard white, DIN 5033)
MECHANICS/ELECTRONICS
Supply voltage 10 V DC ... 30 V DC Ripple ± 10 % Power consumption ≤ 30 mA 1) Output type PNP Switching mode Light/dark switching Switching mode selector Selectable via light/dark rotary switch Response time ≤ 0.5 ms 2) Connection type Connector M8, 3-pin Housing material PBT
plasticOptics material PC Enclosure rating IP 67 Ambient operating temperature –25 °C ... +55 °C Ambient storage temperature –40 °C ... +70 °C UL File No. NRNT2.E128350 & NRNT8.E128350 1) Without load.
2) Signal transit time with resistive load.
技术图纸
Dimensional drawing
Adjustments possible
Connection diagram
Characteristic curve
Sensing range diagram
邦纳BANNER OTBVN6 W/Y光电触摸按钮
LANBAO兰宝 电感式接近开关 LE08SN25DNO
M8圆柱型接近开关凯库恩KEKUHN
邦纳 LS2TP30-1050Q88安全光幕
邦纳 OTBVN6 W,Y光电按钮
