盈美智 EPIX PCI模拟视频卡
Analog Standard Video (RS170, S-VIDEO, NTSC, PAL, CCIR)
产品分类:机器视觉 图像采集卡
品牌:盈美智
型号 | 用于相机接口 | 总线接口 | 最大数据宽度 | 描述 |
PIXCI® SV5 | Analog Standard Video (RS170, S-VIDEO, NTSC, PAL, CCIR) | 32bit/33MHz 5V PCI | 8 bit RGB (24 bit color) | 2 BNC, 1 S–Video Multiplexed Inputs |
PIXCI® SV5A | Analog Standard Video (RS170, NTSC, PAL, CCIR) | 32bit/33MHz 5V PCI | 8 bit RGB (24 bit color) | 3 BNC Multiplexed Inputs |
PIXCI® SV5B | Analog Standard Video (RS170, NTSC, PAL, CCIR) | 32bit/33MHz 5V PCI | 8 bit RGB (24 bit color) | Low-profile, 1 BNC Input with Loop Thru BNC |
PIXCI® SV5L | Analog Standard Video (RS170, S-VIDEO, NTSC, PAL, CCIR) | 32bit/33MHz 5V PCI | 8 bit RGB (24 bit color) | Low-profile, 2 mini-BNC, 1 S-Video Multiplexed Inputs |
PIXCI® SV5S | Analog Standard Video (RS170, S-VIDEO, NTSC, PAL, CCIR) | 32bit/33MHz 5V PCI | 8 bit RGB (24 bit color) | SV5 with Vertical Sync Stripper |
盈美智Vivid LVDS/RS-422 to Camera Link Translators
盈美智 Vivid Camera Link Simulators
盈美智 Vivid Camera Link Breakout Box
盈美智 SVS HR系列相机
盈美智 SVS SVCam-CF系列工业相机
