CEB-H81M-A110
2020/7/30 9:55:36
LGA1150 Intel®4代酷睿 i7/i5/i3/奔腾®/赛扬®处理器, VGA/DVI-D,DDR3,SATAIII,USB3.0,10COMs,M-ATX 主板
产品分类:嵌入式系统 嵌入式主板
品牌:桦汉科技
■ 简介 | ||
采用Intel®Haswell平台,H81芯片组, 中央处理器功耗最高支援到65W,m-ATX 架构, 支持双千兆网口,DDR3,SATA III,USB3.0,10COMs. 主板支持丰富的I/O接口、功能齐全,具备耐用设计与多扩展功能。可应用于金融、智能服务、智能制造、安全监控、环保监测等领域。 |
■ 特性 | ||
■ 规格 | ||
处理器 Processor | Intel®4th Core™ i7/i5/i3/Pentium®/Celeron®processor, TDP up to 65W | |
芯片组 Chipset | H81 | |
内存 Memory | DDR3 1333/1600 MHz, 2 x U-DIMM Slot, up to 16GB | |
存储 Storage | 2 x SATA 2.0, 2 x SATA 3.0 | |
显示 Display | Intel® HD Graphics 4600 | |
网口 Ethernet | 2 x Realtek® 8111G-CG GbE (10/100/1000 Mbps) | |
音频 Audio | Realtek® ALC269 HD Audio codec, supports 2.1-channel | |
BIOS | AMI UEFI BIOS | |
外部接口 Rear I/O | 1 x VGA: max resolution up to 1920 x 1600@60Hz 1 x DVI-D: max resolution up to 1920 x 1200@60Hz 1 x HDMI: max resolution up to 2560 x 1600@60Hz 2 x USB 3.0, 6 x USB 2.0 2 x USB 3.0, 6 x USB 2.0 Support USB SR Pro 1 x RS232 1 x Line-in, 1 x Line-out, 1 x Mic-in 2 x RJ45 | |
内部接口 Internal I/O | 6 x USB 2.0 1 x CPU_Fan (4pin), 1 x SYS_Fan (4pin) 1 x LVDS: Supports dual channel 24 bit and up to 1920 x 1200 1 x 8-bit GPIO 2 x RS232/422/485, 7 x RS232 1 x Speaker 1 x F_Panel (power LED, HDD LED, power button, reset button) | |
扩展接口 Expansion | 1 x PCIe X 16 (Gen3) 1 x PCIe X 1 2 x PCI | |
环境 Environment | 操作温度operation temp: 0℃~60℃ 存储温度storage temp: -40℃~85℃ 操作湿度operation hum: 5%~90%, 非凝结 non-coagulation 存储湿度storage hum: 5%~90%, 非凝结 non-coagulation | |
电源输入 Power Input | ATX | |
尺寸 Dimensions | 244 x 244 mm (9.6" x 9.6") | |
操作系统OS | Windows 7(部分功能受限/limited function)/8.1/10, Linux |
■ 订购清单 | ||
标配 Standard | 型号 Model Name | 描述 Description |
CEA-SA40-CAB0 | 1 x SATA, 1x7P, 400mm, w/o lock, 180°/180° | |
CEA-H81M-BRK0 | I/O shielding bracket | |
选配 Optional | 型号 Model Name | 描述 Description |
CEA-CM50-CAB0 | 4 x COM(3~6), 2 x 20P, 500mm, black | |
CEA-CM50-CAB1 | 4 x COM(7~10), 2 x 20P, 500mm, black | |
CEA-US25-CAB0 | 4 x USB, 2 x 5P, 250mm, white | |
CEA-H81M-FAN0 | CPU Cooler, support 65W, LGA115X Series | |
桦汉科技产品矩阵再扩大,全新升级的IPC-310工控机满足更多场景应用
新品速递|工业扩展型触摸一体机,实现工业应用的无限可能!
凭实力“出圈”,桦汉科技入选市级示范智能车间!
面对制造业的严重内卷,桦汉科技也能迎难而上!
