CEB-Q17A-A100
2020/7/30 10:04:20
LGA1151 Intel® 6/7代酷睿 i7/i5/i3/奔腾®/赛扬®处理器,VGA/DVI-D/DP++, DDR4, SATAIII, USB3.0, 6 COMs, ATX 主板。
产品分类:嵌入式系统 嵌入式主板
品牌:桦汉科技
■ 简介 | ||
采用Intel® Skylake-S/Kabylake-S平台,Q170芯片组,中央处理器功耗最高支援到95W,ATX 架构,支持双千兆网口,DDR4, SATA III, USB3.0, 6COMs。主板支持丰富的I/O接口、功能齐全,具备耐用设计与多扩展功能。可应用于金融、智能服务、智能制造、安全监控、环保监测等领域。 |
■ 特性 | ||
■ 规格 Specification | ||
处理器 Processor | Intel® Core™ i7/i5/i3/Pentium®/Celeron®processor, TDP up to 95W | |
芯片组 Chipset | Q170 | |
内存 Memory | DDR4 2133/2400 MHz, 4 x U-DIMM Slot, up to 64GB | |
存储 Storage | 4 x SATA 3.0, 1 x M.2(SATA3.0 or PCIE3.0x1)2242/2280 | |
显示 Display | Intel® HD Graphics 630 | |
网口 Ethernet | 1 x Intel® i219-LM GbE, 1 x Intel® i211-AT (10/100/1000 Mbps) | |
音频 Audio | Realtek® ALC269 HD Audio codec, supports 2.1-channel | |
BIOS | AMI UEFI BIOS | |
外部接口 Rear I/O | 1 x DVI-D: max resolution up to 1920 x 1200 1 x VGA: max resolution up to 1920 x 1200 1 x DP++: max resolution up to 4096 x 2160 2 x USB2.0, 6 x USB3.0 (support USB SR Pro) 2 x RJ45 1 x RS232/422/485(with auto flow control) 1 x Line-out/Line-in/Mic-in | |
内部接口 Internal I/O | 1 x RS232/422/485 2 x RS232/485 2 x RS232 4 x USB2.0 (Type-A *1 +Pinheader) 1 x 16 bit DIO 1 x LPT | |
扩展接口 Expansion | 2 x PCIe X 16 (Gen3, 1x16 or 2x8 link) 3 x PCIe X 4 (X4 link) 2 x PCI 1 x M.2 (SATA3.0 or PCIE 3.0 x 1) | |
环境 Environment | 操作温度operation temp: 0℃~60℃ 存储温度storage temp: -40℃~85℃ 操作湿度operation hum: 5%~90%, 非凝结non-coagulation 存储湿度storage hum: 5%~95%, 非凝结non-coagulation | |
电源输入 Power Input | ATX | |
尺寸 Dimensions | 304.8 x 244 mm (12" x 9.6") | |
操作系统 OS | Windows 7/8/10, Linux |
■ 订购清单 | ||
标配 Standard | 型号 Model Name | 描述 Description |
CEA-SA40-CAB0 | 1xSATA, 1x7P, 400mm, w/o lock, 180°/180° | |
CEA-H81A-BRK0 | I/O shielding bracket | |
选配 Optional | 型号 Model Name | 描述 Description |
CEA-LP45-CAB0 | 1 x LPT, 2 x 13P, 450mm, Black | |
CEA-CM30-CAB0 | 2 x COM, 2 x 5P, 300mm, Black | |
CEA-GP35-CAB0 | 1 x GPIO, 2 x 10P, 350mm, Black | |
CEA-US35-CAB0 | 2 x USB, 2 x 5P, 350mm, Black | |
CEA-H81M-FAN0 | CPU Cooler, support 65W, LGA115X Series |
注明:[1] MiniPCIE slot和M.2 slot同时只能用一个,需要用jumper做切换
桦汉科技产品矩阵再扩大,全新升级的IPC-310工控机满足更多场景应用
新品速递|工业扩展型触摸一体机,实现工业应用的无限可能!
凭实力“出圈”,桦汉科技入选市级示范智能车间!
面对制造业的严重内卷,桦汉科技也能迎难而上!
