信步自动化核心模块载板SV-B9689
2023/12/8 9:34:13
信步自动化核心模块载板,可灵活选配SCM-C核心模块,可应用于机器视觉、运动控制等工业自动化各细分领域。
产品分类:嵌入式系统
品牌:信步科技
- 可灵活选配SCM核心模块,提供4个intel网卡,适用于各类机器视觉应用场景
- 6*COM, 9*USB, 4*LAN
- 提供1*VGA, 1*HDMI, 1* LVDS/Edp, 支持三屏异显
- 提供1*M.2支持SATA/NVMe, 1*Mini-PCIe支持Wifi/4G
- 187*125mm , DC 12-28V供电
规格
General | |
CPU | SCM-C Intel®11/12th CoreTM i3/i5/i7 or Celeron® J6412 CPU |
Memory | DDR4 Memory, 1*SO-DIMM, up to 32GB |
Storage | 1*SATA3.0 1*SATA7+15P 1*M.2(Key-M, 2242/2280, NVMe PCIe/ SATA SSD) |
Expansion Interface | 1*M.2(Key-E, 2230, PCIe+USB 2.0 ) 1*M.2(Key-B, 3052, USB 3.0+ USB 2.0) 1*Mini-PCIe (PCIe+USB2.0, Wifi/4G/CAN) 1*SIMSlot 1*FPC(SMBUS+2*USB2.0+2*PCIe X1+3*RS232) |
BIOS | AMI UEFI BIOS |
System | Windows 10/11, Linux |
I/O Interface | |
Ethernet | 2*RJ45supported by Ethernet Controllers on SCM module 2*Intel® GbE Ethernet Connector,RJ45 |
Serial | 1* RS232/485/422, 3*RS232, 2*RS232/RS485 |
USB | 4*USB 3.0, 5*USB 2.0 |
Audio | Audio with Line-out/MIC |
GPIO | 2*GPIO |
Feature Interface | 1*MCU, 1*WDT, 1*I2C, 1*Touch, 2*Fan |
Display | |
Display Interface | 1*HDMI:max resolution up to 1920*1080@60Hz 1*VGA:max resolution up to 1920*1080@60Hz 1*LVDS/eDP: LVDS, max resolution up to 1920*1200@60Hz eDP, max resolution up to4096*2160@60Hz |
Multiple Display | Triple |
Mechanical & Environment | |
Dimension | 187*125mm |
Power Input | DC 12V-28V, 支持掉电保护(外置UPS) |
Temperature | Operation: -20℃~60℃, Storage: -30℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
信步机器人控制器核心模块载板SV-B1000
信步新一代高可靠工业计算机NAV-700
“一花独放不是春,百花齐放春满园” —— 信步科技展会侧记
把机器变成人,2023 信步开门红!
时延突破20微秒,信步再获创新三奖项!
