- 型号:REX-C400FK02-V*NN
- 数量:100
- 制造商:RKC
- 有效期:2045/9/30 0:00:00
CD901FK04M GM |
CH102 FK02-M*GN-NN |
CD901FK02-M-AN |
OPL-AN |
MT18-B-FK04-DNN |
M-PCP-A-2-24N-MAB |
REXF900 |
CH402FK02-M*AB |
CH402FK02-M*NN |
CD701FK02-M*GN |
CH402FD10-V*NN |
CB100FK02-VXAP-NN1A1T |
REX-PG410A4HJ-5N AC220V |
CZ-100P-HB-HSN 0-50MPA |
FK02-V*AP-NN/A/Y,0-400度CH102 |
CH402 PT100 400度的 |
ch102fk02-v*ap-nn |
CD901VD12-88*AN-NNN-NA |
CD901VD12-8M*AN-NNN-NA |
REC-D900 |
ST-41 |
ch102fk02-m8gn |
ST-50不是表 是整包起买的一包5根 |
CZ-100P-LLA-SNG |
RKC CD901FD10-8*AB-NN-/Y |
CH402WK02-VM |
CH402WE01-VM |
CH402WK02-VM*an-5n 带通讯 |
fb400-6-4*4nnn-n |
CD901F-801-8*AN |
CH102-FD10-M*GN-NN |
CZ-100P-HLZ-SN |
CT-300-4 |
CH402FD08-8GA-AA |
CH102FJ01-V*AB-N-N |
CD401AK0688NP51 |
CH402FS02-MM*AN-NN |
CH402FK10-8*GN |
REXC900FT-MM*A-N |
RKC85-50M/DC24 |
cd901fk02-v*gn-nn |
CH402FK02-M*GN-NN |
CD901FK06-8*AB-5N |
fb400-8-4*4nnn/f801 |
CD901 FK02-M*AN-NN |
CD901FK06-8*AA-NN |
FB400-8N-4*1NNN/A1-FS01 |
FB400-8N-4*1NN5/A1-FS01 |
cd701 |
C-700FK06-MM*N |
CH402-8450V 0-400度,K型 RELAY 继电器输出/ ALM1,ALM2 |
ST-30 |
F400FK10-V*NP-NNN-NN 用fb400替代 |
CD401VM 带通信 继电器输出 |
CH402VM 不带通信,带报警 ,继电器输出 |
fb900-8-4*4nn5/f801 |
REX-CD901-FK07-8*AN |
CD901FK02-M*AN*NN 是K型 |
CD901Fd08-M*AN*NN PT100 |
CH901FK02-M*GN-NN |
CD901Fd10-M*AN*NN |
CD901Fd10-V*AN*NN |
cd901fd08-vm*gn-nn |
REX-P96P96FK-8*AB-Y1-N |
REX-C100 C100FK07-8*AN用ch102替代 |
CD901FD01-M*M*AN-200C-649C PT100 |
ch102FK05-V*CN-NN/A |
REX-P96FK16-V |
CD501FK07-M*NN |
D900W-8-DN-N-5 |
901温控仪,0-800度,K型,控制可控硅 |
CD901CODEFK02-M*GN-NN |
CD901WD05-8M*AB-NN/NY |
CD901FD01-V*AB |
CD901-FK02-MM*AA-NN |
CH902/901-V*AB-NN |
CH402FK01-VAV |
REX-D900-8-DN-N-5 |
REX-F400 F400FD04-V*CC-NNN-1N |
REX-C400FK02-R*KN |
CH102FK02-V*NN |
CH102FK04-V*AP*5N |
CH402FK01-V*AN |
CH102A801-MM |
ST-23L |
FB400COBE-8N-4*4N-8N-AN-Y AC240 |
CH102FD07-M*AN |
CD901FK02-M*Gn-nn |
CD901FR01-8M*GN-NN |
CD901FR01-M*GN-NN |
CD701FK02-V*EN |
CB100FK07-8V*AP |
REX-P96FK16-V |
cd701f801-8*an-nn |
CH402 CODE FK02-M*GN-NN 0-400 输入:K,输出RELAY |
HA900-DD-VV-4*NN-NN1-N/A/Y |
FB400 8N-4*4NNN/A1-FD35/Y 4 |
HA901 80-B6-4-M2-NNNN-A-Y |
cd401fk02-vm*an-5n (带通信) |
F900FD12-8*AF-NNN-NN AC110V TO 240V |
CH402FK10-8*GN |
CT-300 |
PCT-300N-4N |
M-PCP-A-24N-M*AB Z-190 INPUT:200-240VAC |
M-TIO-B-FD16-V*NN OUTPUT:0-12VDC |
M-DO-A-M OUTPUT:RELAY(250VAC 1A) |
D400F-N*DN-8-N |
D400W-V*NN |
CD901FK02-M*GH-NN |
CD901FK020MMAP-NN |
CH102 FK07-V*AP-NN |
REX-P200 FDC-F*B-NN-N |
CH102-DT03-8*NN |
REX-C400FK02-V*NN 用ch402替代 |
REX-C900FK02-V*NN 用cd901替代 |
c900fd10-m*an 用cd901替代 |
ST-32 |
CH102-DT03-8*NN |
ch102fk07-m*nn-nn/a/y |
cB500fk07-m*nn-nn/a/y |
CD901FK02-8*AN |
CH402FD05-M*GN-2N |
CB100FK07-M*NN-NN/A/Y |
CH402FK03-MM*GN-NN |
MA9004FD10-8N*ABF-D6/N/Y PT100 0-500 四通道 |
CB900FD10-88AF-5N/A/Y PT100 0-500 二通道 |
CH102FK06-M*KN |
P96 LK22-V*GD-Y1-N |
CB900FD10-V*AF-NN/A/Y |
CD901F801-8*HJ-NN |
dp350c |
CH402FK02-M*GN-NN 里面带ZK-1033 0-40度 |
CD401FK02-MNN |
CB900FK07-V*AF 用cd901替代 |
CH402FD05-M*GN-5N |
- 电话:021-66100983 66100663
- 传真:021-61638399-9148
- email:boyi1010@126.com
更多内容请访问 boyi1010(http://home.gongkong.com/profile/?uid=F-8D3F-753371C4A654)
