- 型号:PSM-EG-RS232/RS 422-P/4K
- 数量:100
- 制造商:菲尼克斯
- 有效期:2030/9/30 0:00:00
PSM-EG-RS232/RS422-P/4K |
FL CRIMPTOOL |
ZB 6,6:UNBEDRUCKT |
FL SWITCH 5TX |
FL SWITCH SFN 5TX |
VIO K 1,5 |
EB 10- DIK BU |
EB 10- DIK RD |
IB IL AO 2/U/BP-PAC |
FLM DO 8 M12 |
IB ST 24 AI 4/SF4 |
FLS IB M12 DO 8 M12-2A |
FLS IB M12 DI 8 M12 |
IB ST 24 AO 4/BP |
IB ST 24 AI 4/SF |
FL HUB 8TX-ZF |
FL SWITCH 5TX-ZF |
PSI-DATA/FAX-MODEM/SET1 |
PSI-DATA/FAX-MODEM/RS232 |
FL SWITCH SFN 4TX/FX |
IBS IP 400 ME-VFD 1-3A DI4 |
IB IL 24 DI 8 |
IB IL 24 DI 2 |
IB IL 24 PWR IN/F |
IB IL 24 DO 8 |
IB IL 24 DI 32/HD-PAC |
IB IL 24 DO 32/HD-PAC |
IBS MC FLASH 2MB |
IBS RL 24 DI 16/8-T |
IBS RL PLUG-T |
IBS S7 300 DSC-T |
IBS IP CDIO/R 24-8/SF |
IB STME 24 BDO 32/2 |
IBS DSUB 9/C |
SUBCON 9/F-SH |
IBS TR5 5AT |
FL IL 24 BK-PN-PAC |
IBS RBC METER-T |
IBS PC CB/TDOS486/I-T |
IBS ST 24 BK-T |
IB IL SSI-IN-PAC |
IL PB BK DP/V1 |
IBS PC ISA SC/I-T |
IB IL 400 ELR R-3A |
IB IL 400 ELR 1-3A |
FL SWITCH Sf 14TX/2FX |
FL SWITCH SFN 6TX/2FX |
PSI-MOS-PROFIB/FO 660 E |
PSM-SET-FSMA/4-HC |
IB ST 24 DI 32/2 |
IB ST 24 DI 16/4 |
IB IL 24 PWR IN/2-F |
FL SWITCH 4TX/FX |
SST-IBS-CLX-RLL |
IL MII BK DI8 DO4-PAC |
FL SWITCH MM HS |
FL CAT5 TERMINAL BOX |
FL MC10/100BASE-T/FOG1300 |
- 电话:021-66100983 66100663
- 传真:021-61638399-9148
- email:boyi1010@126.com
更多内容请访问 boyi1010(http://home.gongkong.com/profile/?uid=F-8D3F-753371C4A654)
