西门子编程电缆6FX2003-0DA00 6FX2003-0DS00 6FX2003-0LU00
2009/1/10 22:43:39
0 人气:271
- 型号:6FX5002-2CA11-1BF0 6FX5002-2CA11-1BA0 6FX5002-2CA11-1BA0
- 数量:大量
- 制造商:德国
- 有效期:2019/1/31 0:00:00
天津大成恒业机电设备有限公司 西门子编程电缆长期现货 6FX2003-0DA00 Terminator for drive bus |
6FX2003-0DS00 RS232 ISOLATOR |
6FX2003-0LU00 POWER CONNECTOR SIZE 16-WAY SOCKET, UNION NUT1 6-POLE INSULATOR 8 SOCKET CONTACTS (1-2.5 MM2)2 CABLE |
6FX2003-0LU10 POWER CONNECTOR 6-POL SIZE 1.5SOCKET, UNION NUT1 6-POLE INSULATOR 5 SOCKET CONTACTS (1.5-4MM2)5 SOCK |
6FX2003-0SU01 SIGNAL CONNECTOR, 9-PINUNION NUT1 INSULATOR WITH SOCKET CONT.1 INSULATOR WITH PIN CONT.SOLDER VERSIO |
6FX2003-0SU12 |
6FX2003-7DX00 Mounting flange for signal conn.(can be used for conn. With union cap and for conn. With external thread also) |
6FX2003-7FX00 HF clamp for signal connector and power connector and power connector size1 |
6FX2006-1BA02 Cable distributor |
6FX2006-1BC01 DISTRIBUTOR for hand-held unit with iicl. Shorting plug 3-wire connection |
6FX2006-1BG00 Connecting kit |
6FX2006-1HA0 Holder made of polystyrence |
6FX2007-1AC03 "B-MPI handheld unit 3-step enabling button |
including connecting cable with connector |
3-wire enabling |
- coiled connecting cable length: 3.5 m (11 ft 6 in)" |
6FX2007-1AC04 "B-MPI handheld unit 3-step enabling button including connecting cable with connector 3-wire enabling - coiled connecting cable length: 3.5 m (11 ft 6 in)" |
6FX2007-1AC13 "B-MPI handheld unit 3-step enabling button including connecting cable with connector 3-wire enabling - straight connecting cable length: 10 m (32 ft 10 in)" |
6FX2007-1AC14 "B-MPI handheld unit 3-step enabling button including connecting cable with connector 3-wire enabling - straight connecting cable length: 10 m (32 ft 10 in)" |
6FX2007-1AD01 "Mini handheld unit 3-step enabling button incl. 2 magnets for attachment and connecting cable with connector • Coiled connecting cable Length: 1.5 m (4 ft 11 in), stretches to 3.5 m (11 ft 6 in)" |
6FX2007-1AD11 "Mini handheld unit 3-step enabling button incl. 2 magnets for attachment and connecting cable with connector • Straight connecting cable Length: 5 m (16 ft 5 in)" |
6FX2007-1AE04 "B-MPI handheld unit 3-step enabling button |
4-wire enabling |
6FX2007-1AE14 "B-MPI handheld unit 3-step enabling button |
4-wire enabling |
6FX4002-2CA51-1BF0 SIGNAL CABLE 611A---1PH6 ENCODER/SIMAG H, 3X2X0.14+4X0.14+2X0.5C L=15M |
6FX4002-2CB31-1BA0 SIGNAL CABLE, 611A TO 1FT5 TG/SHAFT POSITION ENCODER, 12X0.23C, L=10M |
6FX4002-2CB42-1BA0 SIGNAL CABLE, 810/820 TO BUILT-IN ENCODER ROD320, 4X2X0.38+4X0.5C, L=10M |
6FX4002-2CB42-1BF0 SIGNAL CABLE, 810/820 TO BUILT-IN ENCODER ROD320, 4X2X0.38+4X0.5C, L=15M |
6FX4002-5CA12-1BJ0 POWER CABLE, PREASSEMBLED, EXT., 4X4 C, CONNECTOR SIZE 2 [1FT/1FK TO 611/810D/SIMODRIVE] L=18M |
6FX4002-5DA01-1BA0 POWER CABLE, 4X1.5C,CONN. SIZE 1, L=10M |
6FX4002-5DA02-1BF0 POWER CABLE L=15M |
6FX5002-2AD00-1BA0 SIGNAL CABLE, (611D/MCU TO ENDAT ENCODER) 3X2X0.14+4X2X0.5C L=10M |
6FX5002-2CA11-1AF0 encoder cable,5M |
6FX5002-2CA11-1AG0 encoder cable,6M |
6FX5002-2CA11-1BA0 encoder cable,10M |
6FX5002-2CA11-1BF0 encoder cable,15M |
- 电话:010-88603269/65431486/654334982
- 传真:010-65431486-8005
- email:dachenghengye@yahoo.con
上一篇:西门子编程电缆6FX2001-3EB02 6FX2001-3EC50 6FX2001-7KF10
下一篇:西门子编程电缆6FX5002-5CA41-1BC0 6FX5002-5CA51-1BA0 6FX5002-5CA11-1CA0
相关推荐
工控宝APP下载安装
