西门子编程电缆6FX5002-5CA41-1BC0 6FX5002-5CA51-1BA0 6FX5002-5CA11-1CA0
供稿:dachenghengye 2009/1/10 22:47:37
0 人气:223
- 型号:6FX5002-2CG00-1BA0 6FX5002-2CG00-1CA0 6FX5002-2CJ00-1AH0
- 数量:大量
- 制造商:德国
- 有效期:2020/1/31 0:00:00
天津大成恒业机电设备有限公司 010-88603269/65431486
西门子编程电缆长期现货,价格从优
6FX5002-2CA11-1CA0 encoder cable,20M |
6FX5002-2CA11-1CF0 encoder cable,25M |
6FX5002-2CA31-1AF0 Signal cable,5M |
6FX5002-2CB51-1BF0 SIGNAL CABLE (BUILT-ON ENCODER 5V 6FX2001-2) 4X2X0.34+4X0.5C L=15M |
6FX5002-2CD01-1AF0 Signal cable, SMC30 --- external encoder(TTL), 5M |
6FX5002-2CD01-1BA0 Signal cable, SMC30 --- external encoder(TTL), 10M |
6FX5002-2CD01-1BF0 Signal cable, SMC30 --- external encoder(TTL), 15M |
6FX5002-2CD01-1CA0 Signal cable, SMC30 --- external encoder(TTL), 20M |
6FX5002-2CD01-1CF0 Signal cable, SMC30 --- external encoder(TTL), 25M |
6FX5002-2CG00-1AF0 Incremental(sin/cos 1Vpp) encoder cable,5M, IP20/IP67 |
6FX5002-2CG00-1BA0 Incremental(sin/cos 1Vpp) encoder cable,10M, IP20/IP67 |
6FX5002-2CG00-1BF0 Incremental(sin/cos 1Vpp) encoder cable,15M, IP20/IP67 |
6FX5002-2CG00-1CA0 Incremental (sin/cos 1Vpp)encoder cable,20M, IP20/IP67 |
6FX5002-2CG00-1CF0 Incremental(sin/cos 1Vpp) encoder cable,25M, IP20/IP67 |
6FX5002-2CJ00-1AH0 Signal cable,SIMODRIVE Baseline-802C BL(7M) |
6FX5002-2DC10-1AF0 DRIVE CLiQ Signal cable for Motor encoder --- Motor module,5M, IP20/IP67, with 24VDC |
6FX5002-2DC10-1BA0 DRIVE CLiQSignal cable for Motor encoder --- Motor module,10M,IP20/IP67, with 24VDC |
6FX5002-2DC10-1BF0 DRIVE CLiQSignal cable for Motor encoder --- Motor module,15M,IP20/IP67, with 24VDC |
6FX5002-2EQ10-1BA0 SIGNAL CABLE, (ABSOLUTE ENCODER IN MOTOR) 3X2X0.14+4X0.14+2X0.5+4X0.22C L=10M |
6FX5002-2EQ10-1BJ0 signal cable, (ABSOLUTE ENCODER IN MOTOR) 3X2X0.14+4X0.14+2X0.5+4X0.22 C, L=18M |
6FX5002-5CA01-1AF0 power cable for 3,2-16 Nm motor,5M |
6FX5002-5CA01-1BJ0 power cable for 3,2-16 Nm motor,18M |
6FX5002-5CA11-1AF0 power cable for 18 Nm motor,5M |
6FX5002-5CA11-1BA0 power cable for 18 Nm motor,10M |
6FX5002-5CA11-1BF0 power cable for 18 Nm motor,15M |
6FX5002-5CA11-1CA0 power cable for 18 Nm motor,20M |
6FX5002-5CA21-1BA0 POWER CABLE 4X1.5C, CONN. SIZE 1.5 L=10M |
6FX5002-5CA31-1AF0 power cable for 27 Nm motor,5M |
6FX5002-5CA31-1BA0 power cable for 27 Nm motor,10M |
6FX5002-5CA31-1BF0 power cable for 27 Nm motor,15M |
6FX5002-5CA41-1AF0 power cable for 27 Nm motor,5M |
6FX5002-5CA41-1BA0 power cable for 27 Nm motor,10M |
6FX5002-5CA41-1BC0 power cable for 27 Nm motor,12M |
6FX5002-5CA41-1BF0 power cable for 27 Nm motor,15M |
6FX5002-5CA41-1CA0 power cable for 27 Nm motor,20M |
6FX5002-5CA51-1AF0 power cable for 36 Nm motor,5M |
6FX5002-5CA51-1BA0 power cable for 36 Nm motor,10M |
6FX5002-5CA51-1BF0 power cable for 36 Nm motor,15M |
天津大成恒业机电设备有限公司西门子编程电缆长期现货 |
6FX5002-5CS01-1AF0 Power cable below 18NM,5M |
6FX5002-5CS01-1BA0 Power cable below 18NM,10M |
6FX5002-5CS01-1BF0 Power cable below 18NM,15M |
6FX5002-5CS02-1AF0 Power cable for 1FT/1FK/1PH spindle motor,5M, open connection in motor side, 4x1.5 sqr.mm, used for 1PH7101 |
6FX5002-5CS02-1BA0 Power cable for 1FT/1FK/1PH spindle motor,10M, open connection in motor side, 4x1.5 sqr.mm,used for 1PH7101 |
6FX5002-5CS02-1BF0 Power cable for 1FT/1FK/1PH spindle motor,15M, open connection in motor side, 4x1.5 sqr.mm,used for 1PH7101 |
6FX5002-5CS12-1AF0 Power cable for 1FT/1FK/1PH spindle motor,5M, open connection in motor side, 4x2.5 sqr.mm, used for 1PH7103 |
6FX5002-5CS12-1BA0 Power cable for 1FT/1FK/1PH spindle motor,10M, open connection in motor side, 4x2.5 sqr.mm,used for 1PH7103 |
6FX5002-5CS12-1BF0 Power cable for 1FT/1FK/1PH spindle motor,15M, open connection in motor side, 4x2.5 sqr.mm,used for 1PH7103 |
6FX5002-5CS31-1AF0 Power cable for 27NM,5M |
6FX5002-5CS31-1BA0 Power cable for 27NM,10M |
6FX5002-5CS31-1BF0 Power cable for 27NM,15M |
6FX5002-5CS41-1AF0 Power cable for 36NM,5M |
6FX5002-5CS41-1BA0 Power cable for 36NM,10M |
6FX5002-5CS41-1BF0 Power cable for 36NM,15M |
6FX5002-5CS42-1AF0 Power cable for 1FT/1FK/1PH spindle motor,5M, open connection in motor side, 4x4 sqr.mm, used for 1PH7107 |
6FX5002-5CS42-1BA0 Power cable for 1FT/1FK/1PH spindle motor,10M, open connection in motor side, 4x4 sqr.mm,used for 1PH7107 |
6FX5002-5CS42-1BF0 Power cable for 1FT/1FK/1PH spindle motor,15M, open connection in motor side, 4x4 sqr.mm,used for 1PH7107 |
6FX5002-5CS51-1AF0 Power cable for 45NM,5M |
6FX5002-5CS51-1BA0 Power cable for 45NM,10M |
6FX5002-5CS51-1BF0 Power cable for 45NM,15M |
6FX5002-5CS52-1AF0 Power cable for 1FT/1FK/1PH spindle motor,5M, open connection in motor side, 4x6 sqr.mm, used for 1PH7133-xxD02 |
6FX5002-5CS52-1BA0 Power cable for 1FT/1FK/1PH spindle motor,10M, open connection in motor side, 4x6 sqr.mm, used for 1PH7133-xxD02 |
6FX5002-5CS52-1BF0 Power cable for 1FT/1FK/1PH spindle motor,15M, open connection in motor side, 4x6 sqr.mm, used for 1PH7133-xxD02 |
6FX5002-5DA01-1AF0 power cable for 3.2-16NM,5M |
6FX5002-5DA11-1AF0 power cable for 18 Nm motor,5M,brake |
- 电话:010-88603269/65431486/654334982
- 传真:010-65431486-8005
- email:dachenghengye@yahoo.con
更多内容请访问 dachenghengye(http://home.gongkong.com/profile/?uid=2008070812083700001)
上一篇:西门子编程电缆6FX2001-3EB02 6FX2001-3EC50 6FX2001-7KF10
下一篇:西门子编程电缆6FX5002-5DA11-1BA0 6FX5002-5DA41-1BA0 6FX5002-5DA51-1AF0
相关推荐
