西门子编程电缆6FX8002-4AA21-1BA0 6FX8002-4AA21-1AF0 6FX8002-2CA11-1AF0
供稿:dachenghengye 2009/1/10 23:08:06
人气:281
- 型号:6FX6002-3AD02-1AH0 6FX6002-2CF02-1BF0
- 数量:大量
- 制造商:德国
- 有效期:2024/1/31 0:00:00
天津大成恒业机电设备有限公司 010-88603269/65431486
西门子编程电缆大量现货
6FX6002-2CA31-1CA0 signal cable,20M |
6FX6002-2CF02-1AF0 signal cable,5M 611U-Motor |
6FX6002-2CF02-1BA0 signal cable,10M 611U-Motor |
6FX6002-2CF02-1BF0 signal cable,15M 611U-Motor |
6FX6002-2CJ10-1AH0 Signal cable,611U-802C BL(7M) |
6FX6002-3AD02-1AH0 Cable 802S Base Line -STEPDRIVE C (7m)] |
6FX6002-3BA31-1AD0 Cable 802S, BETW. ENC and CONVERTER L=3M |
6FX6002-5AA51-1AB0 SINUMERIK 802S CABLE BETW. STEPDRIVE AND STEPPER MOTOR L= 1 m |
6FX6002-5AA51-1AD0 SINUMERIK 802S CABLE BETW. STEPDRIVE AND STEPPER MOTOR L= 3 m |
6FX6002-5AA51-1AF0 SINUMERIK 802S CABLE BETW. STEPDRIVE AND STEPPER MOTOR L= 5 m |
6FX6002-5AA51-1AH0 SINUMERIK 802S CABLE BETW. STEPDRIVE AND STEPPER MOTOR L= 7 m |
6FX6002-5AA51-1BA0 SINUMERIK 802S CABLE BETW. STEPDRIVE AND STEPPER MOTOR L= 10 m |
6FX6002-5AA51-1BF0 SINUMERIK 802S CABLE BETW. STEPDRIVE AND STEPPER MOTOR L= 15 m |
6FX6002-5CA01-1AF0 power cable for 3,2-18 Nm motor,5M |
6FX6002-5CA01-1AG0 power cable for 3,2-16 Nm motor,6M |
6FX6002-5CA01-1AH0 power cable for 3,2-16 Nm motor,7M |
6FX6002-5CA01-1AJ0 power cable for 3,2-16 Nm motor,8M |
6FX6002-5CA01-1BA0 power cable for 3,2-18 Nm motor,10M |
6FX6002-5CA01-1BC0 power cable for 3,2-16 Nm motor,12M |
6FX6002-5CA01-1BF0 power cable for 3,2-18 Nm motor,15M |
6FX6002-5CA01-1CA0 power cable for 3,2-16 Nm motor,20M |
6FX6002-5DA01-1AD0 power cable for 3,2-16 Nm motor,3M |
6FX6002-5DA01-1AE0 power cable for 3,2-16 Nm motor,4M |
6FX6002-5DA01-1AF0 power cable for 3,2-16 Nm motor,5M,brake |
6FX6002-5DA01-1AH0 power cable for 3,2-16 Nm motor,7M,brake |
6FX6002-5DA01-1BA0 power cable for 3,2-16 Nm motor,10M,brake |
6FX6002-5DA01-1BF0 power cable for 3,2-18 Nm motor,15M,brake |
6FX8002-2BA00-1BA0 SIGNAL CABLE, 4X2X0.34+4X0.5C 611 TO CONTROL VALVE L=10M |
6FX8002-2BA02-1AF0 command cable for HLA/ANA L=5m |
6FX8002-2CA11-1AF0 SIGNAL CABLE,(SIMODRIVE TO SINUS ENC. 1Vpp) 4X2X0.34+4X0.5 C, L=5M |
6FX8002-2CD01-1AF0 SIGNAL CABLE, (INCR. ENCODER TTL 6FX2001-2) 4X2X0.34+4X0.5 C, L=5M |
6FX8002-4AA21-1AF0 Pre-assembled cable for Handwheel L=5M |
6FX8002-4AA21-1BA0 Pre-assembled cable for Handwheel L=10M |
6FX8008-1BD61-1FA0 handwheel cable (50M) |
6GK1551-2AA00 SIMATIC NET CP5512 PG-Profibus or MPI |
6MM-6MM SPRING DISK COUPLING |
6SC6100-0AB00 SIMODRIVE 610 G20 DC-link Voltage Limitation |
6SC6100-0GC14 SIMODRIVE 650 POWER SUPPLY FOR 6SC6502/03-4AA01/02 |
6SC6100-0NA11 SIMODRIVE 610 AC FEED DRIVE, CLOSED-LOOP CONTROL 2-AXES, N12 |
6SE3214-0DA40 MICR.masterVECTOR MMV150/3, 3AC 380-500+/-10%, 1.5KW |
6SE6400-0BP00-0AA0 MICR.master4 BASIC OPERATOR PANEL [BOP] |
6SL3000-0CE15-0AA0 SINAMICS SMART Line reactor for 5KW |
6SL3000-0CE21-0AA0 SINAMICS SMART Line reactor for 10KW |
6SL3055-0AA00-5BA1 SMC20 Sensor Module for external incremental encoder:SIN/COS 1Vpp absolute encoder: ENDAT without DRIVE-CLIQ cable |
6SL3055-0AA00-5CA0 SMC30 Sensor Module for external encoder(without DRIVE-CLiQ cable) |
6SL3060-4AD00-0AA0 Drive CLiQ cable(0.16m), IP20/20 |
6SL3060-4AF00-0AA0 Drive CLiQ cable(0.21m), IP20/20 |
- 电话:010-88603269/65431486/654334982
- 传真:010-65431486-8005
- email:dachenghengye@yahoo.con
更多内容请访问 dachenghengye(http://home.gongkong.com/profile/?uid=2008070812083700001)
上一篇:西门子编程电缆6FX5002-5DA11-1BA0 6FX5002-5DA41-1BA0 6FX5002-5DA51-1AF0
下一篇:西门子变频器配件6SL3060-4AH00-0AA0 6SL3100-1BE22-5AA0 6SL3120-1TE13-0AA0
