西门子变频器配件6SL3060-4AH00-0AA0 6SL3100-1BE22-5AA0 6SL3120-1TE13-0AA0
供稿:dachenghengye 2009/1/10 23:18:24
人气:246
- 型号:6SL3121-2TE21-8AA0 6SL3130-6AE15-0AA0 6SL3130-7TE21-6AA1
- 数量:大量
- 制造商:德国
- 有效期:2027/1/31 0:00:00
天津大成恒业机电设备有限公司 010-88603269/65431486
大量现货,价格从优
6SL3060-4AH00-0AA0 Drive CLiQ cable(0.26m), IP20/20 |
6SL3060-4AU00-0AA0 Drive CLiQ cable(0.6m), IP20/20 |
6SL3100-1AE31-0AA0 SINAMIC Braking Module,1.5KW |
6SL3100-1BE22-5AA0 "SINAMICS pulsed resistor plus,600V,15.6OHM |
control power module for voltage monitoring " |
6SL3100-1BE31-0AA0 SINAMIC Braking resistor,1.5KW/100KW |
6SL3100-1CE14-0AA0 SINAMIC SCAPACITOR MODULEINPUT: 600 V DC4000 UF |
6SL3120-1TE13-0AA0 SINAMIC Single Motor Moudule, 3A/1.6Kw,internal cooling |
6SL3120-1TE15-0AA0 SINAMIC Single Motor Moudule, 5A/2.7Kw,internal cooling |
6SL3120-1TE21-0AA1 SINAMIC Single Motor Moudule, 9A/4.8Kw,internal cooling |
6SL3120-1TE21-8AA1 SINAMIC Single Motor Moudule, 18A/9.7Kw,internal cooling |
6SL3120-1TE23-0AA1 SINAMIC Single Motor Moudule, 30A/16Kw, internal cooling |
6SL3120-2TE13-0AA0 SINAMIC Double Motor Moudle,2*3A/1.6Kw,internal cooling |
6SL3120-2TE15-0AA0 SINAMIC Double Motor Moudle,2*5A/2.7Kw,internal cooling |
6SL3120-2TE21-0AA0 SINAMIC Double Motor Moudle,2*9A/4.8Kw,internal cooling |
6SL3120-2TE21-8AA0 SINAMIC Double Motor Moudle,2*18A/9.7Kw, internal cooling |
6SL3121-1TE13-0AA0 SINAMIC Single Motor Moudule, 3A/1.6Kw,external cooling |
6SL3121-1TE15-0AA0 SINAMIC Single Motor Moudule, 5A/2.7Kw,external cooling |
6SL3121-1TE21-0AA0 SINAMIC Single Motor Moudule, 9A/4.8Kw,external cooling |
6SL3121-1TE21-8AA0 SINAMIC Single Motor Moudule, 18A/9.7Kw,external cooling |
6SL3121-1TE23-0AA0 SINAMIC Single Motor Moudule, 30A/16Kw,external cooling |
6SL3121-2TE13-0AA0 SINAMIC Double Motor Moudle,2*3A/1.6Kw,external cooling |
6SL3121-2TE15-0AA0 SINAMIC Double Motor Moudle,2*5A/2.7Kw,external cooling |
6SL3121-2TE21-0AA0 SINAMIC Double Motor Moudle,2*9A/4.8Kw,external cooling |
6SL3121-2TE21-8AA0 SINAMIC Double Motor Moudle,2*18A/ 7Kw,external cooling |
6SL3130-6AE15-0AA0 SINAMICS SMART Line module, 5KW,internal cooling |
6SL3130-6AE21-0AA0 SINAMICS SMART Line module, 10KW,internal cooling |
6SL3130-7TE21-6AA1 SINAMICS ACTIVE Line module, 16KW,internal cooling |
6SL3130-7TE23-6AA1 SINAMICS ACTIVE Line module, 36KW,internal cooling |
6SL3131-6AE15-0AA0 SINAMICS SMART Line module, 5KW,external cooling |
6SL3131-6AE21-0AA0 SINAMICS SMART Line module, 10KW,external cooling |
6SL3131-7TE21-6AA0 SINAMICS ACTIVE Line module, 16KW,external cooling |
6SL3131-7TE23-6AA0 SINAMICS ACTIVE Line module, 36KW,external cooling |
6SL3162-1AF00-0AA0 SINAMICSSHIELD CONNECTION PLATEFOR 150 MMLINE/MOTOR MODULES |
6SL3162-1AH00-0AA0 SINAMICSSHIELD CONNECTION PLATEFOR 300 MMLINE/MOTOR MODULES |
6SL3162-1AH01-0AA0 SINAMICSSHIELD CONNECTION PLATEFOR 200 MMLINE/MOTOR MODULES |
6SL3162-2AA00-0AA0 SINAMICS24 V TERMINAL ADAPTERFOR MODULES IN BOOKSIZE DESIGN |
6SL3162-2BD00-0AA0 SINAMICSDC LINK RECTIFIER ADAPTERFOR DIRECT INFEEDSCREW TERMINALS 0.5-10 MM2FOR 50 AND 100 MMLINE/MOTOR MODULESIN BOOKSIZE FORMAT |
6SL3162-2BM00-0AA0 SINAMICSDC LINK RECTIFIER ADAPTERFOR DIRECT INFEEDSCREW TERMINALS 35-95 MM2FOR 150, 200 AND 300 MMLINE/MOTOR MODULESIN BOOKSIZE FORMAT |
6SL3162-2BM01-0AA0 SINAMICSDC LINK ADAPTERFOR MULTI-TIER DESIGNSCREW TERMINALS 35-95 SQMMFOR ALLLINE/MOTOR MODULESIN BOOKSIZE FORMAT |
6SL3166-3AB00-0AA0 SINAMICSWARNING LABELSFOR SINAMICS MODULEIN BOOKSIZE DESIGN1 SHEET, 12 LANGUAGES |
- 电话:010-88603269/65431486/654334982
- 传真:010-65431486-8005
- email:dachenghengye@yahoo.con
更多内容请访问 dachenghengye(http://home.gongkong.com/profile/?uid=2008070812083700001)
上一篇:西门子编程电缆6FX8002-4AA21-1BA0 6FX8002-4AA21-1AF0 6FX8002-2CA11-1AF0
下一篇:SUNX 神视光电传感器CX-421,CX-421,CX-421,CX-421,CX-M10P,CX-421,CX-421
