当前页面: 首页 >供求信息 >BAY52—Q/CBQY防爆防腐全塑荧光灯
2009/3/17 9:55:42
0 人气:22
  • 型号:CBQY
  • 数量:10000
  • 制造商:旭升照明有限公司
  • 有效期:2018/3/22 0:00:00
产品名称:  CBQY系列防爆防腐全塑荧光灯(ⅡC)
 适用范围 Application
1区,2区、20区、21区、22区危险场所。
ⅡA、ⅡB、ⅡC类爆炸性气体环境。
适用于可燃性粉尘场所。
Zone 1、Zone 2、Zone21 and Zone
   22 hazardous areas.
Can be used in IIA、IIB、IIC
  groups edplosive atmosphere
  mixture.
Can be used in flammable dust areas.
 型号含义 Model implication
 产品特点 Features
◆玻璃纤维增强不饱和聚脂模压成型外壳,具有强度高耐冲击,
    耐腐蚀等优良性能。
◆外壳为增安型结构,具有防水、防尘等优点。
◆内置开关采用防爆元件,当产品打开时能自动切断电源。
◆内装单脚灯管、快速瞬时启动,可根据用户要求改装双 脚灯管。
◆可根据用户要求配带应急装置。
电缆或钢管布线均可。
●The glass fiber strengthen unsaturated polyester mould pressing shape
    outer covering.Have the strength high,bear the impact and bear the
    good function in etc.in corrosion.
●Polycarbonate transparent chimney.
●The outer shell is for increasing the peaceful type construction,having
    the wate rtightness,dust palliative..etc.advantage.
●The inside places the switch adoption flameproof a piece,be the product
    open can cut off the power supply automatically.
●Single footlights tube installed inside,starting with fast instantaneous.
●Canrefit the one foot light tube according to the customer request.
●The emergency device can be provided according to user's request.
●Wiring by cable or steel pipe.
 主要技术参数 Main technical parameters
         防爆标志          额定电压(v)               防护等级            电缆外径(¢,mm)         进线口螺纹(G")            防腐等级
         Ex-mark      Rated voltage            Protection       Cable's outside          Inlet's thread     Corrosion-Proofing
        diameter                                                         grode
        Exd ⅡCT6             220                        IP65                   10~14                        3/4                        WF2
 配用光源 Supplied with light source
        配用光源 Supplied with light source            2x20W           1x40W            2X40W
           壳体类别 Type of shell                                          I                                          II                                           II
 应急装置参数 Emergency equippment parameters
              应急起动时间(s)                                              充电时间(h)                                          应急照明时间(min)
        Starting duration in Emergency                                 Charging time                                 Lighting time in Emergency
                               0.3        24        90
 外形及安装举例 Outline example
              护栏式(h) Fence type                           法兰式(f) Flange type
               壁式(b) Bracket type                                         吊杆式(g) Pendant type
型号 Type             A            B         C          D
CBQY-2X20         780        150        196      500
CBQY-2X40         1340       160      196      800
                  吸顶式(x) Ceiling type
       序号 No.                                     名称 Name                                               备注 Remark              号 No.          名称 Name                  备注 Remark
             1            防爆荧光灯(CBQY)Explosion-proof fluorescent lamp                                                     13          吸盘 Sucker                             3/4"
             2            安装架 Mounting  rack        14          直杆 Pole                                 3/4"
             3         管夹 Pinpe clamp        15        联轴器 Coupler
            4         弯管Bended pipe        16       固定板 Fasten plate             用户自备
           5         异形接头Reduction Connector        17       活接头Active connector
           6         立杆 Pipe        1'/4"                             18         安装架Mounting bracket
           7       活接头Active connector        1'/2"                             19      吊环螺钉 M6 x 12Eyebolt
           8       接线盒(CBJH51-3/4C) Junction box                                                用户另配                        20       挂钩  Hook
          9       U型管夹 U Type pinpe clamp                                                       用户自备                          21       链条 Chain
          10       挠性连接管 Flexible Connector                                                      用户自备                         22
膨胀螺钉 Expand bolt
         11       立柱 Pipe        23      安装脚配件 Mounting base
          12
      安装架 Mounting rack
  • 电话:13867778538
  • 传真:057762128889
  • email:joukwu@126.com
工控宝APP下载安装
