- 数量:10
- 有效期:2022/12/31 0:00:00
郑州高恩供应三菱FX系列可编程控制器(PLC)
FX1N-14MR-001 BASE UNIT WITH 8 INPUTS/6 TRANSISTOR OUTPUTS 2,310.00
FX1N-14MT-001 BASE UNIT WITH 8 INPUTS/6 TRANSISTOR OUTPUTS 2,400.00
FX1N-1DA-BD 1 CHANNEL D/A 1,170.00
FX1N-232-BD RS-232C SERIAL PORT (1 CH) 390.00
FX1N-24MR-001 BASE UNIT WITH 14 INPUTS/10 RELAY OUTPUTS 3,330.00
FX1N-24MR-D BASE UNIT WITH 14 INPUTS/10 RELAY OUTPUTS 2,990.00
FX1N-24MT-001 BASE UNIT WITH 14 INPUTS/10 RELAY OUTPUTS 3,400.00
FX1N-24MT-D BASE UNIT WITH 14 INPUTS/10 RELAY OUTPUTS 3,100.00
FX1N-2AD-BD 2 CHANNELS A/D 1,170.00
FX1N-2EYT-BD EXT. BOARD WITH 2 TRANSISTOR OUTPUTS 470.00
FX1N-40MR-001 BASE UNIT WITH 24 INPUTS/16 RELAY OUTPUTS 4,030.00
FX1N-40MR-D BASE UNIT WITH 24 INPUTS/16 RELAY OUTPUTS 4,010.00
FX1N-40MT-001 BASE UNIT WITH 24 INPUTS/16 RELAY OUTPUTS 4,130.00
FX1N-40MT-D BASE UNIT WITH 24 INPUTS/16 TRANSISTOR OUTPUTS 4,100.00
FX1N-422-BD RS-485 SERIAL PORT (1 CH) 390.00
FX1N-485-BD RS-422 SERIAL PORT (1 CH) 390.00
FX1N-4EX-BD EXT. BOARD WITH 4 INPUTS 470.00
FX1N-5DM DISPLAY MODULE FOR FX1S/1N PLC 450.00
FX1N-60MR-001 BASE UNIT WITH 36 INPUTS/24 RELAY OUTPUTS 4,680.00
FX1N-60MR-D BASE UNIT WITH 36 INPUTS/24 RELAY OUTPUTS 4,490.00
FX1N-60MT-001 BASE UNIT WITH 36 INPUTS/24 RELAY OUTPUTS 4,800.00
FX1N-60MT-D BASE UNIT WITH 36 INPUTS/24 TRANSISTOR OUTPUTS 4,600.00
FX1N-8AV-BD MANUALLY ADJUSTABLE POTENTIOMETER INPUT BOARDS 390.00
FX1NC-16MT BASE UNIT WITH 8 INPUTS/8 TRANISITOR OUTPUTS 2,550.00
FX1NC-32MT BASE UNIT WITH 16 INPUTS/16 TRANISITOR OUTPUTS 3,550.00
FX1N-CNV-BD FX0N MODULE TRANSFORM UNIT 390.00
FX1N-EEPROM-8L PLC PROGRAM TRANSFER UNIT 710.00
FX1S-10MR-001 BASE UNIT WITH 6 INPUTS/4 RELAY OUTPUTS 1,580.00
FX1S-10MR-D BASE UNIT WITH 6 INPUTS/4 RELAY OUTPUTS 1,530.00
FX1S-10MT-001 BASE UNIT WITH 6 INPUTS/4 TRANSISTOR OUTPUTS 1,620.00
FX1S-10MT-D BASE UNIT WITH 6 INPUTS/4 TRANSISTOR OUTPUTS 1,570.00
FX1S-14MR-001 BASE UNIT WITH 8 INPUTS/6 RELAY OUTPUTS 1,850.00
FX1S-14MR-D BASE UNIT WITH 8 INPUTS/6 RELAY OUTPUTS 1,850.00
FX1S-14MT-001 BASE UNIT WITH 8 INPUTS/6 TRANSISTOR OUTPUTS 1,900.00
FX1S-14MT-D BASE UNIT WITH 8 INPUTS/6 TRANSISTOR OUTPUTS 1,900.00
FX1S-20MR-001 BASE UNIT WITH 12 INPUTS/8 RELAY OUTPUTS 2,350.00
FX1S-20MR-D BASE UNIT WITH 12 INPUTS/8 RELAY OUTPUTS 2,230.00
FX1S-20MT-001 BASE UNIT WITH 12 INPUTS/8 TRANSISTOR OUTPUTS 2,410.00
FX1S-20MT-D BASE UNIT WITH 12 INPUTS/8 TRANSISTOR OUTPUTS 2,300.00
FX1S-30MR-001 BASE UNIT WITH 16 INPUTS/14 RELAY OUTPUTS 2,870.00
FX1S-30MR-D BASE UNIT WITH 16 INPUTS/14 RELAY OUTPUTS 2,720.00
FX1S-30MT-001 BASE UNIT WITH 16 INPUTS/14 TRANSISTOR OUTPUTS 2,940.00
FX1S-30MT-D BASE UNIT WITH 16 INPUTS/14 TRANSISTOR OUTPUTS 2,800.00
FX-20P-ADP-KIT OFFLINE PROGRAMMING ADAPTOR 1,480.00
FX-20P-CADP UNIVERSAL ADAPTOR CABLE 0.3M 250.00
FX-20P-E-SET0 HANDY PROGRAMMING PANEL FOR FX0S,FX0N,FX2N SERIES CPU 2,740.00
FX-20P-RWM ROM WRITER FOR FX-20P-E 3,380.00
FX-232CAB-1 DATA TRANSFER CABLE BETWEEN COMPUTER AND FGOT 1,140.00
FX-25DU-E DATA ACCESS UNIT (LCD GRAPHIC TYPE) 5,400.00
FX2N-10GM 1 AXIS POSITION CONTROL UNIT 4,480.00
FX2N-10PG PULSE TRAIN OUTPUT BLOCK (1 CH-1MHz) 5,250.00
FX2N-128MR-001 BASE UNIT WITH 64 INPUTS/64 RELAY OUTPUTS 10,120.00
FX2N-128MT-001 BASE UNIT WITH 64 INPUTS/64 TRANSISTOR OUTPUTS 10,330.00
FX2N-16CCL-M COMPUTER AND COMMUNICATION LINKmasterBLOCK 2,700.00
FX2N-16EX EXTENSION UNIT WITH 16 INPUTS 1,370.00
FX2N-16EYR EXTENSION UNIT WITH 8 RELAY OUTPUTS 1,530.00
FX2N-16EYT EXTENSION UNIT WITH 8 TRANSISTOR OUTPUTS 1,530.00
FX2N-16LNK-M REMOTE I/O SYSTEMmasterBLOCK 2,160.00
FX2N-16MR-001 BASE UNIT WITH 8 INPUTS/8 RELAY OUTPUTS 4,150.00
FX2N-16MT-001 BASE UNIT WITH 8 INPUTS/8 TRANSISTOR OUTPUTS 4,240.00
FX2N-1HC HIGH SPEED COUNTER BLOCK (1 CH) 3,170.00
FX2N-1PG-E PULSE TRAIN OUTPUT BLOCK (1 CH-100KHz) 4,270.00
FX2N-1RM-E-SET PROGRAMMABLE CAM MODULE INCLUDE RESOLVER 8,770.00
FX2N-20GM 2 AXIS POSITION CONTROL UNIT 8,860.00
FX2N-232-BD RS-232C SERIAL PORT (1 CH) 400.00
FX2N-232IF RS-232 COMMUNICATION BLOCK (1 CH) 4,480.00
FX2N-2AD 2 CHANNELS A/D 1,740.00
FX2N-2DA 2 CHANNELS D/A 2,100.00
FX2N-2LC 2 CHANNELS TEMPERATURE CONTROL BLOCK 4,450.00
FX2N-32ASI-M AS-INTERFACEmasterBLOCK 4,230.00
FX2N-32CCL COMPUTER AND COMMUNICATION LINK INTERFACE BLOCK 2,490.00
FX2N-32ER EXTENSION UNIT WITH 16 INPUTS/16 RELAY OUTPUTS 3,060.00
FX2N-32ET EXTENSION UNIT WITH 16 INPUTS/16 TRANSISTOR OUTPUTS 3,060.00
FX2N-32MR-001 BASE UNIT WITH 16 INPUTS/16 RELAY OUTPUTS 5,180.00
FX2N-32MR-D BASE UNIT WITH 16 INPUTS/16 RELAY OUTPUTS 5,180.00
FX2N-32MT-001 BASE UNIT WITH 16 INPUTS/16 TRANSISTOR OUTPUTS 5,290.00
FX2N-422-BD RS-422 SERIAL PORT (1 CH) 400.00
FX2N-485-BD RS-485 SERIAL PORT (1 CH) 400.00
FX2N-48ER EXTENSION UNIT WITH 24 INPUTS/24 RELAY OUTPUTS 4,190.00
FX2N-48ET EXTENSION UNIT WITH 24 INPUTS/24 TRANSISTOR OUTPUTS 4,190.00
FX2N-48MR-001 BASE UNIT WITH 24 INPUTS/24 RELAY OUTPUTS 5,490.00
FX2N-48MR-D BASE UNIT WITH 24 INPUTS/24 RELAY OUTPUTS 5,490.00
FX2N-48MT-001 BASE UNIT WITH 24 INPUTS/24 TRANSISTOR OUTPUTS 5,600.00
FX2N-4AD 4 CHANNELS A/D 2,310.00
FX2N-4AD-PT 4 CHANNELS TEMPERATURE INPUTS, PT TYPE 3,270.00
FX2N-4AD-TC 4 CHANNELS TEMPERATURE INPUTS, THERMAL COUPLE TYPE 3,270.00
FX2N-4DA 4 CHANNELS D/A 3,270.00
FX2N-5A 4 CHANNEL A/D, 1 CHANNEL D/A 3,400.00
FX2N-64MR-001 BASE UNIT WITH 32 INPUTS/32 RELAY OUTPUTS 6,280.00
FX2N-64MR-D BASE UNIT WITH 32 INPUTS/32 RELAY OUTPUTS 6,280.00
FX2N-64MT-001 BASE UNIT WITH 32 INPUTS/32 TRANSISTOR OUTPUTS 6,410.00
FX2N-80MR-001 BASE UNIT WITH 40 INPUTS/40 RELAY OUTPUTS 7,030.00
FX2N-80MR-D BASE UNIT WITH 40 INPUTS/40 RELAY OUTPUTS 7,030.00
FX2N-80MT-001 BASE UNIT WITH 40 INPUTS/40 TRANSISTOR OUTPUTS 7,180.00
FX2N-8AD 8 CHANNELS A/D 7,630.00
FX2N-8AV-BD MANUALLY ADJUSTABLE POTENTIOMETER INPUT BOARDS 400.00
FX2NC-16EX EXTENSION UNIT WITH 16 INPUTS 1,360.00
FX2NC-16EX-T EXTENSION UNIT WITH 16 INPUTS 1,080.00
FX2NC-16EYR-T EXTENSION UNIT WITH 8 RELAY OUTPUTS 1,320.00
FX2NC-16EYT EXTENSION UNIT WITH 16 TRANSISTOR OUTPUTS 1,660.00
FX2NC-16MT BASE UNIT WITH 8 INPUTS/8 TRANISITOR OUTPUTS 3,220.00
FX2NC-32BL BATTERY FOR F930GOT(-K)/ HANDY GOT 330.00
FX2NC-32EX EXTENSION UNIT WITH 32 INPUTS 2,410.00
FX2NC-32EYT EXTENSION UNIT WITH 32 TRANSISTOR OUTPUTS 2,560.00
FX2NC-32MT BASE UNIT WITH 16 INPUTS/16 TRANISITOR OUTPUTS 4,230.00
FX2NC-64MT BASE UNIT WITH 32 INPUTS/32 TRANISITOR OUTPUTS 6,610.00
FX2NC-96MT BASE UNIT WITH 48 INPUTS/48 TRANISITOR OUTPUTS 8,760.00
FX2N-CNV-BC EXTENSION CABLE CONVERTOR 400.00
FX2N-CNV-BD FX0N MODULE TRANSFORM UNIT 400.00
FX2N-CNV-IF EXTENSION CABLE CONVERTOR (FX2 TO FX2N) 400.00
FX2N-ROM-E1 INVERTER INSTRUCTION CASSETTE 1,460.00
FX2N-RS-5CAB SIGNAL CABLE BETWEEN FX2N-1RM AND F2-720RSV 620.00
FX-2PIF 2 TO 1 INTERFACE FOR FX-20P-E, DATA ACCESS UNIT AND FX PLC 4,490.00
FX-30DU-E DATA ACCESS UNIT (LCD GRAPHIC TYPE) 6,590.00
FX3U-232ADP RS232 COMMUNICATION MODULE 1,590.00
FX3U-232-BD RS-232C SERIAL PORT (1 CH) 590.00
FX3U-32BL BACKUP BATTERY FOR FX3UC CPU 470.00
FX3U-425-BD RS-422 SERIAL PORT (1 CH) 590.00
FX3U-485ADP RS485 COMMUNICATION MODULE WITH MULTI-DROP FUNCTION 1,590.00
FX3U-485-BD RS-485 SERIAL PORT (1 CH) 590.00
FX3U-4AD-ADP 4 CHANNELS A/D 6,810.00
FX3U-4AD-PT-ADP 4 CHANNELS TEMPERATURE INPUTS, PT TYPE 3,490.00
FX3U-4AD-TC-ADP 4 CHANNELS TEMPERATURE INPUTS, THERMAL COUPLE TYPE 3,490.00
FX3U-4DA-ADP 4 CHANNELS D/A 6,810.00
FX3U-7DM-HLD DISPLAY PANEL HOLDER 700.00
FX3UC-1PS-5V DC 5V 2A POWER SUPPLY UNIT 1,880.00
FX3UC-32MT-LT BASE UNIT WITH 16 INPUTS/16 TRANSISTOR OUTPUTS 9,400.00
FX3UC-4AD 4 CHANNELS A/D (16BIT) 2,590.00
FX3U-CNV-BD FX3U MODULE TRANSFORM UNIT 350.00
FX3U-FLROM-64 64K FLASH ROM MEMORY CASSETTE 2,350.00
FX3U-USB-BD USB COMMUNICATION PORT (FOR ALL FX SERIES PLC) 1,170.00
FX-40CRW-E SERIAL TYPE ROM WRITER FOR DATA ACCESS UNIT 9,830.00
FX-485PC-IF RS232/RS485 CONVERTER 1,360.00
FX-EEPROM-16 16K EEPROM MEMORY CASSETTE 1,020.00
FX-EEPROM-4 4K EEPROM MEMORY CASSETTE 490.00
FX-EEPROM-4C 4K EEPROM MEMORY CASSETTE WITH REAL TIME CLOCK 620.00
FX-EEPROM-8 8K EEPROM MEMORY CASSETTE 620.00
FX-EEPROM-8C 8K EEPROM MEMORY CASSETTE WITH REAL TIME CLOCK 1,010.00
FX-EPROM-8 8K EPROM MEMORY CASSETTE 490.00
FX-PCS/WIN-C PROGRAMMING SOFTWARE FOR WINDOW (CHINESE) 950.00
FX-PCS/WIN-C-SET WINDOWS PROGRAMMING SOFTWARE WITH MANUAL & SC09 2,630.00
FX-PCS/WIN-E PROGRAMMING SOFTWARE FOR WINDOW (ENGLISH) 950.00
FX-PCS-VPS/WIN-E GM GRAPHICAL PROGRAMMING SOFTWARE 1,070.00
FX-RAM-8 8K RAM MEMORY CASSETTE 550.00
FX-RAM-8C 8K RAM MEMORY CASSETTE WITH REAL TIME CLOCK 810.00
FX-RTC REAL TIME CLOCK 450.00
FX-USB-AW RS422/USB CONVERTER, USB CABLE AND DRIVER SOFTWARE 2,300.00
- 电话:0371-63897587
- 传真:0371-63897587
- email:weiyanbo03@gmail.com
