- 数量:10
- 有效期:2054/12/31 0:00:00
郑州高恩供应Q系列PLC
QX10 100-120VAC/7-8mA, 16pt 1,680.00
QX28 240VAC, 8pt 1,120.00
QX40 240VAC/4mA, POSITIVE COMMON INPUT, 16pt 1,600.00
QX40-S1 24VDC, POSITIVE COMMON INPUT, 16pt (HIGH SPEED) 1,680.00
QX41 24VDC, POSITIVE COMMON INPUT, 32pt 2,780.00
QX41-S1 24VDC, POSITIVE COMMON HIGH-SPEED INPUT, 32pt 2,780.00
QX42 24VDC, POSITIVE COMMON INPUT, 64pt 4,460.00
QX42-S1 24VDC, POSITIVE COMMON HIGH-SPEED INPUT, 64pt 4,460.00
QX48Y57 24VDC POSITIVE COMMON INPUT, 8pt, OUTPUT: 7pt 1,680.00a
QX70 5-12VDC INPUT, POSITIVE AND NEGATIVE COMMON INPUT, 16pt 2,250.00
QX71 5-12VDC INPUT, POSITIVE AND NEGATIVE COMMON INPUT, 32pt 3,030.00
QX72 5-12VDC INPUT, POSITIVE AND NEGATIVE COMMON INPUT, 64pt 4,720.00
QX80 24VDC/4mA. NEGATIVE COMMON INPUT, 16pt, TERMINAL BLOCK 2,020.00
QX81 24VDC/4mA. NEGATIVE COMMON INPUT, 16pt, CONNECTOR 3,450.00
QY10 240VAC/24VAC, 16pt, WITHOUT FUSE 2,190.00
QY18A 240VAC/24VAC, 2A, 8 INDEPENDENT OUTPUT 2,030.00
QY22 240VAC/0.6A, 16pt, WITHOUT FUSE 2,700.00
QY40P 12/24VDC, 16pt, WITH SHORT-CIRCUIT PROTECTION 1,600.00
QY41P 12/24VDC, 32pt, WITH SHORT-CIRCUIT PROTECTION 2,780.00
QY42P 12/24VDC, 64pt, WITH SHORT-CIRCUIT PROTECTION 4,460.00
QY50 12/24VDC, 16pt, WITH FUSE 1,680.00
QY68A 5-24VDC, 8pt, WITHOUT FUSE 2,360.00
QY70 5/12VDC, 16pt, WITHOUT FUSE 2,150.00
QY71 5/12VDC, 32pt, WITHOUT FUSE 2,780.00
QY80 12/24VDC, 16pt, WITHOUT FUSE 2,190.00
QY81P 12/24VDC, 32pt, WITH SHORT-CIRCUIT PROTECTION 3,790.00
Q2MEM-BAT REPLACEMENT BATTERY, FOR Q2MEM-1MBS 220.00
Q312B POWER SUPPLY + CPU + 12 SLOTS FOR Q SERIES I/O, CE/UL/cUL 2,370.00
Q33B POWER SUPPLY + CPU + 3 SLOTS FOR Q SERIES I/O, CE/UL/cUL 1,250.00
Q35B POWER SUPPLY + CPU + 5 SLOTS FOR Q SERIES I/O, CE/UL/cUL 1,310.00
Q38B POWER SUPPLY + CPU + 8 SLOTS FOR Q SERIES I/O, CE/UL/cUL 1,870.00
Q3ACPU 2048PT., 92K STEP, 0.15μS/STEP 36,270.00
Q4ACPU 4096PT., 124K STEP, 0.075 μS/STEP 41,560.00
Q4ARCPU 4096PT., 124K STEP, 0.075 μS/STEP, HOTSTANDBY 46,220.00
Q52B 2 I/O SLOTS, FOR Q SERIES MODULE (NO NEED POWER SUPPLY) 1,120.00
Q55B 5 I/O SLOTS, FOR Q SERIES MODULE (NO NEED POWER SUPPLY) 1,310.00
Q612B POWER SUPPLY + 12 I/O SLOTS, FOR Q SERIES MODULE, CE/UL/cUL 2,500.00
Q61P-A1 100-120VAC INPUT/5VDC 6A OUTPUT, CE/UL/cUL 1,710.00
Q61P-A2 200-240VAC INPUT/5VDC 6A OUTPUT, CE/UL/cUL 1,710.00
Q62AD-DGH 2 CHANNELS, A/D CONVERSION, SIGNAL CONDITIONING FUNCTION 4,210.00
Q62DA 2 CHANNELS, D/A CONVERSION: VOLTAGE/CURRENT OUTPUT 4,210.00
Q62DA-FG 2 CHANNELS, D/A CONVERSION: V/I OUTPUT WITH MONITOR 5,620.00
Q62P 100-240VAC INPUT/5VDC 3A, 24VDC/0.6A OUTPUT 1,970.00
Q63B POWER SUPPLY + 3 I/O SLOTS, FOR Q SERIES MODULE, CE/UL/cUL 1,380.00
Q63P 24VDC INPUT/5VDC 6A OUTPUT 3,000.00
Q64AD 4 CHANNELS, A/D CONVERSION: VOLTAGE/CURRENT INPUT 4,210.00
Q64AD-GH 4 CHANNELS, A/D CONVERSION: VOLTAGE/CURRENT INPIT 6,090.00
Q64DA 4 CHANNELS, D/A CONVERSION: VOLTAGE/CURRENT OUTPUT 6,550.00
Q64P 100-120/200-240VAC INPUT/5VDC 8.5A OUTPUT 3,000.00
Q64RD 4 CHANNELS, PLATINUM RESIST. THERMO. INPUT 6,750.00
Q64TCRT PLATINUM RESIST. THERMO. INPUT 9,370.00
Q64TCRTBW PLAT. RESIST. THERMO. INPUT WITH SHORT CIRCUIT DETECTION 12,170.00
Q64TCTT THERMO-COUPLE INPUT - TRANS. OUTPUT 9,370.00
Q64TCTTBW THERMO-COUPLE INPUT WITH SHORT CIRCUIT DETECTION 12,170.00
Q64TD 4 CHANNELS, THERMO-COUPLE INPUT 11,240.00
Q64TDV-GH 4 CHANNELS, THERMO-COUPLE INPUT, MICRO VOLTAGE INPUT 5,620.00
Q65B POWER SUPPLY + 5 I/O SLOTS, FOR Q SERIES MODULE, CE/UL/cUL 1,440.00
Q68ADI 8 CHANNELS, A/D CONVERSION: CURRENT INPUT 4,880.00
Q68ADV 8 CHANNELS, A/D CONVERSION: VOLTAGE INPUT 4,880.00
Q68B POWER SUPPLY + 8 I/O SLOTS, FOR Q SERIES MODULE, CE/UL/cUL 2,000.00
Q68DAI 8 CHANNELS, D/A CONVERSION: CURRENT OUTPUT 8,420.00
Q68DAV 8 CHANNELS, D/A CONVERSION: VOLTAGE OUTPUT 8,420.00
Q6BAT REPLACEMENT BATTERY FOR MEMORY BACKUP 360.00
Q6BAT REPLACEMENT BATTERY FOR Q02/Q02H/Q06HCPU 360.00
Q6DIN1 DIN RAIL MOUNTING ADAPTER, FOR Q38B/Q312B/Q68B/Q612B 120.00
Q6DIN2 DIN RAIL MOUNTING ADAPTER, FOR Q35B/Q65B 90.00
Q6DIN3 DIN RAIL MOUNTING ADAPTER, FOR Q33B/Q63B 70.00
Q6PU PROGRAMMING PANEL 4,870.00
Q6TA32 FOR 32-POINT I/O, 0.5MM2 (AWG20) 620.00
Q6TA32-TOL TOOL EXCLUSIVELY USED FOR Q6TA32 90.00
Q80BD-J71BR11 MELSECNET/10H UNIT FOR COAXIAL CABLE 16,050.00
Q80BD-J71LP21-25 MELSECNET/10H UNIT FOR OPTICAL CABLE 16,050.00
Q80BD-J71LP21G MELSECNET/10H UNIT FOR SI/QSI/H-PC OPTICAL CABLE 22,290.00
QC05B 0.45m (1.48ft.) 580.00
QC06B 0.6m (1.96ft.) 620.00
QC06B 0.6m (1.97ft.) 620.00
QC100B 10m (32.8ft.) 3,570.00
QC100B 10m (32.79ft.) 3,570.00
QC12B 1.2m (3.93ft.) 890.00
QC30B 3m (9.84ft.) 1,430.00
QC30R2 RS-232 CABLE FOR THE CONNECTION BETWEEN PC AND PLC CPU 1,190.00
QC50B 5m (16.4ft.) 2,140.00
QC50B 5m (16.39ft.) 2,140.00
QD51 INTELLIGENT COMMUNICATION UNIT FOR RS232 2ch 10,700.00
QD51-R24 INTELLIGENT COMMUNICATION UNIT FOR RS-232 1ch, RS422/485 1ch 10,700.00
QD60P8-G 8 CHANNELS, 5/12 TO 24VDC INPUT, INPUT FILTER SETTING 13,370.00
QD62 2 CHANNELS, 200kpps, 5/12/24VDC INPUT, SINK TRANS. OUTPUT 6,690.00
QD62D 2 CHANNELS, 500kpps, DIFFERENTIAL INPUT, SINK TRANS. OUTPUT 7,130.00
QD62E 2 CHANNELS, 200kpps, 5/12/24VDC INPUT, SOURCE TRANS. OUTPUT 6,690.00
QD70P4 4 AXIS PULSE OUTPUT 10,700.00
QD70P8 8 AXIS PULSE OUTPUT 17,830.00
QD75D1 1 AXIS, DIFFERENTIAL OUTPUT 7,130.00
QD75D2 2 AXIS, DIFFERENTIAL OUTPUT 9,810.00
QD75D4 4 AXIS, DIFFERENTIAL OUTPUT 15,160.00
QD75M1 1 AXIS SSCNET COMPATIBLE 7,130.00
QD75M2 2 AXIS SSCNET COMPATIBLE 9,810.00
QD75M4 4 AXIS SSCNET COMPATIBLE 15,160.00
QD75P1 1 AXIS, OPEN COLLECTOR OUTPUT 6,240.00
QD75P2 2 AXIS, OPEN COLLECTOR OUTPUT 8,920.00
QD75P4 4 AXIS, OPEN COLLECTOR OUTPUT 13,370.00
QG60 BLANK COPVER FOR I/O SLOT 180.00
QH42P 24VDC POSITIVE COMMON INPUT, 32pt, OUTPUT: 32pt 4,460.00
QI60 16pt, RESPONSE TIME: 0FF-ON 0.2ms, ON-OFF 0.3ms OR SMALLER 3,570.00
QJ61BT11 CC-LINK UNIT FOR MASTER/LOCAL 3,120.00
QJ71BR11 MELSECNET/10H UNIT FOR COAXIAL 75 CABLE, SIMPLEX LOOP 13,370.00
QJ71C24 SERIAL COMMUNICATION UNIT FOR RS232C 1ch, RS422/485 1ch 5,620.00
QJ71C24-R2 SERIAL COMMUNICATION UNIT FOR RS232C 2ch 5,620.00
QJ71CMO RS-232 1ch 17,830.00
QJ71E71-100 ETHERNET UNIT FOR 10BASE-T/10BASE-TX 13,370.00
QJ71E71-B2 ETHERNET UNIT FOR 10BASE-2 13,370.00
QJ71E71-B5 ETHERNET UNIT FOR 10BASE-5 13,370.00
QJ71FL71 FL-NETWORK UNIT FOR 10BASE-5/10BASE-T 16,050.00
QJ71FL71-B2 FL-NETWORK UNIT FOR 10BASE-2 16,050.00
QJ71LP21-25 MELSECNET/10H UNIT FOR SI/QSI OPTICAL CABLE, DUPLEX LOOP 13,370.00
QJ71LP21G MELSECNET/10H UNIT FOR 50GI OPTICAL CABLE, DUPLEX LOOP 19,620.00
- 电话:0371-63897587
- 传真:0371-63897587
- email:weiyanbo03@gmail.com
下一篇:三菱变频配件(VVVF)
