- 型号:PNOZ X8P 24 VDC 3n/o 2n/c 2so
- 数量:100
- 有效期:2020/1/16 0:00:00
欢迎来电垂询手机:15959295713 QQ: 1296551037
774700 | PNOZ X10 24VAC 6n/o 4n/c 3LED |
774701 | PNOZ X10 42VAC 6n/o 4n/c 3LED |
774703 | PNOZ X10 110-120VAC 6n/o 4n/c 3LED |
774706 | PNOZ X10 230-240VAC 6n/o 4n/c 3LED |
774709 | PNOZ X10 24VDC 6n/o 4n/c 3LED |
774721 | PNOZ X6 42VAC 3n/o |
774725 | PNOZ X6 110-120VAC 3n/o |
774726 | PNOZ X6 230-240VAC 3n/o |
774729 | PNOZ X6 24VAC 24VDC 3n/o |
774730 | PNOZ X4 24VDC 3n/o 1n/c |
774731 | PNOZ X4 24VAC 3n/o 1n/c |
774732 | PNOZ X4 24 Vdc 3n/o 1n/c white box |
774734 | PNOZ X4 110VAC 3n/o 1n/c |
774735 | PNOZ X4 115VAC 3n/o 1n/c |
774736 | PNOZ X4 120VAC 3n/o 1n/c |
774738 | PNOZ X4 230VAC 3n/o 1n/c |
774739 | PNOZ X4 240VAC 3n/o 1n/c |
774740 | PNOZ X10.1 24 VAC 6n/o 4n/c 6LED |
774741 | PNOZ X10.1 42 VAC 6n/o 4n/c 6LED |
774745 | PNOZ X10.1 110-120VAC 6n/o 4n/c 6LED |
774746 | PNOZ X10.1 230-240VAC 6n/o 4n/c 6LED |
774749 | PNOZ X10.1 24VDC 6n/o 4n/c 6LED |
774789 | PNOZ V 3s 24VDC 3n/o 1n/c 1n/o (t) |
774790 | PNOZ V 30s 24VDC 3n/o 1n/c 1n/o (t) |
774791 | PNOZ V 300s 24VDC 3n/o 1n/c 1n/o (t) |
775505 | PU3Z 120-240VAC 3n/o 1n/c 6so |
775510 | PU3Z 24VDC 3n/o 1n/c 6so |
775600 | PNOZ 1 24VAC 3n/o 1n/c |
775620 | PNOZ 1 48VAC 3n/o 1n/c |
775630 | PNOZ 1 110-120VAC 3n/o 1n/c |
775650 | PNOZ 1 230-240VAC 3n/o 1n/c |
775695 | PNOZ 1 24VDC 3n/o 1n/c |
775730 | BUCH MASCHINENSICHERHEIT |
775735 | Buch Maschinensicherheit, spanisch |
777053 | PNOZ X7P 110-120VAC 2n/o |
777056 | PNOZ X7P 230-240VAC 2n/o |
777059 | PNOZ X7P 24VAC/DC 2n/o |
777070 | PNOZ 16SP 24VAC 24VDC 2n/o |
777071 | PNOZ 16SP 42VAC 24VDC 2n/o |
777072 | PNOZ 16SP 48VAC 24VDC 2n/o |
777073 | PNOZ 16SP 110VAC 24VDC 2n/o |
777074 | PNOZ 16SP 115VAC 24VDC 2n/o |
777075 | PNOZ 16SP 120VAC 24VDC 2n/o |
777076 | PNOZ 16SP 230VAC 24VDC 2n/o |
777077 | PNOZ 16SP 240VAC 24VDC 2n/o |
777080 | PNOZ X11P 24VAC 24VDC 7n/o 1n/c 2so |
777083 | PNOZ X11P 110-120VAC 24VDC 7n/o 1n/c 2so |
777086 | PNOZ X11P 230-240VAC 24VDC 7n/o 1n/c 2so |
777100 | PNOZ X1P 24VDC 3n/o 1n/c |
777140 | PZE 9P 24VACDC 8n/o 1n/c |
777148 | PZE 9P 24VACDC 100-240VACDC 8n/o 1n/c |
777150 | PZE X5P 24VDC 5n/o 2so |
777300 | PNOZ X2.9P 24VDC 3n/o 1n/c |
777301 | PNOZ X2.8P 24VACDC 3n/o 1n/c |
777302 | PNOZ X2.8P 24-240VAC/DC 3n/o 1n/c |
777303 | PNOZ X2P 24VACDC 2n/o |
777304 | PNOZ X2.3P 24VACDC 3n/o |
777305 | PNOZ X2.7P 24VACDC 3n/o 1n/c |
777306 | PNOZ X2.7P 24-240VAC/DC 3n/o 1n/c |
777307 | PNOZ X2P 48-240VACDC 2n/o |
777308 | PNOZ X2.5P 24VDC 2n/o 1so |
777310 | PNOZ X3P 24VDC 24VAC 3n/o 1n/c 1so |
777313 | PNOZ X3P 24-240VACDC 3n/o 1n/c 1so |
777314 | PNOZ X3.10P 24VACDC 3n/o 1n/c 1so |
777330 | P2HZ X1P 24VAC 3n/o 1n/c 2so |
777331 | P2HZ X1P 42VAC 3n/o 1n/c 2so |
777332 | P2HZ X1P 48VAC 3n/o 1n/c 2so |
777340 | P2HZ X1P 24VDC 3n/o 1n/c 2so |
777341 | P2HZ X1.10P 24VDC 3n/o 1n/c 2so |
777354 | P2HZ X4P 24VAC 3n/o 1n/c |
777355 | P2HZ X4P 24VDC 3n/o 1n/c |
777434 | P2HZ X1P 110VAC 3n/o 1n/c 2so |
777435 | P2HZ X1P 115VAC 3n/o 1n/c 2so |
777436 | P2HZ X1P 120VAC 3n/o 1n/c 2so |
777438 | P2HZ X1P 230VAC 3n/o 1n/c 2so |
777439 | P2HZ X1P 240VAC 3n/o 1n/c 2so |
777500 | PNOZ XV2P 30/24VDC 2n/o 2n/o t |
777502 | PNOZ XV2P 3/24VDC 2n/o 2n/o t |
777503 | PNOZ XV2P 1/24VDC 2n/o 2n/o fix |
777504 | PNOZ XV2P 0.5/24VDC 2n/o 2n/o fix |
777510 | PNOZ XV3P 30/24 VDC 3n/o 2n/o t |
777511 | PNOZ XV3.3P 30/24VDC 3n/o 2n/o t |
777512 | PNOZ XV3P 3/24 VDC 3n/o 2n/o t |
777514 | PNOZ XV3P 0.5/24VDC 3n/o 2n/o t fix |
777515 | PNOZ XV3P 3/24 Vdc 3n/o 2n/o t fix |
777517 | PNOZ XV3P 10/24 Vdc 3n/o 2n/o t fix |
777518 | PNOZ XV3P 300/24VDC 3n/o 2n/o t |
777520 | PNOZ XV3.1P 30/24VDC 3n/o 1n/c 2n/o t |
777522 | PNOZ XV3.1P 3/24VDC 3n/o 1n/c 2n/o t |
777525 | PNOZ XV3.1P 3/24VDC 3n/o 1n/c 2n/o t fix |
777530 | PNOZ XV3.1P 30/24-240VACDC 3no 1nc 2no t |
777532 | PNOZ XV3.1P 3/24-240VACDC 3no 1nc 2no t |
777538 | PNOZ XV3.1P 300/24-240VACDC 3no 1nc 2no |
777540 | PNOZ XV2.1P 30/24-240VACDC 2n/o 2n/o t |
777542 | PNOZ XV2.1P 3/24-240VACDC 2n/o 2n/o t |
777544 | PNOZ XV2.1P 0.5/24-240 VacDC 2n/o 2n/o fi |
777545 | PNOZ XV2.1P 3/24-240 VacDC 2n/o 2n/o fix |
777547 | PNOZ XV2.1P 10/24-240 VacDC 2n/o 2n/o fix |
777548 | PNOZ XV2.1P 300/24-240VACDC 2n/o 2n/o t |
777580 | PZE X4VP 0,5/24VDC 4n/o fix |
777581 | PZE X4VP 1/24VDC 4n/o fix |
777582 | PZE X4VP 2/24VDC 4n/o fix |
777583 | PZE X4VP 3/24VDC 4n/o fix |
777584 | PZE X4VP8 24VDC 4n/o |
777585 | PZE X4P 24VDC 4n/o |
777586 | PZE X4VP4 24VDC 4n/o |
777587 | PZE X4.1P 24VDC 4n/o |
777588 | PZE X4.1P 24-240VAC/DC 4n/o |
777600 | PNOZ X2.1VP 0.75/24VDC 1so 2n/o fix |
777601 | PNOZ XV1P 3/24VDC 2n/o 1n/o t |
777602 | PNOZ XV1P 30/24VDC 2n/o 1n/o t |
777606 | PNOZ X9P 24VDC 100-240VACDC 7no 2nc 2so |
777607 | PNOZ X9P 12VDC 7n/o 2n/c 2so |
777609 | PNOZ X9P 24VDC 7n/o 2n/c 2so |
777750 | PNOZ X10.11P 24VDC 6n/o 4n/c 6LED |
777760 | PNOZ X8P 24 VDC 3n/o 2n/c 2so |
777764 | PNOZ X8P 110VAC 3n/o 2n/c 2so |
777765 | PNOZ X8P 115VAC 3n/o 2n/c 2so |
777766 | PNOZ X8P 120VAC 3n/o 2n/c 2so |
777768 | PNOZ X8P 230VAC 3n/o 2n/c 2so |
777770 | PNOZ X8P 24VAC 3n/o 2n/c 2so |
777949 | PSWZ X1P 0,5V /24-240VACDC 2n/o 1n/c 2so |
777950 | PSWZ X1P 3V /24-240VACDC 2n/o 1n/c 2so |
777951 | PSWZ X1P 0,0075-0,5V/24-240VACDC |
778010 | PMUT X1P 24VDC 3n/o 1n/c 5so |
779000 | PNOZmulti Tool-Kit |
779110 | PNOZmulti Bus-Terminator |
779112 | PNOZmulti Bus-Terminator coated |
779120 | PNOZpower Bus-Terminator |
779125 | PNOZ pe2p Bus-Interface |
779200 | PNOZmulti Chipcard Set 10 pieces 8kB |
779201 | PNOZmulti Chipcard 1 piece 8kB |
779211 | PNOZmulti Chipcard 1 piece 32kB |
779212 | PNOZmulti Chipcard Set 10 pieces 32kB |
779230 | Chip Card Reader |
779240 | PNOZmulti Chipcard Holder (Sparepart) |
779250 | PNOZmulti Seal 10 pieces |
783100 | Set spring terminals PNOZ m0p/m1p/m2p |
783400 | Set spring term mi1p/mi2p/mo1p/mo3p/ml1p |
783520 | Set spring terminals PNOZ mo2p |
783536 | Set spring terminals PNOZ mo4p/mo5p |
783537 | 10 Set spring terminals PNOZ mo4p/mo5p |
783700 | Set spring terminals PNOZ mc1p/ma1p |
783800 | Set spring terminals PNOZms1p/ms2p |
- 电话:15959295713
- 传真:15959295713
- email:npliuqin12@163.com
下一篇:供应圆锥滚子轴承
相关推荐
