- 型号:BXK
- 数量:200
- 制造商:上海柯铭防爆电器有限公司
- 有效期:2051/11/29 0:00:00
优质防爆箱,乐清防爆箱,防爆配电箱,防爆箱厂家 BXM(D)59防爆配电柜 配电箱 控制箱
适用范围
1、爆炸性气体环境:1区、2区
2、场所中危险气体或蒸气:IIA、IIB
3、温度组别:T1~T6
4、户内、户外(防护等级IP54, 可达IP65)
Applying scope
1、Explosive gas atmospheres:Zone 1&2
2、Dangerous gases or vapors zone: IIA、IIB
3、Temperature classes:T1~T6
4、Indoor and outdoor (IP 54,It could be designed as IP65 according to user′s requirements)
产品特点
1、铸铝合金外壳,表面喷塑
2、内可装C65N(H)-C、C65N(H)-D、NC100H及类似小型断路器
3、具有过载、短路保护功能
4、C65N(H)-C 优先适用于照明配电系统,C65N(H)-D优先适用于动力配电系统
5、进出线腔、电器元件腔分别独立
6、输入:3P+N+PE 输出:3P+N+PE或1P+N+PE
7、可根据用户要求特制
8、可钢管或电缆布线,电缆布线须配电缆夹紧密封接头
Features
1、Enclosure is made of casting aluminium alloy,surface is sprayed with plastics
2、Built-in small breaker such as C65N(H)-C, C65N(H)-D,NC100H etc
3、With overload and short circuit protection function
4、C65N(H)-C is preferable of lighting distribution system and C65N(H)-D for power distribution system
5、Inlet,outlet compartment and component compartment are independent from each other
6、Input:3P+N+PE , output: 3P+N+PE or 1P+N+PE
7、For user′s requirements, it could be specially made
8、Wiring with conduit or cable,For cable, it should be fitted with explosion-protected cable sealing connector
主要技术参数 Specification
型号 防爆标志 额定工作电压(V) 主回路额定工作电流(A) 支路数 支路额定工作电流(A) 使用类别 极数 进线口规格 出线口规格电缆外径
BBX□59-4N Exde II BT6 380/400
220/230 4 1,3,6,10,16,
25,32,40,50,
63,80,100,125 AC1,AC3 3P+N+PE
3P+PE
1P+N+PE G40
F16~F24.5 G20
F8~F12
BX□59-6N 6
BX□59-8N 8
BX□59-10N 10
BX□59-12N 12
BX□59-4K ≤80 4
BX□59-6K ≤125 6
BX□59-8K ≤125 8
BX□59-10K ≤125 10
BX□59-12K ≤125 12
- 电话:0577-61780756
- 传真:0577-61780759
- email:1466908630@qq.com
