BLACK BOX切换器ACURA002A
2012/6/13 9:34:28
0 人气:6
- 数量:90
- 有效期:2019/6/28 0:00:00
产品名称:BLACK BOX切换器ACURA002A
型号:ACURA002A
品牌:BLACK BOX
BLACK BOX切换器ACURA002A;BLACK BOX延长器ACURA002A;BLACK BOX KVM延长器;ACURA002A
Rackmount CAT5 KVM Extender Hubs with Serial and Bidirectional Stereo Audio
KVM serial and audio extensions up to 300 metres - plus dual-access and rackmount options!
Combines six extenders in one box.
Send keyboard, monitor, mouse, and serial and bidirectional stereo audio signals up to 300-m from a CPU or ServSwitch?.
Dual-access capability enables the connection of two KVM consoles to each CPU.
Saves money and space.
Fully adjustable video equalisation for the best possible video quality.
Hub and remote units feature built-in surge protection on the CAT5 link side.
规格:
Clamping Voltage - Up to 15 volts
Compatibility - Keyboard: PC/AT?, PS/2?;
Monitor: VGA, Super VGA, XGA;
Mouse: PS/2 mouse only (user)
Resolution (Maximum) -
ACUWREM: 1600 x 1200 @ 60 Hz: 50 m;
ACU1006MVRA: 1600 x 1200 @ 60 Hz: 50 m;
ACUVREM:
1600 x 1200 @ 60 Hz: 60 m;
1280 x 1024 @ 60 Hz: 90 m;
1024 x 768 @ 60 Hz: 300 m;
ACURA001/2/4A:
1600 x 1200 @ 60 Hz: 200 m;
1280 x 1024 @ 60 Hz: 300 m
Connectors - ACU1006VRA: (6) DB25 F, (12) 3.5-mm barrel jack, (6) DB9 F, (6) RJ-45 F;
ACU1006DVRA: (12) Mini DIN 6-pin (Mouse and Keyboard) and (6) HD15 F;
ACUWREM: (1) HD15 F, (1) RJ-45 F, (2) Mini DIN 6-pin, (2) 3.5-mm barrel jack;
ACU1006MVRA: (6) HD15 F, (6) RJ-45 F, (12) Mini DIN 6-pin, (12) 3.5-mm barrel jack;
ACUVREM: (1) HD15 F, (1) RJ-45 F, (2) Mini DIN 6-pin, (2) 3.5-mm barrel jack;
ACURA001A: (1) HD15 F, (1) RJ-45 F, (2) Mini DIN 6-pin, (2) 3.5-mm barrel jack;
ACURA002A: (2) HD15 F, (2) RJ-45 F, (2) Mini DIN 6-pin, (2) 3.5-mm barrel jack;
ACURA004A: (4) HD15 F, (4) RJ-45 F, (2) Mini DIN 6-pin, (2) 3.5-mm barrel jack
Power — Hubs: 100-240 VAC, 50-60 Hz, external, auto sensing, with IEC connector and power cord;
Remote Units: External power supply unit 100-240 VAC auto sensing (included)
Dimensions - ACU1006VRA: 4.4(H) x 48.3(W) x 11.4(D) cm;
ACU1006DVRA: 8.8(H) x 48.3(W) x 11.4(D) cm;
ACUWREM: 5.1(H) x 8.1(W) x 10.9(D) cm;
ACU1006MVRA: 4.4(H) x 44.2(W) x 11(D) cm;
ACUVREM: 9.9(H) x 19.8(W) x 3.6(D) cm;
ACURA001A, ACURA002A: 4.4(H) x 14(W) x 14.5(D) cm;
ACURA004A: 4.4(H) x 27.4(W) x 14.5(D) cm
- 电话:02158126804-614
- 传真:02158126844
- email:14494442@qq.com
工控宝APP下载安装
