BLACK BOX KVM ACU1002A
2012/6/19 9:30:52
0 人气:4
- 数量:90
- 有效期:2019/7/4 0:00:00
产品名称:BLACK BOX KVM ACU1002A
型号:ACU1002A
品牌:BLACK BOX
BLACK BOX切换器ACU1002A;BLACK BOX延长器ACU1002A;BLACK BOX KVM延长器;ACU1002A
ServSwitch? CAT5 KVM Extenders
Send one or two high-quality video channels to a remote site over CAT5 or higher cable
CAT5 extender kits support extensions of 1600 x 1280 video up to 60-m; CATx kits support extensions of 1600 x 1200 video up to 200-m from your CPU. Go even further at lower resolutions!
Place your keyboard, monitor and mouse station far from your CPU and get clear video at the remote end.
All dual-access units have single/dual local video outputs.
Dual-video versions suit CPUs with multihead video applications.
Serial models are available for transmitting touch screen and other RS-232 serial port data.
Audio versions for CATx transmit near-digital-quality audio from the CPU to the remote end.
Single- and dual-access kits available.
CATx remote units include built-in skew compensator.
All monitor skew compensation can be fine-tuned easily via keyboard hotkey commands — even at long distances and high resolutions.
Video settings store in nonvolatile memory.
Keyboard/mouse emulation provides keep-alive functionality.
Flash-upgradable remote units.
ACU2201A-R2 and ACU2222A-R2 extender kits feature DDC support on higher video bandwidth, and can be flash upgraded on the local end.
To pair individual extender remote units with a hub extenders or to set up quad-video extensions, see our CATx extenders.
Warranty — 1 Year..
规格:
Compatibility - Keyboard: PS/2. PC/AT, (with optional AC244A and FA222-R2)
Video: VGA, Super VGA, XGA.
Mouse: PS/2 mouse only (user).
Clamping Voltage - 15 volts
Resolution (Maximum) - CAT5 versions: 1600 x 1280: 60-m; 1280 x 1024: 90-m; 1024 x 768: 305-m;
CATx versions: 1600 x 1200: 200-m; 1280 x 1024: 300-m; For all versions, higher resolutions may be possible at shorter distances
Connectors - ACU1001A, ACU2001A: Local: (1) RJ-45, (1) HD15 M, (2) 6-pin mini DIN F; Remote: (1) RJ-45, (1) HD15 F, (2) 6-pin mini DIN F, (1) DB9 F;
ACU1002A: Local: (1) RJ-45, (1) HD15 M, (2) 6-pin mini DIN F, (1) DB9 F; Remote: (1) RJ-45, (1) HD15 F, (2) 6-pin mini DIN F, (1) DB9 F;
ACU1009A:, ACU2009A: Local: (1) RJ-45, (1) HD15 M, (1) HD15 F, (4) 6-Pin mini DIN F; Remote: (1) RJ-45, (1) HD15 F, (2) 6-pin mini DIN F;
ACU1008A: Local: (1) RJ-45, (1) HD15 M, (1) HD15 F, (4) 6-pin mini DIN F, (1) DB9 F; Remote: (1) RJ-45, (1) HD15 F, (2) 6-pin mini DIN F, (1) DB9 F;
ACU1022A, ACU1028A: Local: (1) RJ-45, (1) HD15, (2) 6-pin mini DIN F, (1) 3.5-mm barrel jack, (1) DB9 F; Remote: (1) RJ-45, (1) HD15, (2) 6-pin mini DINF, (2) 3.5-mm barrel jack, (1) DB9 F;
ACU2022A: Local: (1) RJ-45, (1) HD15 M, (2) 6-pin mini DIN F, (2) 3.5-mm audio, (1) DB9 F; Remote: (1) RJ-45, (1) HD15 F, (2) 6-pin mini DIN F, (2) 3.5-mm audio, (1) DB9 F;
ACU2028A: Local: (1) RJ-45, (1) HD15 M, (1) HD15 F, (4) 6-pin mini DIN F, (2) 3.5-mm audio, (1) DB9 F; Remote: (1) RJ-45, (1) HD15 F, (2) 6-pin mini DIN F, (2) 3.5-mm audio, (1) DB9 F;
ACU2201A-R2: Local: (2) RJ-45, (1) DB25 F, (1) HD15 M; Remote: (2) RJ-45, (2) HD15 F, (2) 6-pin mini DIN D;
ACU2209A: Local: (2) RJ-45, (1) HD15 M, (2) HD15 F, (1) DB25 F, (2) 6-pin mini DIN F; Remote: (2) RJ-45, (2) HD15 F, (2) 6-pin mini DIN F;
ACU2222A-R2: Local: (2) RJ-45, (1) HD15 M, (1) DB25 F, (2) 3.5-mm audio, (1) DB9 F; Remote: (2) RJ-45, (2) HD15 F, (2) 6-pin mini DIN F, (2) 3.5-mm audio, (1) DB9 F; Remote: (2) RJ-45, (2) HD15 F, (2) 6-pin mini DIN F, (2) 3.5-mm audio, (1) DB9 F;
ACU2228A: Local: (2) RJ-45, (1) HD15 M, (2) HD15 F, (1) DB25 F, (2) 6-pin mini DIN F, (2) 3.5-mm audio, (1) DB9 F; Remote: (2) RJ-45, (2) HD15 F, (2) 6-pin mini DIN F, (2) 3.5-mm audio, (1) DB9 F
Power - Local units: From the PC
Remote units: 100-240 VAC, 50-60 Hz, external, autosensing, with IEC 320 connector.
Dimensions - ACU1001A-ACU1002A, ACU1008A-ACU1009A, ACU1022A, ACU1028A: Both local and remote units: 3.6(H) x 19.8(W) x 9.9(D) cm;
ACU2001A, ACU2209A, ACU2228A: Local units: 3.6(H) x 9.9(W) x 19.8(D) cm; Remote units: 2.8(H) x 14.5(W) x 14(D) cm;
ACU2022A, ACU2028A: Local units: 4.3(H) x 9.9(W) x 19.8(D) cm; Remote units: 4.3(H) x 9.9(W) x 19.8(D) cm;
ACU2201A-R2: Local unit: 2.8(H) x 14.7(W) x 10.9(D) cm; Remote unit: 4.3(H) x 14.5(W) x 14(D) cm;
ACU2222A-R2: Local unit: 4.1(H) x 14.5(W) x 10.9(D) cm; Remote unit: 4.3(H) x 14.5(w) x 14(D) cm
- 电话:02158126804-614
- 传真:02158126844
- email:14494442@qq.com
工控宝APP下载安装
