- 型号:IS-12-C3-S2,95B061611,IS-12-C4-03,95B061621,IS-12-C4-S2
- 数量:10000
- 有效期:2024/5/4 0:00:00
电感式接近开关,模拟量接近开关,光电开关,防水接近开关
灵敏度,分辨力高,位移:0.1mm,精度高,线性特性好,非线性误差0.05%~0.1%
性能稳定,重复性好;
1、外型规格:Φ4 M5 Φ6.5 M5 M8 M12 M18 M30 CP40等
2、镍铜合金外壳 3、标准型、缩短型、长型
4、标准和双量程工作距离 5、工作距离:0.8至30MM
6、电缆、M8或M12接头连接 7、NPN、PNP、NPN/PNP、NO、NC、NO/NC
8、防护等级IP67(IEC)
95B064030 ,IS-12-A0-03,95B064060 ,IS-12-A0-S2,95B061241 ,IS-12-A1-03,
95B061251 ,IS-12-A1-S2,95B061271 ,IS-12-A2-03,95B061281,IS-12-A2-S2,95B061181 ,IS-12-A3-03,95B061191,IS-12-A3-S2,95B061211,IS-12-A4-03,
95B061221,IS-12-A4-S2,95B064100 ,IS-12-A9-03,95B063931 ,IS-12-A9-S2,
95B064040 ,IS-12-B0-03,95B062041 ,IS-12-B1-03,95B062051,IS-12-B1-S2,
95B062071 ,IS-12-B2-03,95B062081 ,IS-12-B2-S2,95B061981 ,IS-12-B3-03,
95B061991 ,S-12-B3-S2,95B062011 ,IS-12-B4-03,95B062021 ,IS-12-B4-S2,
95B064080 ,IS-12-C0-S2,95B061641,IS-12-C1-03,95B061651 ,IS-12-C1-S2,
95B061671 ,IS-12-C2-03,95B061681,IS-12-C2-S2,95B061581 ,IS-12-C3-03,
95B061591 ,IS-12-C3-S2,95B061611,IS-12-C4-03,95B061621,IS-12-C4-S2
95B064110,IS-12-C9-03,95B064140 ,IS-12-C9-S2,95B062441 ,IS-12-D1-03,
95B062451,IS-12-D1-S2,95B062471IS-12-D2-03,95B062481,IS-12-D2-S2,
95B062381,IS-12-D3-03,95B062391 ,IS-12-D3-S2,95B062411 ,IS-12-D4-03,
95B062421,IS-12-D4-S2,95B067030 ,IS-12-E1-S2,95B067020,IS-12-F1-S2,
95B063841,IS-12-G0-03,95B064070,IS-12-G0-S2,95B063361,IS-12-G1-03,
95B063371,IS-12-G1-S2,95B063381,IS-12-G2-03,95B063391 ,IS-12-G2-S2,
95B063321,IS-12-G3-03,95B063331 ,IS-12-G3-S2,95B063341,IS-12-G4-03,
95B062661,IS-12-G6-03,95B062671,IS-12-G6-S2,95B063801,IS-12-G9-03,
95B064130 ,IS-12-G9-S2,95B064050,IS-12-H0-03,95B064090 ,IS-12-H0-S2,
95B063441,IS-12-H1-03,95B063451 ,IS-12-H1-S2,95B063461,IS-12-H2-03,
- 电话:18317108518
- 传真:021-57687139
- email:li630988995@163.com
