- 型号:IS-18-C2-03,IS-18-C2-S2,IS-18-C3-03,IS-18-C3-S2
- 数量:10000
- 有效期:2024/5/4 0:00:00
DC3线-电容式圆柱接近开关,电感式防水接近开关,横拟量接近开关
灵敏度,分辨力高,位移:0.1mm ,精度高,线性特性好,非线性误差0.05%~0.1%
性能稳定,重复性好;
外型规格:Φ4 M5 Φ6.5 M5 M8 M12 M18 M30 CP40等。
特点描述FeatureDescription:
1、可以检测金属、塑料、液体等不同物质 2、具有浪涌、逆极性和短路保护功能
3、电位器可方便调节灵敏度 4、金属外壳,坚固耐用
5、适用温度范围为-25?70℃ 6、防护等级IP67(IEC)
95B063471,IS-12-H2-S2,95B063401,IS-12-H3-03,95B063411 ,IS-12-H3-S2,
95B063421 ,IS-12-H4-03,95B063431 ,IS-12-H4-S2,95B062761 ,IS-12-H5-03,
95B062771 IS-12-H5-S2,95B062741 ,IS-12-H6-03,95B062751 ,IS-12-H6-S2,
95B064120 ,IS-12-H9-03,95B064150 ,IS-12-H9-S2,95B064230 ,IS-18-A0-03,
95B064260 ,IS-18-A0-S2,95B061341 ,IS-18-A1-03,95B061351 ,IS-18-A1-S2
95B061361 ,IS-18-A2-03,95B061371 ,IS-18-A2-S2,95B061301 ,IS-18-A3-03,
95B061311 ,IS-18-A3-S2,95B061321 ,IS-18-A4-03,95B061331 ,IS-18-A4-S2,
95B064300 ,IS-18-A9-03,95B063941 ,IS-18-A9-S2,95B062141 ,IS-18-B1-03,
95B062151 ,IS-18-B1-S2,95B062161,IS-18-B2-03,95B062171,IS-18-B2-S2,
95B062101,IS-18-B3-03,95B062111,IS-18-B3-S2,95B062121,IS-18-B4-03,
95B062131,IS-18-B4-S2,95B064240,IS-18-C0-03,95B064280,IS-18-C0-S2,
95B061741,IS-18-C1-03,95B061751,IS-18-C1-S2,95B061761,IS-18-C2-03,
95B061771,IS-18-C2-S2,95B061701,IS-18-C3-03,95B061711,IS-18-C3-S2,
95B061721,IS-18-C4-03,95B061731,IS-18-C4-S2,95B064310,IS-18-C9-03,
95B064340,IS-18-C9-S2,95B062541,IS-18-D1-03,95B062551,IS-18-D1-S2,
95B062561,IS-18-D2-03,95B062571,IS-18-D2-S2,95B062501,IS-18-D3-03,
95B062511,IS-18-D3-S2,95B062521,IS-18-D4-03,95B062531,IS-18-D4-S2,
95B067050,IS-18-E1-S2,95B067040,IS-18-F1-S2,95B063851,IS-18-G0-03 T,
95B064270,IS-18-G0-S21,95B063521,IS-18-G1-03,95B063531,IS-18-G1-S2,
- 电话:18317108518
- 传真:021-57687139
- email:li582586887@163.com
