![](http://nfs.gongkong.com/Upload/trade/201505/20150519093604722_w.jpg)
- 型号:FOXBORO MODEL # RS-83
- 数量:10
- 制造商: 厦门兴锐达自动化设备有限公司
处理器:Intel? Core? 2 Duo ULV 1.2GHz (U2500) 处理器, FSB 533MHz
· 系统内存:200-pins DDRII 533/ 667 SODIMM Socket x 1,最大2GB (出厂设定)
· LCD/CRT控制器:Intel? 945GME
· LCD显示:8.4" SVGA (800 x 600) TFT LCD 带触摸屏和数字转换器 (选配)
· 通讯:
千兆以太网, RJ-45 x 1
56kbps V.92/K56 flex modem RJ-11 x 1
WLAN 802.11 a/g
蓝牙 Class 2 (选配)
· I/O接口:
RS-232 x 1
USB2.0 x 2
Mini USB x 1
Docking port (contact pin with USB/RS-232/Power signal) x 1
Two Audio in/out jack for Microphone/ Earphone
· 硬盘:2.5" HDD支架 / SSD
· 扩展插槽:PCMCIA, Mini 卡槽 x 2 (内置), CF
· 操作系统:Windows? XP Embedded
· 结构
· 构造:铝美合金
· 颜色:黑色
· 尺寸:270mm (W) x 184mm (D) x 51mm (H) (10.63"x 7.24" x 2")
· 包装尺寸:515mm(W) x 270 mm(D) x 360mm(H) (20.28"x 10.63"x14.17")
· 总重:2.15Kg(4.7 lb)
环境
· 工作温度:
0oC ~ 60oC (32oF ~ 140oF) HDD
-20oC ~ 60oC (-4oF ~ 140oF) HDD加热器(选配)
-10oC ~ 60oC (14oF ~ 140oF) SSD (选配)
· 存储温度:-55oC ~ 75oC (-67oF ~167oF)
· 工作湿度:10 - 95% @ 40C, 无冷凝
· 防尘防水:
Rain chamber to operate at no less than 40 PSIG and no less than 4 in
/ hr. 10 min per axis, 6 axes, Unit is non-operating.
Mil Std 810F-506.4 Procedure II, IPX4
Meets IEC 60529 IP-5X standard, Protected against dust, limited ingress (no harmful deposit)
· 振动:Meets Mil Std 810F-514.5, Procedure I Cat. 24, Fig. 514.5C-17 & 14.5C-18 (Unit is non-operating)
ASTM 4169-99 Truck Assurance Level II, Schedule E (Unit is operating)
· 跌落:Mil Std 810F-516.5, Procedure IV
· ESD:Air +/- 8KV, Contact +/- 4KV
· EMC/安全:CE/FCC Class B
电源
· AC / DC 适配器:
AC 输入: 100V-240V, 50Hz-60Hz, 65W
DC 输入: 20V
兴锐达不吹牛!想要比同行低15个点!请贵宾来电!保证满意!
FOXBORO 202S-10-SNFSFSNFSFSNFSS
FOXBORO B0133SA-D
Foxboro P0972QM-0C
FOXBORO D0134JUJ
FOXBORO 2ANU-D-FGB
FOXBORO D0140AE
FOXBORO FWS-KBC1-E
FOXBORO IGP20-A22B21F-M1
Foxboro FBM43
FOXBORO B0134ZT
NEW!! FOXBORO IDP10-T22A21F-L1S2T
FOXBORO D0141AV
FOXBORO E69F-TI2-RS
FOXBORO L0118UH
FOXBORO 3AT-SPL
Foxboro 2CDA-S1
Agilent HP 85680B
FOXBORO 873EC-AIPCGZ-7
FOXBORO KIT-C-E27-A-C
- 电话:0592-5580706/13295922579
- 传真:0592-5361191
- email:LJY_05228@163.com
