- 型号:钨铼热电偶
- 数量:1
- 制造商:苏州迅鹏仪器仪表有限公司
钨铼热电偶|迅鹏推荐
产品名称: 钨铼热电偶
特别说明:目前我公司生产的W-Re热电偶分三类,一类是采用的精细陶瓷保护管,另一类是纯钼保护管,再一类就是钨保护管。陶瓷管的规格有:直径为Ф8,Ф10,Ф12,Ф14,Ф16,长度300~1100mm,这类热电偶不受工作环境气氛的限制能在任何气氛中长期使用,测温范围是0~1800℃的;钼管和钨管规格有:直径为Ф6,Ф8,Ф10mm,长度500~700mm,这种热电偶只能在真空、还原或者惰性气体保护的环境中长期工作,钼管最好是在1800℃以下的温度下长期使用,短期使用温度能到2000℃;至于钨管则能在2100℃下长期工作,但很难加工致使其价格非常昂贵。请根据我们的参数选择适合于您的热电偶。
隔爆本安型带热电偶电阻系列,SBWR-4270/440D,WZP2-892
室内用双支铂热电阻系列,WREK-440,WRE2-740,WRN2-740,0512-68381801.WRN2-440A,WRNK-240,WREK2-240,WRNK-841n*i,WRNK-842n*i,WRE-240A,WREK-841n*I,WREK-842n*i,WRN2-240A,WREK2-440,WRN-640,WRN2-640,WRN-740,WRE-440A,WRNK-440,WRE-640,WRE2-640,WREK-842n*D,WZP-64SB,.SBWR-4280/8413KD,XMTA-100,MWFT-1,MWFT-2,MWFT-3,WZP-120B,WZP-121B,WZP-130B,WZP-131B,WZP2-120B,WZP2-121B,WZP2-130B,WZP2-131B,WZC-120B,WZC-130B,WZP-220B,WZP-221B,
WZP-230B,WZP-231B,WZP2-220B,.WZP2-221B,WZP2-230B,WZP2-231B,WZP-220ABWZP2-220AB,WZC-220B,WZC-120B,
电站测温用热电阻系列WZC-130B, WZP-220B,.WZP-221B,WZP-230B,WZP-231B,WZP2-220B,WZP2-221B, WZP2-230B,WZP2-231B,WZP-220AB,WZP2-220AB。WZC-220B,WZC-230B,WZC-220AB,WZP-320B,WZP-321B,WZP-330B,WZP-331B,WZP2-320B,WZP2-321B,WZP2-330B,WZP2-330B,WZC-320B,WZC-320B,WZP-420B,.WZP-421B,WZP-430B,WZP-431B,.WZP2-420B,WZP2-421B,WZP2-430B,WZP2-431B,WZP-42AB,WZP2-42AB,WZC-420B,WZC-430B,WZP-420B,WZP-421B,WZP-430B,WZP-430B,WZP-431B,WZP2-420B,WZP2-421B,WZP2-430B,WZP2-431B,WZP-42AB,WZP2-42AB,WZP-420B,WZC-430B,WZP-621B,WZP-621AB,WZP-631B, WZP2 -621B,WZP2 -621B,WZP2 -631B,WZP-621B, WZP-631B,WZP-621B,WZP2 -631B,WZP-621AB,WZP2-621AB,WZP-002,.WZP-003,WZP-003A,WZCM-201, WZPM-201,WZPM-201,WZP-270S,WZP-26S,WZP-236SB
薄膜铂热电阻系列WZP2-236SB,WZP-1312AB,WZP2-1312AB,WZP-212AB,WZP2-212AB,WZP-3312AB,WZP2-3312AB,WZP-4312AB,WZP2-4312AB,0512-68381801.WZP-6312AB,WZPK-103U,WZPK-104U,WZPK-105U,WZPK-106U,WZPK-106U,WZPK-204U,WZPK-205U,WZPK-206U,WZPK-303U,WZPK-304U,WZPK-305U,WZPK-306U,0512-68381801.WZPK-403U,WZPK-404U,WZPK-405U,WZPK-406U,WZPK-503U,WZPK-504U,WZPK-505U,WZPK-506U,WZPK-133U,WZPK-134U, WZPK-135U,WZPK-136U,.WZPK-233U,WZPK-234U,WZPK-235U,WZPK-236U,WZPK-333U,WZPK-334U,WZPK-335U,WZPK-336U,WZPK-433U,WZPK-434U,WZPK-435U,WZPK-436U,WZPK-533U,WZPK-534U,WZPK-535U,WZPK-536U,WZPK-123UWZPK-124U
装配式不锈钢接线盒铂电阻系列WZPK-125U,WZPK-126U, WZPK-223U,WZPK-224U,WZPK-225U,WZPK-226U,WZPK-323U,WZPK-324U,0512-68381801.WZPK-325U,WZPK-326U,WZPK-423U,WZPK-424U,WZPK-425U,WZPK-426U,WZPK-523U,WZPK-524U,WZPK-525U,WZPK-526U,WZPK-163U,WZPK-164U,WZPK-165U.WZPK-166U,WZPK-263U,WZPK-264U,WZPK-265U,WZPK-266U,WZPK-363U,WZPK-364U,.WZPK-365U,WZPK-366U,WZPK-463U,WZPK-464U,WZPK-465U
铠装铂电阻系列WZPK-466U,WZPK-563U,0512-68381801.WZPK-564U,WZPK-565U,WZPK-566U, WZPK-173U,WZPK-174U,WZPK-175U,WZPK-176U,WZPK-273U,WZPK-274U,WZPK-275U,WZPK-276U,WZPK-373U,WZPK-374U,WZPK-375U,WZPK-376U,WZPK-473U,WZPK-474U,WZPK-475U,WZPK-476U,WZPK-573U,WZPK-574U,.WZPK-575U,WZPK-576U,WZPK-103S,WZPK-104S,WZPK-105S,WZPK-106S,WZPK2-105SA,WZPK2-106SA,WZPK-203S,WZPK-204S,WZPK-205S, WZPK-206S,WZPK2-205SA,WZPK2-206SA,WZPK-303S
- email:2850806280@qq.com
