- 型号:3126/3126B/3145/3150/3160/3176/3176B
- 数量:1000
- 制造商:宁波北仑日兴动力科技有限公司
- 有效期:2020/7/1 0:00:00
宁波日昕动力科技有限公司建立了一套完整的卡特彼勒CAT柴油机、柴油发电机零配件供应体系,全天候快速响应,纯正的卡特彼勒CAT柴油机、柴油发电机配件是您最佳的选择,因为您所得到的是延长卡特彼勒CAT柴油机、柴油发电机动力系统寿命的最佳保证。
特别声明:我司只销售卡特彼勒CAT柴油机、柴油发电机原厂配件,需付厂或防品件请绕道,谢谢。卡特彼勒c17滤清器,卡特彼勒c17柴油滤清器,卡特彼勒c17 空气滤清器,卡特彼勒c17机油 柴油 空气滤清器
卡特彼勒CAT全系列产品型号有:1693,3003,3013,3014,3024,3034,3054,3056,3066,3114,3116,S6K,3126,3126B,3126E,3145,3150,3160,3176,3176B,3176C,3196,3204,3208,3304,3304B,G3304,3306,3306B,3306C,G3306,3406,3406B,3406C,3406E,3408,3408B,3408C,3408E,G3408,3412,3412C,3412E,G3412,3456,3504,3504B,3508,3508B,G3508,3512,3512B,G3512,PM3512,3516,3516B,G3516,PM3516,
索引
系统操作
缩略语和符号.....................................................................7
空气进气和排气系统........................................................24
后冷却机......................................................................25
排气旁通阀(带有涡轮增压器的发动机)...................31
涡轮增压器...................................................................30
阀门系统部件...............................................................32
空气起动系统...................................................................43
基本部件...........................................................................41
凸轮轴..........................................................................42
曲柄轴..........................................................................42
汽缸组、汽缸套和汽缸盖............................................41
活塞、轮圈和连杆........................................................42
冷却系统...........................................................................36
冷却水系统...................................................................40
分开回路后冷却机系统................................................41
电力系统...........................................................................44
充电系统部件...............................................................44
其他部件......................................................................47
起动系统部件...............................................................46
电子点火系统.....................................................................8
发动机设计.........................................................................5
G3508............................................................................5
G3512............................................................................5
G3516............................................................................6
发动机监控和停机保护....................................................12
发动机起/止面板..........................................................14
接线盒.........................................................................13
发动机性能参数...............................................................11
预定定时参数..............................................................12
负载定时图..................................................................12
速度灵敏定时图..........................................................11
燃料、进气和排气系统....................................................16
2301A电子调速器.......................................................19
3161调速器.................................................................21
燃料系统......................................................................17
点火系统............................................................................9
控制模块......................................................................10
发动机传感器..............................................................10
点火变压器..................................................................10
润滑系统..........................................................................33
3161调速器的操作..........................................................23
测试与调节
空气进气和排气系统......................................................119
检查后冷却机运转.....................................................125
压缩............................................................................126
曲柄轴箱(曲柄轴隔舱)压力.....................................125
汽缸盖........................................................................126
发动机旋转................................................................126
排气旁通阀................................................................119
进气集管温度(所有后冷却系统)...........................119
排气温度的测量.........................................................119
空气进气和排气的限制..............................................119
空气起动系统.................................................................150
润滑...........................................................................151
压力调节阀...............................................................150
基本部件......................................................................140
检查曲柄轴偏转......................................................144
连杆轴承.................................................................140
汽缸组......................................................................140
飞轮和飞轮罩...........................................................142
主轴承......................................................................140
活塞环.......................................................................140
汽缸套凸...................................................................141
减震器.......................................................................145
凸轮轴定时.....................................................................128
桥调节........................................................................130
气门间隙设定的曲柄轴位置......................................132
气门间隙....................................................................132
冷却系统.........................................................................135
皮带张力表................................................................140
冷却系统的测试.......................................................136
冷却系统的外观检查.................................................135
电力系统........................................................................145
电池............................................................................147
充电系统...................................................................147
起动系统....................................................................148
电力系统的测试工具.................................................145
为1号活塞找出上静点压缩位置....................................126
燃料系统..........................................................................67
对已知热含量燃料的调节...........................................70
化油器........................................................................69
燃气压力调节器..........................................................69
初始调节.....................................................................67
低排放发动机设定......................................................72
氧气排放曲线图..........................................................72
点火系统..........................................................................61
点火系统部件...................................................................62
部件操作.....................................................................62
定时和燃料表..............................................................66
润滑系统.........................................................................133
油压计........................................................................135
机油温度升高.............................................................135
发动机油压的测量....................................................134
油压过高...................................................................135
油压过低..................................................................134
轴承磨损太严重........................................................135
油耗过高...................................................................133
故障检查..........................................................................50
故障检查问题列表.......................................................50
配线图.............................................................................60
规格
注:如想获得带有插图的具体部件规格,请参看SENR6411,G3500发动机规格部分。如果在SENR6411中的规格与发动机操作、测试和调节中所提供的规格不一致,请看每本书封面上的出版日期,并使用最近出版日期的那本书的规格。
如果在页的边缘标有“C”,则表明内容与以前出版的有所改变。
- 电话:15088860848 0574-26886646
- 传真:0574-26892499
- email:ygx556@163.com
