- 型号:RZ3A40D40
- 数量:100
- 制造商:深圳市天为机电设备有限公司
CARLO GAVAZZI瑞士佳乐固态继电器RZ3A40D40
三相过零型固态继电器内置浪涌保护,带LED批示,具体规格如下:
外形尺寸(mm)H*W*D:74*103*41
控制电压范围:4-32VDC
最大输入电流:23mA
额定工作电流:电阻性负载时为40A;电感性负载时为8A
工作电压范围:42-440Vrms
最大峰值电压:≤850Vp
工作温度:-30℃–+80℃
端子:接线端子
认证/标准:CE-UL-CSA
相关型号:
RZ3A40A25: SSR 3 POLE ZS 24-440V 25A 24-275VAC
RZ3A40A25P: SSR 3 POLE ZS 24-440V 25A 24-275VAC +OTP
RZ3A40A40: SSR 3 POLE ZS 24-440V 40A 24-275VAC
RZ3A40A40P: SSR 3 POLE ZS 24-440V 40A 24-275VAC +OTP
RZ3A40A55: SSR 3 POLE ZS 24-440V 55A 24-275VAC
RZ3A40A55P: SSR 3 POLE ZS 24-440V 55A 24-275VAC +OTP
RZ3A40A75: SSR 3 POLE ZS 24-440V 75A 24-275VAC
RZ3A40A75P: SSR 3 POLE ZS 24-440V 75A 24-275VAC +OTP
RZ3A40D25: SSR 3 POLE ZS 24-440V 25A 4-32VDC
RZ3A40D25P: SSR 3 POLE ZS 24-440V 25A 4-32VDC +OTP
RZ3A40D40: SSR 3 POLE ZS 24-440V 40A 4-32VDC
RZ3A40D40P: SSR 3 POLE ZS 24-440V 40A 4-32VDC +OTP
RZ3A40D55: SSR 3 POLE ZS 24-440V 55A 4-32VDC
RZ3A40D55H33: SSR 3 POLE ZS 24-440V 55A 4-32VDC + HS WAS565M:
RZ3A40D55P: SSR 3 POLE ZS 24-440V 55A 4-32VDC +OTP
RZ3A40D75; SSR 3 POLE ZS 24-440V 75A 4-32VDC
RZ3A40D75P: SSR 3 POLE ZS 24-440V 75A 4-32VDC +OTP
RZ3A40LD25; SSR 3 POLE ZS 24-440V 25A 5VDC
RZ3A40LD40: SSR 3 POLE ZS 24-440V 40A 5VDC
RZ3A40LD55; SSR 3 POLE ZS 24-440V 55A 5VDC
RZ3A40LD75; SSR 3 POLE ZS 24-440V 75A 5VDC
RZ3A60A25: SSR 3 POLE ZS 42-660V 25A 24-275VAC
RZ3A60A25P: SSR 3 POLE ZS 42-660V 25A 24-275VAC +OTP
RZ3A60A40: SSR 3 POLE ZS 42-660V 40A 24-275VAC
RZ3A60A40P: SSR 3 POLE ZS 42-660V 40A 24-275VAC +OTP
RZ3A60A55; SSR 3 POLE ZS 42-660V 55A 24-275VAC
RZ3A60A55H33; SSR 3 POLE ZS 42-660V 55A 24-275VAC + HS WA565M;
RZ3A60A55P; SSR 3 POLE ZS 42-660V 55A 24-275VAC +OTP
RZ3A60A75; SSR 3 POLE ZS 42-660V 75A 24-275VAC
RZ3A60A75P: SSR 3 POLE ZS 42-660V 75A 24-275VAC +OTP
RZ3A60D25: SSR 3 POLE ZS 42-660V 25A 4-32VDC
RZ3A60D25P: SSR 3 POLE ZS 42-660V 25A 4-32VDC +OTP
RZ3A60D40; SSR 3 POLE ZS 42-660V 40A 4-32VDC
RZ3A60D40P; SSR 3 POLE ZS 42-660V 40A 4-32VDC +OTP
RZ3A60D55; SSR 3 POLE ZS 42-660V 55A 4-32VDC
RZ3A60D55P: SSR 3 POLE ZS 42-660V 55A 4-32VDC +OTP
RZ3A60D75: SSR 3 POLE ZS 42-660V 75A 4-32VDC
RZ3A60D75P: SSR 3 POLE ZS 42-660V 75A 4-32VDC +OTP
RZ3A60LD25: SSR 3 POLE ZS 42-660V 25A 5VDC
RZ3A60LD40: SSR 3 POLE ZS 42-660V 55A 5VDC
RZ3A60LD75: SSR 3 POLE ZS 42-660V 75A 5VDC
RZ3A69A75: SSR 3 POLE ZS 42-760V 75A 24-275VAC
RZ3A69D75: SSR 3 POLE ZS 42-760V 75A 4-32VDC
RZ3A69LD75: SSR 3 POLE ZS 42-760V 75A 5VDC
- 电话:0755-29412192,29412193,13923452066(微信同号)
- 传真:0755-29179602
- email:sales@sztianwei.net
